Question about Peg Perego John Deere Gator HPX Ride on Toy
The john deere gator ride on, where do you plug the charger in to the gator?
    Genius:
  • Peg Perego Master
  • 1,508 Answers
The battery is behind the front grille, you have to remove the screw in the middle and then pull out on the green plastic clips on each side then fold down
Posted on Jun 13, 2012
  • 60 Answers
SOURCE: old john deere gator and battery new charger still will not move
Could be several things.  Your battery could be bad. After not being charged for a while, they do go bad- often. You may want to try a new battery along with your new charger.  You could also have a switch /connection problem. If you get a new battery and it still doesnt work, you may want to check the switches and wiring. It is not uncommon for the switch to go bad especially if it had been stored outside.
Posted on Mar 11, 2009
  • 156 Answers
SOURCE: replace parts on ride-on toys
The gearboxes for both hummers and peg perego gators are under the back seat.
If you hear a clicking noise It is definatly the gearbox on the gator. The hummer gearboxes sometimes come loose from the motors, so it may be as simple as tightning the motor gearbox.
Here is how you take the gearboxes out from the gator.
1. disconnect battery
2. take hinge pins out from the dump bed to access the green cover plate.
3. take a flathead screwdriver and pry around the plastic cover to expose the gearboxes.
4. take the rear wheels off and remove the rear axle.
remove the motor gearboxes (they are interchangeable)
5. install the new gearboxes making sure the wires are secure and the wheels are going in the correct direction.
6. put back together.
7. hook up battery and your good to go!
If you have any problems are questions you can contact these guys at http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-switches-and-shifters.html.
They have a toll-free number and are very smart when it comes to these peg perego ride on toys.
Posted on Apr 08, 2009
  • 156 Answers
SOURCE: John Deere Gator 4x2 - Left Wheel doesn't move when in 2nd gear
I would replace the high/low switch and the reverse switch. One time a replaced the high/low switch and the reverse switch quit on me 2 weeks later.
You can also get the Peg Perego Gator Shifter that upgrades the vehicle.
You can get the parts and repair help at this site
They have helped me several times.
Hope this helps
Posted on May 26, 2009
  • 156 Answers
SOURCE: help for my childs John Deer Gator
the peg perego gators have two switches in the shifter that need replaced.
I have replaced them before on my grandkid's gator.
Here is the website I get my parts from
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.html
You can also call them direct at 1.801.655.0800.
They seem to always know which part I need and I have always been very happy with their service.
Hope this helps
Posted on Mar 18, 2010
  • 19 Answers
SOURCE: john deere gator 1999 4x6 overheating.replaced
bleed air out of cooling system contact dealer for instructoins
Posted on Aug 17, 2010
Where do you plug the charger to the john deere power wheels gator
you have to flip down the front brush guard and then you'll have access to the battery to disconnect it from the vehicle and connect it to the charger
Jun 27, 2014 | Peg Perego John Deere Gator HPX Ride on...
Where is the do you plug the charger in at
you have to disconnect the battery from the gator and plug the charger into it. its located behind the front bumper.
Dec 25, 2010 | Peg Perego John Deere Gator HPX Ride on...
How do i access the battery to charge it up?
On a regular John Deere there are 2 small screws on the hood that must be removed and the hood lifts up. The battery has a cable that disconnects and the charger plugs into the end that goes to the battery. The connectors only go on one way, don't force it.
Hope this helps.
Here is a link to the page to download a manual:
http://us.pegperego.com/toys-catalog/2010/John+Deere+Gator+HPX
Thanks for using Fixya.
Dec 24, 2010 | Peg Perego John Deere Gator HPX Ride on...
My sons john deere gator is dead do they send new batteries or chargers for it
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in, otherwise you can order a new one here www.powerwheelsoutlet.com
Sep 05, 2010 | Peg Perego John Deere Gator HPX Ride on...
Where do you plug in the battery charger on the John Deere peperego Gator ride on ?
the battery is behind the front grille, you have to remove the screw in the middle and then pull out on the green plastic clips on each side then fold down
Jun 24, 2010 | Peg Perego John Deere Gator HPX Ride on...
John Deere Gator HPX 12 Volt Ride on Toy by: where do you plug in the charger for the gator...
May 17, 2010 | Peg Perego John Deere Gator HPX Ride on...
John Deere Gator HPX 12 Volt Ride on Toy by: I can't find where to plug in the charger on the j...
May 16, 2010 | Peg Perego John Deere Gator HPX Ride on...
Help for my childs John Deer Gator
May 09, 2010 | Peg Perego John Deere Gator HPX Ride on...
Where does charger plug in gator
The Peg Perego Gator Battery is located in front behind the black gril and green battery door
Jun 20, 2009 | Peg Perego John Deere Gator HPX Ride on...
Peg Perego John Deere Gator HPX Ride on Toy Logo
46 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
