Question about HP Pavilion dv4165cl Notebook
I've HP4165cl and it freezes from time to time, it looks like there is some loose connection somewhere within laptop. If I tap on right side of trackap (below keyboard) it works and once again freezes. Is there anything under right side wristpad which does something like this ? TIA -MJ
    Scholar:
  • 83 Answers
Try replacing the disk drive and reinstall a new OS and my assumption would be that ur old hard disk is ailing....
Posted on Sep 02, 2010
Repair white blank screen at start up on hp 2311x
From what I have read, it seems to be a loose connection inside the monitor somewhere. Lots of people have had temporary success with either tapping the sides (and top) or by turning the monitor upside down. If you want to, you could tear it apart and look for a loose connection.
Jul 14, 2014 | HP 2311X 23 in. LED Monitor 2843276
Washing machine not filling
yes your problem is up the line somewhere. you have to have water coming out of the fill line when the washing machine is unhooked.
you will have to locate the valve to turn on the water.
good luck
Jul 05, 2012 | Russell Hobbs RH1042 Frontload Washing...
EDTV RCR
Hello
The fault is due to loose contact in the connecting wires from its T'Con board to display panel. If you are aware in electronics, unplug all the flat cables thaconnected with T'Con board to display panel, Just unplug it, and replug in. If any loose contact in between the contacts of the wire strip's connecter end, will get right by this. But you must be vary causious not to damage the wires.
This is the picture of the tCon board to your set. It will be normally within an shelded condition. Just see, the connectors that hold strip wires. Juslt look release the clips that holds each connector wire end. You can see it on either side of each connectors. Just pull the clip up to release the strip wires. Pulling up, will loosen the connectior's hold to wire. Take each of the fully out, one at a time, and replug it. Switch ON and check each time after repluging each connection wire. In this way, you will get an idea about the loosed connection too.
Dec 14, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My Hannspree SN12E23BUP212 notebook is great, but sometimes the cursor goes nuts and when I'm trying to type something, it will just go somewhere else on the page. Help!
Most times when that happens you've touched the touchpad unintentionally when you're typing and, as a result, the touchpad treat the touch as a tap and the cursor get repositioned. I'd check under Windows Control Panel (assuming that's your OS) and Mouse and look for something like tap control - you can adjust a tap to be a heavier tap instead of a really light one and that'll likely fix the annoyance.
Sep 06, 2011 | Hannspree HannsBook SN12E23BUP212 Notebook
How can i turn on my wireless connection
On the top right side above the keyboard you should see the Quick launch buttons. Press the button that looks like a satellite dish. When the wireless connection is enabled it glows like a yellowish green.
Hope this helped!
May 18, 2011 | MSI M670 Notebook
Possible Freeze Plug
that would be a freeze plug. You will just have to get a new one, get a hammer and punch and tap the new one in
Feb 02, 2009 | 2000 Cadillac DeVille
Screen shakes and it freezes
i suspect a possible loose contact between the ribbon connecting the motherboard module to the LCD display module. if you can open up the laptop, check if the both the ends are snug and tight.
Mar 19, 2008 | IBM ThinkPad T42 Notebook
Freezes when jostled
sounds like a connection to the hard drive may be loose.
No matter what it is it will have to be taken apart to fix.
Nov 19, 2007 | HP Pavilion dv4000 Notebook
HP Pavilion dv4165cl Notebook Logo
22 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
