Question about Carrier Heating & Cooling
We have a carrier heat pump/ac unit. Our ductwork in the attic has condensation all over it and it is dripping thru our newly installed insulation to the sheetrock on the second floor thereby staining, leaving sheetrock wet and possibly being taken over by mold and mildew. What can be done to improve this problem. We are under a 10 year warranty plan with this unit and the company that installed it. Windows have condensation on them. Humidity is 60 to 70 percent.
    President:
  • 3,074 Answers
Usually if there is a lot of condensation, then there is bare/uninstulated metal in the duct work. Now if the unit itself is condensating then putting a condensation pan under the unit with a drain should fix this problem. A far as the windows it will happen but shouldn't cause a mold problem. hope this helps Tim
Posted on Aug 22, 2010
Testimonial: "As it is night here, we will have to check this out later this week. I do have surgery tomorrow. I do believe that we have the pan installed."
My(38ycc030340)carrier heat Pump ac unit blows 5 amp fuse on board in handler in attic when switch stat to heat.
Miss wired or shorted low voltage wiring. Have you changed stat? Animal chewed wires at foundation wall or in attic?
Oct 10, 2016 | Carrier Heating & Cooling
My Carrier Infinity system Model FE4A is leaking water from the bottom of the unit on to the basement floor. How do I stop the leak?
have your HVAC technician check the pressures in your unit...sounds like you may have low pressure. You should NOT be having any ice build up to melt off.
Sep 13, 2014 | Carrier Infinity Series Variable Speed...
There is moisture condensation on clothes dryer vent pipe. The pipe goes up and through the attic and is greater than 25 feet long. We have cleaned the pipe in the attic and replaced connecting pipe and...
hot moist air ( from drying clothes) will cool down and the moisture collects on the cooler surfaces the further from the dryer
the insulation used has to be thick rubber or fibre glass insulation or the moisture will still form on thin insulation talk with ac installers especially shops that install ducted ac units for some ideas
Oct 30, 2017 | Maytag Dryers
In our company there is ductatble AC unit having capacity of 10 Ton which catert the AC requirement of two office rooms. This AC unit is installed in passage above false sealing and duct is extened to...
Hi, this is a 10 ton a/c unit, more then likely has 2 stages of cooling. You say the copper suction line is wrapped with insulation already, and the problems continue? What you need to do next as the evaporator coils are in the ceiling, is to have a condensation pan made to cover the bottom of the unit to catch any moisture that drips from the suction line and evaporator coils and have a 3/4" drain that will drain into existing condensate line. You can't prevent the suction line from sweating has thee cold temperatures are reaching its dew point and will always drip. The line should be wrapped with a black cork type insulation that has a sticky back that is made for this suction line. All you can do is have a sheet metal pan made to put under this unit to catch the moisture and let it drain or evaporate if its not real bad. I have seen this many times with units that are in the ceiling, which will destroy the tiles. Keep in mind that the suction line will reach temperatures of 40*F and will drip condensation when it is cooling so they should have put a pan under this unit when it was installed. This will solve the problem, and that's about all that you can do. Please don't forget to rate me as I know you will be kind. I wish I had other ways to solve this, but this is the only way, and the way it should have been done to begin with.
Sincerely, Shastalaker7
A/C, Heating, & Refrigeration Contractor
Sep 04, 2010 | Heating & Cooling
Why does my AC keep freezing (Carrier FB4ANF036). I have replaced the blower motor less than a month ago due to the same problem. Just last night we had a lightening storm and shortly after that the AC...
if your system is a heat pump you can switch to heat and see if coil outside gets cold while indoor blows warm air - then switch back to a/c - both coils should not be cold at the same time - low freon pressure / dirty coil / dirty filter / low air flow causes freezing
Sep 22, 2009 | Carrier Heating & Cooling
Little Giant Condensate pump runs for 1 sec when res not full
Is there a check valve in the pumps discharge fitting? If there is it may be stuck open or broken allowing some of the water to return to the reservoir once the pump shuts off which then may lead to the brief cycle between full cycles.
If there is not one, install one to keep any water from backing back into the reservoir and that should stop the short runs.
Aug 06, 2009 | Plumbing
Air condition cleaning
hi! there,
if your unit is almost five years from now,its more convenient to have a maintenance schedule every two to three time a year,if this a windows type,cleaning of ac unit mostly the eveporator and condenser should free from dust,upon installing,the a/c unit should be eleveted down on condenser,the tray should have a drain with hose to drip the water outside your room,so that water will not leak on your light,see this may cause electrical fault resulted on burning.have always clean the filter.try to inform the maintenance crew to elevate the condenser portion down gradually so that water will drip outside the room.have anice day,don't forget get to rate me,and thank's a lot.
Apr 26, 2009 | Heating & Cooling
My Heat will not work on my upstairs unit. I am getting an E2 error code on my carrier thermostat. what does that mean?
the e2 code on a carrier comfort zone thermostat is indicitive of the external safety sensors which are located on your units ductwork in the attic. the e2 code are the hpt/ and lat sensor codes. the hpt is the heat pump temperature sensor and the lat is the leaving air temperature sensor. you can pull off the cover of the panel and behind it will actually give you all the fault codes associated with you carrier tsat.each sensor has a certain ohm rating and if its out of the range it will fail. now as to the reasons for failure, the indoor coil could be dirty, filters dirty, refrigerant charge incorrect.
Dec 03, 2008 | Carrier Heating & Cooling
Condensation collecting on AC hoses in condo attic
Hi zimexlady
I'm Harvey the Master Plumber
Your question is can you use foam ****-tubing to cover these hoses to absorb drips? Now, wrapped with black tape
YES! The tubing doesn't absorb drips, it insullates the pipes against the humidity. I'm surprised it was not insullated to begin with as that is required for this very reason! When insullating don't leave any gaps and you'll be fine.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Plumbing
A\c unit
it cold be different problems.
1-check for any air leaks around the house.
2-check the return box and see if have any opening and seal the holes.
3-check the insulation on the attic or any motor that takes the heat out the attic.
4-check if the unit is under tonage each tonage mean a 400 sf per ton.
5-check if the air handler coil is not dirty and enought air going thru the coil.
6-check the pressure of the condenser unit if have the rigth presures.
7-check thermostat if is set-up right.
Jul 22, 2008 | Heating & Cooling
Heating & Cooling Logo
148 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
