Question about Lite On Laars Lite 2 Heaters: 250,000BTU MV Heater
Laars boiler my boiler will not fire up the pilot is on the pump is running can you help
  • tommy50 May 27, 2008
    thanks for your help i have found the problem after by passing the high & low limit stats the bioler fired up and found the wires had melted inside the caseing as the boiler is 26 months old and cost £ 1.500 i will not be recomending a laars boiler to any one
It's likely the pressure switch. If the heater isn't enough water pressure through it it won't fire. I had the same problem with mine. Try bypassing the switch with a little piece of wire and see what happens.
I replaced my switch this year and it seems to be working fine. You might want to take the switch off and let water pump through the siphon hose for a few minutes.
Good luck.
B
Posted on May 26, 2008
I'm having the same problem. I thought it was due to having to put some non-detergent oil in the siphon loop, but that doesn't work either....i'm still having the same problem...will not kick on!!!!
Posted on May 04, 2008
Boiler won't fire the pilot is lit.
Flame sensor not picking up flame and won't release /open gas valve
Mar 16, 2016 | Hydrotherm Gas Fired Boiler Hvx-105 Power...
My laar hot shot natural gas pool heater pilot says lit but wont fire any more replaced pilot generator pilot that whole unit nice pilot but wont fire
problem isnt with the pilot generator. you have either an open safety withing circuit, lose wiring connection, or tstat issue
Aug 17, 2013 | Teledyne Laars Laars Lite 2 Pool Heater...
Have a problem with a laars boiler the pilot keeps
How long does it stay lit (if at all)? It sounds like the thermocoupler (about 10 bucks). Good luck
Dec 25, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Have a problem with a laars mini therm ii boiler. the pilot keeps
hi. i have mini temp boiler 150 btu 5yers old . it is burning with know radiation .it is up to thempitio .but it will not shut off.flame is good radietor is hot ,help?
Nov 04, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Boiler won't fire even though the pilot is lit
Check if the ignition plug works. Upon putting your boiler on, a spark will normally trigger the
the firing. Then, check the ignition transformer if it works. Check the secondary voltage which is between 15000 to 20000 volts to trigger the ignition plug and the boiler to fire. If no spark,
have your ignition transformer replaced to make it work.
Sep 21, 2009 | Heating & Cooling
Pilot Flame will not ignite
Clean the pilot tube of rust or other debris.
Jul 10, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars Lite 2 - Turns off after 5mins of being on!
This happened to me and the tech came out and change the pressure switch and it worked fine afterwards
Jun 15, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Heating & Cooling Logo
420 people viewed this question
Top Lite On Heating & Cooling Experts
1STHVACMAN
Paul Carew
Michael Galve
Michael Galve
Are you a Lite On Heating and Cooling Expert? Answer questions, earn points and help others
