Question about Samsung DLP HL-P5663W 56" TV
My hlt4675sx/xaa won't power up. The Stand by/ temp light and the lamp light flash. The bulb id brand new.
    Top Expert:
  • Samsung Master
  • 14,553 Answers
First thing to do is look from back of set or area when lamp is: do you see the lamp come on for even a few seconds?
Also is the problem the exact same as before lamp Replaced?
Before set failed did you hear unusual fan like, high pitched whine or even grinding sound?
Depending on how you answer I will assist you.
SD TECH
Posted on Aug 22, 2010
Yes
Posted on Jul 23, 2011
Samsung hlt4675sx/xaa lamp ballast keeps going out
Hello Leeann,
Wow 3 ballasts is too many too quick. Did this solve you problem every time?
Have you checked the voltage going to the ballast? this might be a power supply issue. The power going into the ballast should be between 320V - 380V. Please do not try to measure the power going to the lamp! The ignition charge can be 15kV and it is dangerous to you and a multimeter.. please let me know and I will try to help you get to the bottom of this
Jan 06, 2014 | Samsung HLT4675SX/XAA OEM TV Lamp
My sanding tv hlt4675sx xaa keeps turning off. When I turn it back on here a little grinding noise... now when I turn it on can here the fans come on nothing else. No light from the bulb is showing from...
It sounds like the color wheel has fallen apart. I would recommend calling Samsung at 1-800-samsung to find the closest service center. This can be a difficult repair and I would strongly recommend a Samsung authorized repair center.
Aug 01, 2011 | Samsung Televison & Video
Samsung model hlt4675sx\xaa projection tv wont work. the stand by/temp light flashes red and the lamp light flashes green? it makes the sound that it makes when it turns on but no picture. we looked at the...
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Jul 31, 2011 | Samsung DLP HL-P5663W 56" TV
Samsung hls4266wx/xaa tv. tv stays on for a minute, then shuts down Timer lamp flashes and temp standby
I put a lamp in to my Samsung HLS4266WX/XAA, but when I actually took it apart for the Bulb replacement which I have done twice now. I found where that switch is, that gets pressed when you have the back cover to the bulb screwed in was hanging, and I can get the new bulb and my replacement bulb to work for about 15 secs, and at one point it was working really good. Can anyone help me with this problem, cause Im getting frustrated. It seems like a simple fix,but its almost like the bulb I ordered is not as good as my other replacement bulb.Its from MWAVE.com, anyone heard anything about this company? Please help if you can, id really appreciate it.
Joe Red
May 21, 2011 | Samsung HLS4266 TV
Samsung TV: HLP4663WX/XAA Lamp Code: BP96-00826A(P) No picture . . . no light from lamp On/Off Switch: ''lamp'' and ''Stand By Temp'' Should I replace the lamp?
hello am rico, no. first check your power supply, because lamp has nothing to do with power. more like it you goona have power supply problem. if you need more help, feel free to call at 602-810-7149 anytime.
Jan 07, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung dlp HLN5065W1X/XAA new bulb no pic 3 lights come on in the front that are labeled timer lamp and temp
If you have replaced the lamp, then the ballast or power supply board have failed.You can call 1-800-samsung for the nearest service center.
Jan 27, 2010 | Televison & Video
Samsung HLS4266WX/XAA warnings w/ new lamp also
You may be in need a new ballast, the assembly that excites the bulb into producing output.
Sep 20, 2017 | Samsung Televison & Video
Blinking lights on HLT5075SX/XAA samsung
Manual says you need to replace the lamp: When do I need to replace it?
• It should be replaced when the screen becomes darker, less clear or when all three LEDs on the front (STAND BY/TEMP, LAMP, and
TIMER) are flashing
imgadgetman
Aug 09, 2009 | Samsung HCM4215W 42" Rear Projection...
Samsung DLP HL-P5663W 56" TV Logo
1,262 people viewed this question
Henry  Thomas
Henry Thomas
