Question about Royal RS9512C Shredder
No forward motion. It does not shred. - Royal RS9512C Shredder
    Genius:
  • 1,218 Answers
You can check/clean the eye's in the paper "throat"...if that dosn't fix it then you possibly have defective pcb...you can call Royal at 1-800-524-0799 for parts assistance.
Posted on Aug 28, 2010
The top thread shreds sewing in reverse.
(put my answer in wrong box on this site. Duh)
Get a good light on the foot so you can study the problem. You may need three hands or a helper. Thread the needle, and hold the end of the thread as you hand turn the hand wheel forward, press the reverse and as the needle goes through the foot see if isn't rubbing the foot. If its not rubbing the foot, take the feet pieces off and go through the same motions watching to see if the needle/thread isn't rubbing on the hole in the feed dog. You may need to go down a size in your needle or modify your machine parts with emery cord.
Good Luck.
Mar 14, 2016 | Juki DU-1181N Walking foot Industrial...
Why doesn't forward shredding work?
  • The jam was not cleared completely
  • The shredding mechanism was damaged in the process of clearing he jam
Nov 28, 2015 | Royal 150MX Cross-Cut Shredder
My Black & Decker Shredder #BD-61 all of a sudden does not work. I used it tonight, but the next time I tried it does not work. The lights come on in both positions, but
On some shredders when both the forward and reverse LEDs are on it can indicate either a jam or a full receiver bag/ container (the area that the shredded paper is fed into).
Try the following steps:
  1. ) unplug the power
  2. ) open up the shredder (see 1 on diagram)
  3. ) empty out all the shredded paper (see 2 on diagram)
  4. ) check that the shredding jaws (both the entrance and exit) are clear of any shredded material (see 3 on diagram)
  5. ) put everything back together
  6. ) plug power cord back in
  7. ) force the shredder into reverse (see 4 on diagram)
Hopefully you should hear your shredder motor running. If it is switch it to automatic and try shredding again
Jan 24, 2015 | Shredder Office Equipment & Supplies
20822 Department shredder
The motor has a feature to go forward and reverse and thus the forward (paper in) control has been compromised. The problem can be the switches. A rocker switch when in one position may control the forward motion or backward motion, therefore if the switch fails only one side is working. Then there may be two small switches on the so called rollers (Cutters) that sense the input of paper into the cutters thereby starting the motion and shredding procedure. If a sensing device is broken, only the unaffected switch works. Repair is usually expensive, thus a replacement is in order.
Dec 18, 2013 | Dahle Office Equipment & Supplies
How to lubricate a Black & Decker Model BD-s600 paper shredder
    • 1 Turn the paper shredder off and unplug it.
    • 2 Clean out the paper shredder. Make sure the blades are free of paper bits and debris. Remove pieces of paper that are jammed around the blades.
    • 3 Spray the shredder oil through the blade opening or throat of the shredder. Spray it in a stream.
    • 4 Plug the shredder back in and switch the reverse button on. Then run it for 10 to 30 seconds in reverse to allow the blades to be saturated with shredder oil.
    • 5 Put the shredder in forward motion and let it run again to disperse the oil thoroughly to all areas of the cutting blades.
    • 6 Feed a couple pieces of paper through the blades to be shredded and absorb any extra shredding oil.
Read more: How to Lubricate Paper Shredders ' eHow.com http://www.ehow.com/how_5761042_lubricate-paper-shredders.html#ixzz1kDQGrxZ8
Jan 22, 2012 | Office Equipment & Supplies
Royal 15MX shredder does not run at all in auto mode. Runs fine in reverse.
There is most likely something blocking your shred gears preventing it from running in forward motion. If you press the feed button will it engage the motor? If not, you will need to have it serviced if you cannot visibly see any blockage. Be sure to unplug this unit before attempting to clear the pathway.
Mar 13, 2011 | Royal 15MX Shredder
What do the three signs where the switch are mean. i do not have a manual. I am talking about the two arrows the circle and the (I). I just want to know what each one is for .
forward off reverse.
when you switch on the shredder will work in a forward motion.
if the schredder gets blocked, you can switch reverse to release paper from shredded in a bacward motion.
and off for when not in use.
I hope this was helpful
Jan 11, 2011 | Office Equipment & Supplies
My shredder overload light comes on immediately with only one sheet of paper inserted and it won't go.
Try running the machine in reverse and putting some shredder oil onto the cutting blades to loosen things up. Then try running the machine in the forward direction but hold the paper in the eyes but dont let it go into the shredding blades...see if it runs forward.!
If it will do this then slowly try paper 1 sheet at a time..but put some shredder oil onto the sheets of paper you are shredding.
If the overload light still comes on without even letting you shred 1 sheet of paper then you likely have another problem...maybe the motor or pcb..you can contact Royal at 1-800-524-0799 for parts assistance.
Oct 28, 2010 | Royal RS9512C Shredder
Shreds in reverse only
I think there is a shredded buildup on the bottom. Unlpug the device ... turn it over and clear out the residue you will find there.
Sometimes I find the addition of shredder oil during the shredding process helps to eliminate this problem. Get the oil where shredders are sold.
May 31, 2010 | Tech Solution TS-4500 Shredder
46 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
