Question about Janome Memory Craft 3000
The top thread on my Janome 300E is getting caught in the bobbin. It starts bunching up on the back of the fabric that I am trying to embroider and it gets stuck. When I pull it off all the top thread is caught up where the bobbin is. How do I fix it?
  • 109 Answers
If your thread is getting caught underneath it's usually the UPPER thread is threaded wrong or not correctly through the tension discs. This can also happen if you're using Sticky Back stabilizer. Make sure you have a new needle in case there's a burr on the old one which can also cause this problem.
Posted on Aug 23, 2010
Why is the fabric bunching into the bobbin when embroidering with the Singer Futura
bobbin thread is too high pressure or too low pressure on teh top adjustment!
remove bobbin and turn tension screw about 1/8turn left (anticlockwise) check if still grabbing, if so - top thread turn about 1/4 turn (at embroidery ir should do automatically, but sometimes need kick...).
check if it is still grabbing on the bottom, do it grab during straight? zigzag? double zigzag? if do not - setting on the pattern need to be look at. if it tangle as well on these three - need definitely servicing...
follow manual how to adjust.
Jan 09, 2015 | Singer Futura Xl-400 All-In-One Sewing And...
Open helpline
Like the last pair of photos here? http://www.picturetrail.com/sfx/album/view/22521551 Clean the machine, rethread from scratch with the presser foot UP while you're threading the top of the machine, fetch up the bobbin thread, and hold the bobbin and top thread ends together behind the presser foot while you're starting each seam -- just for the first 2-3 stitches of each seam.
Jan 25, 2014 | Janome Sewing Machines
The bottom side of the item I am embroidering is showing all of the top thread color. I have adjusted the tension dial and bobbin tension. Any other suggestions?
Normally you will see the about 1/3 bobbin thread and about 2/3 of the top thread on the bottom side of the fabric. If you dont see any of the bobbin thread on the back side turn the upper tension (needle tension) to a larger number.
Good Luck,
Doug
Jun 28, 2010 | Janome 200E Computerized Sewing Machine
Hi, my thread gets caught and pulls the materal into the foot and i can not sew due to the jamming and the thread get all bunched up by the bobbin
I had similar problems when I first started sewing. Try adjusting the tension in your thread - less tension for lighter fabrics, more tension for heavier fabrics. This will stop the needle from pulling the threads in the fabric.
As for the thread getting bunched up in the bobbin - this is most likely because your bobbin is the wrong size for the machine, or that you did not thread the bobbin properly. Try re-threading, this time making sure you pull the thread into the bobbin container tightly. This should stop the bobbin from jumping around the container and spitting thread.
Feb 27, 2010 | Brother Sewing Machines
My top thread gets caught in the bobbin. When I
Here are a couple of solutions to try.
* Try re-threading your machine. It may be threaded wrong.
* Raise your feed dogs
If your machine has this feature.
* When you start to sew a seam, hold the upper and bobbin thread tails back and out of the way as you sew your first couple of stitches. This will prevent them from getting caught in your machine.
I hope this helps.
Dec 29, 2009 | Sewing Machines
Singer ce350 bobbin thread on top
Be sure when you are threading the top thread that you ALWAYS RAISE the presser foot. This releases the tension disk and allows the thread to seat properly.
Have you gone back and re-tested on your test fabric? Does it work okay on the test fabric? If so, then there's a suspicion that it has something to do with the fabric, needle & thread of your project. Is your project fabric very dense, heavy... Are you using a stabilizer? A hoop--is it taut, not stretched? Make sure the fabric is not trampolining. Could be an incompatibility. The needle & thread may be having difficulty piercing the fabric. Try a different weight needle, perhaps a microtex or embroidery needle.
Mar 23, 2017 | Singer CE-100 Futura Computerized Sewing...
Janome Sew Mini bobbin problem
Hi, Usually wrap-ups in the bobbin area are caused by the lack of tension on the top thread. The slack arm ( shinny lever that moves up and down while sewing) has to pull the loop around the bobbin case and it does so only if the tension on the top thread is sufficient to keep it from pulling more thread of the spool.
Try this: Thread the top of the machine all the way just short of the needle eye. When the presser foot is up the thread should pull through easily. Now drop the presser foot (this closes the tension discs) and pull the tread while adjusting the upper tension control.
If everything is working correctly you should feel the drag on the thread change if not something is keeping the discs from closing.
Most Janomes aren't too difficult to remove the nose cover, usually just one screw and you can get a look at the thread path. Look for thread wrapped around the mechanism.
Sorry, no easy answer but I hope this helps.
Mar 16, 2017 | Janome Sewing Machines
Sewing Machines Logo
332 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
