I put my clothes in and select what eversize load, it doesn't really matter because it fills and continues to fill and the water will overflow onto the ground. It does not stop until I stop it.
    Champion:
  • 245 Answers
You have a bad water level select switch. Replace it problem solved. Good lick, rate me if I am correct!
Posted on Aug 22, 2010
Kenmore Washer only leaking from one area
Ive never worked on a Kenmore but it may just be the overflow outlet. All washing machines have an overflow which will dump water out from the top of the tub if it overfills but sometimes on high fill water level, clothes can splash around and cause a "wave" of water to splash out over the overflow outlet. Check to see if the leak only occurs when you have selected high level fill.
Nov 23, 2017 | Kenmore Energy Star 44092 Front Load...
I HAVE A GE WASHER THAT FILLS WITH WATER AND OVERFLOWS. DOESN'T MATTER WHAT SIZE LOAD, IT CONTINUES TO FILL WITH WATER AND OVERFLOWS. IT STOPS WHEN I HIT THE STOP/PAUSE BUTTON.
There is a pressure sensor that needs to be looked into. USUALLY, there is a chamber, on the outside of the washer tub, and out of the top of it is a small plastic hose. This hose runs up to an electrical switch.
Too much soap, over time, can plug up this system, so the machine has no idea how much water is going in...and keeps filling..... Sometimes the hose comes loose, but this makes a fairly immediate water leak, so I suspect something is plugged.
Doc
Jul 06, 2011 | General Electric WHDRE526EWW Top Load...
I put in a load. The machine filled up but did not stop filling. The dial did not proceede to next step, it stayed at the 10. Overflowing EVERYWHERE. When we moved the dial manually to spin, it drained...
your fill switch is either bad or "gllitched" and the timer cannot move until this switch senses the right amount of water for the load unless its an electronically sensed water/load capacity filled machine,when it starts,the water fills the unit and the pressure switch shuts the water fill off when at selected water level and powers the timer to continue the wash cycle,it works off a "bellows" on air pressure to change a switch by air pressure to operate the machine when full of water
Dec 27, 2010 | Kenmore 22622 Top Load Washer
The water continued to fill the drum and overflowed onto the floor
ONE OF TWO THINGS----YOUR WATER VALVE IS STUCK OPEN OR THE LOAD SELECTOR (SMALL MEDIUM LARGE LOAD) IS NOT WORKING,SO IT DON'T KNOW IF IT IS FULL OR NOT.
Oct 28, 2009 | Washing Machines
Frigidaire Washer/Dryer flse60rgs1 Starts filling but won't stop no matter what setting its put on it just fills the tub, and ultimately overflows
The problem is most likely the float switch or it could be a stuck fill valve. If it is the fill valve, it will stop filling if you unplug the machine.
You can find the parts and diagrams at partselect.com
If you need more help, post a comment.
Thanks,
Tim
May 14, 2009 | Kenmore 22642 Top Load Washer
Bucket continues to fill with water and does not stop.
As earlier described, regardless of the load size selected, the bucket continues to fill up with water to the point where it overflows into the machine frame and subsequently onto the floor. The main suspect was therefore the load selector switch, so I unplugged the machine, removed the screws holding the control panel in place, and checked behind the load selector switch to see if any wires had come loose. I noticed that all the wires were in place but a plastic tube had become dislodged from a nipple attached to the switch. Assuming this to be some sort of a vacuum tube that was used to shut off the water when it reached the appropriate level, I re-attached it and tried the machine again. Eureka, it worked.
Dec 05, 2008 | Whirlpool Washing Machines
Whirlpool ultimate II water level problem
does it still fill when you unplug? if it does then the fill valve is no good.if it turns off the check your hose going to pressure switch.will be a small clear hose going from tub to your pressure switch.
Nov 14, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
