Question about Frigidaire 30" Self-Cleaning Slide-In Gas Range - White
Door locked and can't release. - Frigidaire 30" Self-Cleaning Slide-In Gas Range - White
  • Frigidaire Master
  • 43,501 Answers
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
The other option you have is to call the customer service number of the manufacturer... they often have codes that they do not publish...
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Posted on Aug 23, 2010
Fuel door won't open on a 2008 g8 pontiac
Fuel Fill Door Description and Operation
The fuel door latch actuator shares the circuit with the driver door latch assembly. The body control module (BCM), upon receipt of a lock switch lock or unlock signal, will switch the appropriate door lock actuator, as well as a fuel filler door release actuator control circuits to battery positive voltage. The opposing side of the door lock and fuel filler door release actuators is connected to ground by the I/P fuse block through the other door lock actuator control circuit and the doors, along with the fuel filler door release, will lock or unlock as commanded.
Circuit/System Testing
  1. Ignition OFF, disconnect the harness connector at the fuel door release actuator.
  2. Test for less than 1 ohm between the control circuit terminal 1 and ground.
  3. ?‡'
    If greater than the specified range, test the control circuit for a short to voltage or an open/high resistance.
  4. Test for less than 1 ohm between the control circuit terminal 2 and ground.
  5. ?‡'
  6. Connect a test lamp between the control circuit terminal 1 and control circuit terminal 2.
  7. Ignition ON, command the doors to LOCK and UNLOCK by using the door lock switch. The test lamp should illuminate while commanding the LOCK and UNLOCK states.
  8. ?‡'
    If the test lamp remains OFF during either command, test either control circuit for a short to ground.
  9. If all circuits test normal, test or replace the fuel door release actuator.
Component Testing
  2. Install a 15A fused jumper wire between the control terminal 1 and 12V. Momentarily install a jumper wire between the control terminal 2 and ground. The fuel door release actuator should perform the LOCK/UNLOCK function.
  3. ?‡'
    If the function does not perform as specified, replace the fuel door release actuator.
  4. Reverse the jumper wires. The fuel door release actuator should perform the UNLOCK/LOCK function.
Remove the rear compartment side trim (right) panel. Refer to
Rear Compartment Side Trim Panel Replacement .
Apr 06, 2016 | Pontiac Cars & Trucks
Door lock is engaged but door is open. panel says door locked. how do I release lock so door will close?
Hello Maureen, thank you for your post!
I see that your Frigidaire range is currently displaying door lock engaged except the door is open. The best way to release the door lock is to hold down the cancel button for at least ten seconds. If that does not help release the door lock I would suggest disconnecting power from your range for at least ten minutes. We hope that this information is helpful towards the repair of your range. -Matt
Feb 01, 2016 | Frigidaire Kitchen Ranges
My door won't close at all bounces back a bad lock on a ford ka? i wil buy another lock but do i need to get the key of the new lock or i an stay with the one i have?
door lock latch is closed you need to release the locking mechanism at the side of door with screwdriver while holding door handle open to release the latch then door lock will operate as normal
Jan 20, 2014 | Ford Ka Cars & Trucks
2007 ford freestar lift gate will not open even though I can hear the lock disengaging. Still feels locked. It is manual open, but cannot lift it, feels locked.
Try pressing the door closed while unlocking and releasing. If the door previously has been slammed shut hard or just due to general wear and tear the latching mechanism can become slightly relocated. This means that when the door closes the door is pressing tighter than normal against the door seal. The compressed door seal will put a lot of strain on the latch mechanism and can hinder its retraction when released. By pressing the door closed and therefore removing the strain due to the door seal you might allow the release mechanism enough freedom of movement to retract when released. If having got the door open then immediately adjust/relocate and lubricate the lock/release mechanism such that you achieve a happy medium of the door closing with a weatherproof seal but not so tightly as to put the latch under a lot of strain.
Aug 19, 2011 | 2007 Ford Freestar Limited Minivan
2002 Hyundai Elantra Drivers dorr Lock Jammed not unlocking properly. Lock lever on inside and key on outside are stuck and door move bery much and will not unlock car. Originally cable in door to release...
Same thing happened with mine. It turned out that the power door lock motor went out. Since the handle or the switch can unlock the driver's door, both of these mechanisms are connected. When the door lock motor goes out it freezes in whatever position, it was last engaged.
Nov 06, 2010 | Hyundai Motor 2002 Elantra
Where is the button to release the gas door for a 1996 jetta gls
There is no button release for your gas door, if you lock the car doors the gas door will lock to, unlock car doors gas door locks.
If the gas door stays locked then the locking linkage might be defective.
Sep 08, 2010 | 1996 Volkswagen Jetta
Cannot unlock door lock
Can't help on the lock release, but will say that OFTEN the detergent will not dump if it is filled too much. Leave a little space.
Dec 26, 2009 | GE Nautilus 24" Built-in Dishwasher
Door is locked and won't release
Press and hold the start button to release the door (if the door locked light is lit).
Dec 09, 2009 | Maytag Neptune MAH6500A Front Load Washer
Doors lock without pressing button. wiring
1.doors will lock when you start engine,(autolock)
2.are you using service key in trunk lock? it wont go in all the way,(try another key)
3.have you tried turning key fully to the left then button release/turn key fully to right then button release,(valet lock)
Still have a problem?please feel free.....
car supplied with 3x keys and 2x remotes when new...
Nov 20, 2009 | 2000 Volkswagen Beetle
The lock on self cleaning oven door will not release
Once the cleaning button on the oven is pressed it take 15 minutes for the uven door to unlock.
Jul 30, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire 30" Self-Cleaning Slide-In Gas Range - White Logo
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
