Question about Canon PowerShot SD950 IS Digital Camera
I have a Canon PowerShot SD950 IS Digital ELPH, with almost no use, one day when I went to use it not lit. I charged the battery again and turned on the camera: nothing happen!. Please help!
SOURCE: My powershot SD1000 digital elph
well i just hit it really hard and shook it and then it started working again.
Posted on May 12, 2008
SOURCE: canon powershot sd30 digital elph
I have same problem. I turn on the camera you hear it trying to come on, shows display pic for like 3 seconds and then shuts down. If I could get the lens to retract I am sure the camera would work.
Posted on Jun 24, 2008
SOURCE: Camera won't power up
Mine was the microswitch that tells the camera the battery / card door is closed. The tiny, cheap plastic protrusion that pushes on the switch broke off. Jam the switch with the end of a toothpick.
Posted on Feb 07, 2009
jamo297
  • 19 Answers
SOURCE: Canon Powershot SD870 IS Digital Elph will not
This solution was originally posted by rulds2008.
"The battery regulator inside needs to be replaced around $15 from radioshack or you can take it to a camera shop for around $35 bucks. If its still under warrenty Take it in and have it repaired free."
Posted on Jul 18, 2009
  • 58 Answers
SOURCE: camera in water
Remove the battery, card and bake it in the sun(window sill, front seat of the car) with any plugs or doors open for a few days. Same as cell phones. Good luck. It doesn't always work.
Posted on Sep 18, 2009
I can't turn on the camera, even with a fully charged battery.
The battery contacts are like little springs, as the camera gets jostled these can stop making good contact. Open the battery case and try force holding the battery against the contacts (You may need to hold a piece of metal across the bottom of the battery as you push) Then see if the camera comes on.
If it does, you may have to stuff, pull, or rig the battery to fit more securely.
Mar 17, 2010 | Canon PowerShot SD950 IS Digital Camera
My canon sd950 is will not start when i press the on button. the lens tries to open, but then shuts
Hi there, please relace the battery with new fully charged battery. After that is the same problem happens then clean the power button & clean the lens guide pin internaly. After that your problem will be solve. Thanks.
Mar 15, 2010 | Canon PowerShot SD950 IS Digital Camera
Camera will not turn on
clean the bazttery comparment,contact points,if u fail to get on the camera,then it is problem of power section,so contact canon service station
Mar 05, 2010 | Canon PowerShot SD950 IS Digital Camera
Battery not charging
the charger light detect the battery level charge, shows red when charging and green when fully charged.when the charger light is not lit,may be the battery dosnt hold any charge that means its likely that the battery is defective
Dec 20, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
My canon powershot sd950 is not turning on after I finished a travel by plane. The battery is brand new and when I shake the camera there is no noise.
I had the same problem. I sent it to Canon and it came back today fixed and free of charge even though I've had it for almost two years. Then I tried using it again tonight and it doesn't work again. I charged the battery pack, still not working. I found out that this camera has a service notice for it on canon's site. My camera does have one of the serial #'s they describe. I guess they fixed it for free b/c it was a loose screw but now it's come loose again the same day. How frustrating! I have to have a camera for tomorrow so I'll go buy another camera. I'll still send this one back to Canon and see what they do this time.
Here's the link so you can check your serial #. Good luck!
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=224&modelid=15652&keycode=2112&id=55260
Oct 30, 2009 | Canon PowerShot SD950 IS Digital Camera
I have a 1 and 1/2 year old powershot SD950IS digital elph - worked fine one day and would turn on the next day . . . two different charged batteries, still not powering on. Is it fixable?
That can be from a few causes such as the fuses blowing. It is worth fixing if you have warranty but may cost as much or more than a replacement camera if you are no longer covered..
Oct 23, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon sd950is won't turn on
Dear Sir,
Welcome to Fixya
Might want to take a look at this:
http://canoncanada.custhelp.com/app/answers/detail/a_id/11506/session/L3Nuby8xL3NpZC9FVFAyZDdCag
A screw inside some Canon PowerShot SD950 IS cameras may loosen and fall out due to vibration that is generated while carrying or using the camera. Apparently a screw might have come out that prevents the camera from turning on.
The repair is free-of-charge, even fro out-of-warranty period.
I think it helps.
If you have any problem regarding this issue leave a feedback we were Happy to assist you.
Have a Nice Day
Oct 14, 2009 | Canon PowerShot SD950 IS Digital Camera
Camera in water
Sep 18, 2009 | Canon Cameras
My Canon PowerShot SD950 IS won't turn on
http://canoncanada.custhelp.com/app/answers/detail/a_id/11506/session/L3Nuby8xL3NpZC9FVFAyZDdCag==
My SD950 just refused to power on during a trip out west. Apparently a screw might have come out that prevents the camera from turning on. The repair is free-of-charge, even fro out-of-warranty period.
It is a beautiful camera: pictures are not too shabby, but the design is fantastic for a portable ...
Jun 23, 2009 | Canon PowerShot SD950 IS Digital Camera
Card locked!
my camera Canon PowerShot SD630 DIGITAL ELPH/DIGITAL IXUS 65 out off work the lenc dsnt work bcose the battry was lowa atar the my camera stop intel now no work please inser me thank you
Oct 08, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon PowerShot SD950 IS Digital Camera Logo
107 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
