Question about Electric Mobility 3 Wheel Motorized Electric Wheelchair Power Scooter
I have a Raskel and put 2 new batteries on it but the motor won't kick in when you push on the pedal to make it go. Thank You
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 347 Answers
Hi,im disabled myself,thats why im here,please rate me as in thumbs up 1 to 4.visit:www.alldatasheet.com & download the troubleshooter for your product as PDF File.get if you already havent on your comp,an Adobe Reader for you to read the troubleshooter.hope this was of help,colin.
Posted on Aug 23, 2010
Why won't my 1984 Oldsmobile Delta 88 start?
if throttle blades dont move look on side of carb were kick down cable was replaced possible throttle and kick down popped off or damaged
May 14, 2014 | Oldsmobile Delta 88 Cars & Trucks
Pedal hard to push in has new cluch
the cables is #1 top failure. and can damage car, or it can stick and cause a wreck
http://www.fixkick.com/tranny/clutch/clutch-on-kick.html
never run old cables here.
they fail inside, big time, where you will never see,
also if you keep it like this, the spins on the top of the clutch pedal
strip, (good luck finding that)
or fire wall cracks at the mount for cable.
or the pedal welds snap.
seen 100's on all tracker/kick forums.
Apr 02, 2014 | 1992 Geo Tracker
What i can do next ? i have put new tps. and new throttle motor and codes still shows throttle stuck open and forced idle the explorer 04 still won't accelerates
The problem never had anything to do with
the TPS Sensor,the TACM throttle body motor
When you don't own & work from Factory Diagnostic
Manuals, you don't know the system your working on
or learn anything
Your problem is the ignition coils or modules
I'm all too familiar with all the throttle body codes
Non of the codes have anything to do with the
factory reference manuals either,they help but
stop short of telling you the PCM gets spikes in
what is called a Quizzer which is inside the PCM
but a separate section dedicated to processing
the throttle plate position,control of the motor
& your pushing on the gas pedal & the input from
that or the ETC which is the gas pedal electronic
throttle control
The bad ignition coils are why most repair shops
& dealers can't fix a ford.
Feb 22, 2013 | Cars & Trucks
72cc pitbike kick start won't come back up after you kick it down ...?
mate whats happening is there is no recompression inside the engine pushing the gear to return id say you have done the gears in it and it would cost more to replace them than to replace the engine
Jan 28, 2013 | Pit Cycling
Car won't start. All batteries are new.
I unfortunately don't have a solution, but I'm having the exact same problem with my 2010 Cube.
Oct 08, 2012 | 2010 Nissan Cube
Bobbin won't wind - foot pedal working but bobbin won't turn ES2020 New *unused just stored since purchase from new*
Your new but stored machine has sat long enough that any oils from the factory have become gummy and or dried out. I would take it in and have the pros service it. But for now you might try....
Turning the hand wheel by hand while you press on the pedal. This MAY free up the machine enough for the motor to take over.
Jul 21, 2012 | Sewing Machines
When I push the arrow up to make my heater kick on a 1+2 pops up above the temperature number and it won't kick on.
sounds like your touchscreen is messing up and your adjusting the T-factor.. try pushing the reset button on your thurmastat.
Feb 26, 2012 | Heating & Cooling
Peg pergo gaucho jeep won't go when push petal, bought new battery but not battery
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in, then check for power at the foot pedal, then at the shifter, then at the motors
Oct 07, 2011 | Peg Perego Gaucho Rock'in
John deer push pull tractor won,t work.
If you have a clicking problem, I would check the wiring on the foot pedal. something is not connected right, which is making the fuse click.
You can contact J&L at this link or call there toll free number. http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-switches-and-shifters.html.
They have switches and other parts for these peg perego gators, but I would talk to them to make sure.
Apr 08, 2009 | Peg Perego John Deere Gator HPX Ride on...
Electric Mobility 3 Wheel Motorized Electric Wheelchair Power Scooter Logo
225 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
