Question about Fedders Q Chassis A6Q10F2A Air Conditioner
Is the Fedders Service # A3X05F2B-B a 110 or a 220?
How do i fix a leaky air conditioner? it is a fedders A3X05F2B INstalled in the wall and it is leaking in to my house.
It is the drain line clogged that should normally go outside. The best way to clean a window unit is take it out of window. Take off the cover and using a waterhose, Clean the evaporator and condensor. Make sure drain line drains to the back of the unit. from inside to outside. While you are there if the fan motor has oilers on it then oil bearings. Install cover and put back in the window and you should be good to go. Hope this helps.
Jul 26, 2011 | Heating & Cooling
Living in Burlinjgton Ontario Canada. Looking for owners manual. How can I get one?
Henry, unfortunately Fedders as you knew them is now out of business, A company by the name or Airwell bought parts and manufacturing and it's now call Airwell-Fedders. You particular model is no longer available. However, if you contact Airwell-Fedders Customer Service 866-829-2440 or email them customerservice@airwell-fedders.com they should be able to help you with the manual.
Good luck. I hope this helped you.
May 24, 2011 | Fedders SFPEB08F2B Air Conditioner
Control board deffective/where i can find service center
dear sir '
please use blow link for know your nearest fedders dealer :
www.fedders.com/contactus.asp
hope answer the question
thank you
please vote!
Sep 30, 2010 | Fedders A6Y18F7BCOM Air Conditioner
Replace fan motor overheating fan is fyk-62s helix motor ltd
my ac motor no work at all is a FYK-62-S ,how much cost to buy a new fan motor?
Jul 30, 2010 | Fedders X Chassis A3X05F2B Air Conditioner
Doped and dosent work right
mcdevito75 here, Fan motor could be bad. Check with an A/C repair shop in your area., Check online for your area A/C shops, or the yellow pages.
Jun 23, 2010 | Fedders X Chassis A3X05F2B Air Conditioner
Fan works for about ten minutes then begins to slow down
Try spraying some WD-40 or similar on the motor shaft. There is probably some buildup of contaminents gumming up the bearings.
If I knew what country you lived in, I might be able to tell you where you can buy the motor if you need it.
May 29, 2008 | Fedders X Chassis A3X05F2B Air Conditioner
Fedders window air
Make sure the evaporator and condenser are clean. If so, is the blower motor still running when the compressor shuts off?
Aug 23, 2007 | Fedders X Chassis A3X05F2B Air Conditioner
"high" vs "low" dual control
could be problem with either switch of fan. try continuity across both legs of the switch then try continuity across the fan windings.
May 25, 2007 | Fedders X Chassis A3X05F2B Air Conditioner
Fedders Q Chassis A6Q10F2A Air Conditioner Logo
90 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
