Question about Faberware FSW343 Electric Wok
Powercord gets too hot only at one spot which is really close to where it plugs into the wall
    Problem Solver:
  • 11 Answers
Try a different outlet. If that doesn't fix it, cut off the plug and install another one you get from the hardware store. Pay attention to whether the prongs are different or the same size. If they're different be sure and buy a polarized plug. Then, before you cut off the old plug look on the cord for a ribbed side to see which prong (narrow or wide) the ribbed side of the cord goes to. That way you will keep the same polarity on the new plug. If the prongs are the same width on the old plug it won't matter.
Posted on Sep 24, 2010
Where is the fuse located at on acer computer
There is none.
If it is a Desktop Computer (case) you will need a new power supply or a different one to test if that is really the problem.
on a laptop, try holding the power button for ~40secs with all power diconnected (no battery and no powercord).
then re-plug the powercord to see if it will turn on. Try a different powercord if it still wont turn on, or have it tested at an electronics store.
Aug 30, 2014 | Acer Aspire Computers & Internet
I have a magic chef microwave that heats well but when the door is closed it hums and get really hot on top while not in use. Eventually it will stop working all together until it cools down then I can...
This one actually sounds like the unit is cooking when the door is closed without blowing the fuse as it is supposed to do. Unplug it from the wall and let it cool down, which it probably already is. Put a cup of cold water in it, close the door and plug it in for one minute. Unplug it from the wall and check the water. Did it heat up? I'd bet that it heated the water up. Sometimes the cook relay sticks closed and it stays in cook mode. This condition is supposed to blow the fuse but really rarely it doesn't. I've only seen this happen 3 or 4 times out of about 14,000 units I have looked at in my career.
It would need a new control PCB and new door switches and probably a new magnetron.
Oct 11, 2013 | Magic Chef Microwave Ovens
Freezer not working, fridge is fine.
That seem to me like it could bea simple cleaning. Dust and junk gets into the condenser. Blow that ****** out and party on. I have your models service manual on my foggy blog
Mar 05, 2012 | GE GSS25LGM Side by Side Refrigerator
How to change freezeout plug on fire wall side of 1994 olds cutlass
Tough spot to get at ,they make an expandable plug that you may get to work,rubber with a steel washer .
Tightens with an open end wrench or an allen head,
Never get a metal plug in from there,problem is.. The rest of the plugs are most likely to follow.
Really should pull the motor and change 'em all. there are 2 behind the flywheel also.
Oct 10, 2011 | 1994 Oldsmobile Cutlass Supreme
Went on vacation and left the PS3 powercord unplugged. Now it doesn't work, could it be the cable?
Hey there, a couple of things to verify here to get your ps3 back up and running. Do not worry about leaving your ps3 the whole week with the powercord unplugged, this is OK and should't have affected anything negatively.
1) Make sure that the powercord is well plugged on both ends: ps3 AND in the wall.
2) Make sure that the SWITCH is turned on (in the back of the ps3, there is also a POWER switch I/O). Turn it on by pushing on the I.
3) If it's still unpowered, try plugging the ps3 itself somewhere else in the house (to make sure it's not the power outlet)
Jun 23, 2011 | Sony Playstation 3 (PS3) Console
Oven heating really slow
yes it sounds as if there is a "HOT-SPOT" on the element which will look like a dis colored spot and will be either bubbled up or have pock marks where its burning thru and can no longer pass sufficient current to heat the element fully
Apr 04, 2010 | Maytag 30 in. Electric Single Wall Oven...
Error code 71
That is a laser alignment issue...
You might get lucky:
1. unplug printer power cord from wall or powerstrip.
2. Turn ON printer (without the powercord plugged in).
3. Plug in powercord and turn ON printer again.
If error code 71 remains .... repeat above steps.... but I would advise replacing ($180 ~ $240) instead of repairing ($150)...
Hope this helps!
Sep 09, 2009 | Brother IntelliFAX 4100 Laser Fax
My panosonic lcd tv has devepoped multiple bright colorspots
This is caused by magnetic fields. Either the speakers of tv is faulty or demagnatziser not working. Switch of tv and remove powercord from wallsockets. Leave for about 10 hours and plug in powercord and switch on. if demagnatiszr is working the blue will be gone. if not have youre tv demagnetized
If hometheatre or radio speakers are closer than ½ meter this could also generate coulouration of screen. move speakers further away. If tv is on and and being moved your static electricity can also cause this. So switch of if if you move your tv.
Aug 09, 2009 | Televison & Video
Black strip on front of wall between frig and freezer really hot
not supposed to be hot to touch, try pulling out refrig and vaccuming the coils, your probably FULL of dust and debris, also remove the kickplate from front and clean under there as well
Sep 29, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Faberware FSW343 Electric Wok Logo
184 people viewed this question
Top Faberware Kitchen Appliances - Others Experts
ashburton
Jerry Greenberg
Jerry Greenberg
Tom Chichester
Are you a Faberware Kitchen Appliances - Other Expert? Answer questions, earn points and help others
