Question about Kitchen Ranges
I have a GE iron thats about 30 or 40years old i think.No steam iron its dry iron.It works I want to change the electrail cord that you plugs in. Cat.139F23 Watts1000 Volts115 made in USA.I bought at a second hand store ,I pluged it in it worked it just needs a new cord . Can they be changed? I use it for Quilting.
  • Laura F Simpson Aug 22, 2010
    Thank you very.I have some abulity to do some things,but I dont think i can do this one. I wounder how much it would cost? My husband died last year 2009 so money is tight. Ya,
    it is back before they made steam irons ,I am almost 62 in jan.2011. It works good just dont like the cord on it. I use it for Quilting for stuff that you dont want steam holes on the ironed pieced.
    Yes it was . I will have to find someone to fix it for me.I cant fix this one. Thanks very much.
    Genius:
  • 1,340 Answers
It can be changed.Are you looking to self-repair?I assume it is frayed or just doesn't look safe?If you are I have a couple suggestions.The wires in the new cord need to be at least as thick,if not thicker as the old wire.Wire thickness is measured in guage.The lower the number,the thicker it is.Example:4 guage is actually 1/4 inch thick while 8 guage is 1/inch thick.1/4 inch is thicker than 1/8 inch.If you can take it apart,that would be the best way to replace,straight through to the terminal.If you can't,you may want to have someone do it for you.
Good luck! Greg That's almost antique now!lol
Posted on Aug 22, 2010
  • Greg McCarthy Aug 22, 2010
    If you call a couple small appliance repair places someone should give you a good estimate.I can't see as where it would be very expensive.1 hour labor maybe less and a piece of wire.Greg
When has my iron stopped steaming and heating up?
depends on how old it is, try to rinse it with a water and vinegar solution, this might help
Apr 09, 2015 | Euro Cuisine Ootoo Iron, 1500 Watt Steam...
My iron is getting hot but giving no steam can anyone advise
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Jan 31, 2013 | Breville Vin227 Extreme Steam Steam...
How do you turn on a rival steam wave iron
The Manual for the Rival IR699 and IR999 Steam Wave Iron may be downloaded in PDF from the following link:
http://www.rivalproducts.com/manuals/MANUALS/IR999_43_64403016.PDF
STEAM IRONING
1. Fill the Water Reservoir.
2. Plug the cord into a 120-Volt AC outlet.
3. Select the fabric setting you desire using the dial. Allow the iron to
heat for 2 minutes. While the iron is heating, make sure it is sitting on
its heel rest on a stable, protected surface.
4. Turn the Steam Selector to the appropriate setting. Begin Ironing.
IMPORTANT: When not ironing, always set the Variable Steam Selector
to (Dry) and the Fabric Select Dial to OFF.
Jun 19, 2012 | Rival Steam Wave Iron
I have a B&D 2030 steam iron which I really like, but recently it isn't always turning on when plugged in. I think there may be a short in the cord somewhere, possibly the plug?? It seems to work...
Likely the wire inside the cord is broken from lots of use. You can usually tell where by turning the iron on while plugged in and bending the cord. You will hear a spark when you bend the spot with the break. It isn't very difficult to replace the cord with a new one.
May 31, 2011 | Black & Decker D2030 Iron
Sunbeam Steam & Dry Iron Model # 4214
This is an old model, dont think you will be able to find it new. Try ebay or maybe craigslist. Ebay would be your best bet though.
Jul 18, 2010 | Sunbeam 4214 Iron
My swan steam generator iron s15040 is brand new and i cannot get steam ,and i have followed the instructions ..please help before i have to return it ..does any one else have the same problem and if so...
Hi Im having the same problem but mine is 6mths old..I think its the cartridge that needs replacing as everything else works but the steam..Gonna order one today if that doesnt work I shall return it..They reckon to change it every 3/6/12 mths according to being in hard/medium/soft water area.I took the cartridge out one day and let it dry out it worked for 2 days then packed in on me again.
Nov 10, 2009 | Irons
SHARK STEAM STATION G6200 SUDDENLY STOPPED WORKING.
take it back to the store and tell them what has happend the only thing i can think of is that one of the wires has come loose within the cable
Apr 21, 2009 | Euro-Pro Shark GI490 Iron
CALCIUM BUILDUP COMING OUT OF THE STEAM HOLES...
Hi, the other two responders were correct, use clear or filtered drinking water only. Also, use your iron until it runs dry and use burst of steam or self cleaning function to clear out the last bits of water, being sure it is empty before putting it away. Several cycles of this using and purging process will clean the iron without chemicals. Standing water that evaporates is just like a tea kettle with water left in it, all the white mineral deposits settle to the bottom, and the water dissolves the mineral salts, and when dissimilar metals are wet (think of a an old flashlight battery and the corrosion that occurs if left in storage.
Dec 04, 2007 | Rowenta DX6700 Iron
Kitchen Ranges Logo
93 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
