Question about Whirlwind FH-778 Air Conditioner
How to add freon to central air conditioner - Whirlwind FH-778 Air Conditioner
  • 382 Answers
Dear sir
if you have some knowledge about air conditioner system then first connect hose with suction side of aircon pipe conector(valve) with Gage and second hose with cylinder and GAGE .during of this you must remember don,t forget to open valve before START this job then make your ac unit vacuum it should be 18-20 micron after vacuum fill freon (approxmatily 60-65 pci)
and check your aircon system,s evaporator all pipe has been cold not and any pipe is getting ice on it .if its reach pressure 60-65 psi AND YOUR AIRCON BLOWING COLD AIR then it,s good the close by cup nut on the connecting point and remove hose from connector and disconnect Gage from system .
(but please don,t do if you have not proper knowledge it can be dangour)
warning: if you don,t have knowledge to do this please don,t try
thank you
hope answer the question
Posted on Sep 25, 2010
My unit sends in plain room temperature air what do i do?
http://www.doityourself.com/stry/how-to-add-freon-to-your-central-air-conditioner#b
Aug 02, 2014 | Ruud Central System Air Conditioner
How to add freon in a centralized air conditioning unit
The compressor needs to be running.Also you need freon charging guages and a pressure temp chart to tell how much you need to add.
If your not sure of anything i said here have a service person do this.You take a risk of damaging the unit and yourself.
Nov 21, 2011 | Whirlwind FH-778 Air Conditioner
I have central air and I was wondering how do you put freon in it because its not blowing out cool air
Is the compressor starting? On the outdoor unit you will see a large copper pipe and a small copper pipe. Is the larger of the two cold to the touch? wet? Just because a central air system is not blowing cool air does not mean it needs freon. If you have clogged filters it cannot do an air exchange. So, I would recommend checking the easiest things first before adding Freon.Most people make the mistake of adding Freon and overcharge their system. In a low load situation you can slug the compressor with liquid and your system is ruined. If you do have to add Freon it indicates that you have a leak. An AC System is a closed system and if it is working properly you should not have to add Freon.
Aug 03, 2011 | Whirlwind FH-778 Air Conditioner
That needs to be done by a professional that has the proper equipment and knows how to do it with out getting hurt...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Jul 18, 2010 | Whirlwind FH-778 Air Conditioner
Why the central air conditioner unit run out of freon at all times
it has a leak....freon system is a closed system, and should never run out of freon...leaks are sometimes hard to find.
Jan 25, 2010 | Whirlwind FH-778 Air Conditioner
Compressure and fan not coming on, contactors pulled in from 24v .light blinks 3 times lps hps are jumped add freon still not working.
Sounds like your breaker is tripping for your outside unit. Compresser could be grounded out or a breaker problem.
Oct 08, 2009 | Haier HC48C1VAR Central Air Conditioner
How do I add freon to my central air conditioner
Adding refrigerant (Freon is Dupont's name for refrigerant) requires some special tools and gauges. More important than that is your system should not loose refrigerant. It you are low that means you have a leak in the system. It should be found and repaired before new refrigerant is added. A qualified repair technician should be called.
Sincerely,
Terry aka Funny Plumber
Jun 23, 2009 | Whirlwind FH-778 Air Conditioner
Adding freon to my central air
Well duprees, first you got to have the right instrumentation for charge freon to a a/c system, now, the charge line is the thick line, wich it means the suction line, the colder line, or the most robust line on the compressor.
Then, the system uses freon 22, the right charge, with the system on and the compressor running is 68.5 to 70 psi.
This should give to you about 40 degrees(farenheit) at the evaporator, the panel that gets cold in the system.
This pressure should be at the low side, meaning thicker line in the compressor unit.
Hope this help you......
Good luck.......
Aug 11, 2008 | Whirlwind FH-778 Air Conditioner
Fair price to fix central air conditioner leak & refill with freon
I have heard that there is a spray you can use that will not damage your system and seals the leak when it comes in contact with oxygen
Apr 18, 2008 | Heating & Cooling
Heating & Cooling Logo
212 people viewed this question
Top Whirlwind Heating & Cooling Experts
Dennis Boxerman
Bill Long
Dan Webster
Dan Webster
Are you a Whirlwind Heating and Cooling Expert? Answer questions, earn points and help others
