Question about Gateway (8007054) Laptop Heatsink
When I turn my laptop on, a message says:"Turn off computer, check fan".
  • 855 Answers
You need to check that the cooling fan is working. That warning is telling you that the fan is not working and if you continue to use the laptop you risk burning up the hard drive and other components in your laptop. Have it repaired ASAP. Then purchase an external cooling fan that sits under your laptop and use this as well when using the laptop.
Posted on Aug 22, 2010
    Scholar:
  • 122 Answers
Best solution I would recommend would be to take a can of air to it. Give your laptop a good once or twice over.
Cleans it good :)
Message keeps popping up saying Turn off computer, problem in cooling system
you need to get pressurized air and blow the vents to remove dust particles causing over heat. Or if possible remove keyboard to expose cooling fan and chip and use pressurized air to blow off dust
Nov 25, 2013 | Toshiba Satellite 1715XCDS Cooling Fan...
Turn fan on
Fans might be controlled in the bios, so check the bios or system setup.
The fans, if working properly will turn on and off as needed. Unless you are getting a error message about the fan, don't worry about it. Also if the computer runs hot and shuts down, then you might have a fan problem.
May 10, 2012 | HP Compaq nc8230 Notebook
I turn on my laptop ad what i get is a fan error message after which it turns off what could be the issue and how to solve it. Hit the escape key and it booted up and the fan is running full time. is this...
I turn on my laptop notebook lenovo s10-2 ad what i get is a fan error message after which it turns off but thiers still power what could be the issue and how to solve it. i can not use now my laptop
Jan 25, 2011 | Lenovo ThinkPad X60 Tablet PC
My computer wont boot up the fan and light turn on for a second then goes right off....
With the little bit of information presented, it appears that this is possible a power supply problem. One thing you can try is to unplug the power adapter from the laptop, remove the battery, then plug the power adapter back into the laptop. Then try to turn it on. If everything comes up normally, then the problem points, potentially, to the battery.
Hope this helps!
Feb 18, 2010 | HP Pavilion dv9000z Notebook
Fan quit working on laptop. I've heard conflicting information from stores today about whether or not new computer is needed or this being repairable. When I turn on computer, it says "system fan...
Hi There,
The message that you are getting from your computer system is because the motherboard has got very hot and therefore requires new motherboard and the new fan will come with it. I would buy a new computer instead of repairing this one due to the cost involved.
The answer to your data is yes... your hard drive can taken out and the data copied to another system, or even burned to cd. I would buy an external drive kit from pc shop and instert your drive into it and use it as an external deive on your new laptop.
Please let me know if you need more help.
Regards,
Philip
Dec 01, 2008 | Gateway Computers & Internet
I turned on my laptop and i get a "system fan error" message that says "turn off system and check your system fan!!"
If you are not a technician, please do not attempt to service yourselves. Take your laptop to the service center.
Aug 06, 2008 | Gateway Computers & Internet
Fan error problem
you need to open up laptop and firstly check connections and lead to fan then check fan for dust and debris ,to check fan need to remove cover above it.check if fan freely spins if a bit sticky or stiff pull off plastic fan and clean off motor shaft.you wouldnt think so but hairs and stuff over a period of time accumulate there.with the pc turn on try to physically spin it .if nothing at all fan needs replacing.it could also be the power to the fan but this is unlikely for the mere fact that pc has detected problem in first place.
Mar 05, 2008 | IBM ThinkPad A31 Notebook
Toshiba S2450 PS245E Laptop Heating Problem
toshiba 2450
1 clean the cpu radiator 2 make sure the fan works, 3 install toshiba common modules and toshiba chipset drivers. 4 go into bios and set devices managed by the os.
Dec 24, 2007 | GPS
Computers & Internet Logo
97 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
