Question about Dell XPS 200 PC Desktop
PC is very loud, thought it was the hard drive purchased another hard drive and it is still loud. Has been this way for quite some time.
  • 526 Answers
The only other item that makes noise without physically doing anything, are the fans. You will have anywhere from 3 to 5 fans.
you can get long piece of paper and twirl it into a long tube and stick it where the fan spins. when the fan stops and the noise stops, you know which fan it is.
Check your cdrom, you might have a cd in there which causes the drive to spin, take it and see if that makes a difference.
thanks
Posted on Aug 22, 2010
My Dell 531S will not boot past the BIOS (Dell logo) screen. At first I thought it was the hard drive, since it wasn't recognizing anything connected to SATA port 1. Since then I have purchased a new...
It seems like you have multiple problems:
1. DVD-ROM drive not accessing the disk
2. unable to "disable" the "floppy" drive in BIOS SETUP
3. not recognizing anything connected to SATA1 port
It's time to take your computer to a qualified technician, for professional trouble-shooting.
Is your DELL computer still under warranty? If so, exercise the warranty.
Or, maybe you should just remove the "new" disk-drive, the RAM, the DVD-drive, and then responsibly "recycle" the old computer, and purchase a brand-new system, repurposing the disk/RAM/DVD components.
Sep 01, 2010 | Dell Inspiron 531s Desktop Computer
Loud desktop computer hard drive
that is an indecator for bad HDD , keep backup from your data and expect the worst any time
Jan 20, 2010 | Dell Dimension 8200 PC Desktop
During power up, the pc quits working.Blue power light stays on but no power to hard drive or screen. Occasionally will get through power up and then quits working after 3-4 minutes. It's not the battery....
I'd remain focused on the batteries. You can't have a blue power light on, unless there is power to the drive, I say this because you do power up occasionally, albeit, for a short time. This should also rule out Operating Sytem failure. Not hard drive failure, however.
Its also not important that your power occures via battery or power cable. Search out all the batteries for your laptop, there might be several watch batteries, hidden away, that need to be replaced. They are there to keep the CMOS operational. If these batteries are in failure, your laptop will not function correctly. Battery powered or not. I believe it doubtfull about the connector, but if your sure the cable hasn't been kinked, thus the wire broken, preventing electrical current from arrive at the laptop - I say no faulty connector.
If you find the batteries, and think they are faulty. Replace them and maintain them (batteries) properly. The next step is to look at replacing power cable with a new cable purchased at your favorite computer outlet source.
If you've done both of these step, it got to be a faulty hard drive, consult local computer guy, or the manufacture of your laptop for easy replacement of the hard drive ( be prepared to pay for this service). Or if you feel you don't want to mess around with locating the batteries.
Aug 12, 2009 | Toshiba Satellite M35X-S111 Notebook
The hard drive is clicking loudly. It has been doin this for quite some time and my concern is that it is about to crash.
Usually the drive that does start to go bad will make a clicking sound or a loud whiring sound espically when it speeds up and slows down, and am fairly sure if you have s.m.a.r.t.s. enabled it will say to backup and replace the hd. if it is not enabled it is in the bios under a tab to enable and disable it. it is called s.m.a.r.t.s. status or hard drive status.(older laptops will most likely not have it) but yes, i would strongly recommend that you see about getting the hd replaced. you could even purchase a used hd from a local computer store or ebay to backup your current hard drive by using norton ghost or any other type of backup program or roxio backup. DARK
Jun 14, 2009 | Toshiba G15-AV501 Qosmio Notebook
Loud clicking
You're going to have to narrow it down by removing components. Start by removing the hard drive, if the clicking stops then you know that it's a component that needs or uses the operating system. If it stops then put the hard drive back and remove other components, CD drive, keyboard, etc... until you can either locate exactly where it's coming from or it stops. The CD drive could be the culprit, and removing the keyboard will expose some of the inner workings so you can hear it better and possibly find what it is. This isn't a simple fix, it will take a little effort, but I believe you will find the problem, this is the exact same way that I would do it if you were to bring the computer to my shop.
Jul 24, 2008 | Toshiba Satellite Pro 4600 Notebook
Installing old drive into new drive
If the problem is in the controller inside the case which in 99 percent of the times it is, This will certainly fix your problem. The MTBF(mean time between failure) of harddrives is 100,000 hours of operation. Also, any external case can be used that matches your hard drives specs...size, IDE, SATA ect...
Hope this helps you,
George
Jun 22, 2008 | Acomdata (HD160UE5-72) (HD160UE572) 160 GB...
Seagate Hard Drive issue
i want drive freeagent pro 500 gb firewere400,usb2.0, eSATA
May 13, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Emachine T3508 Loud Loud Loud
The only sure way to quiet it down is to replace the hard drives with newer ones, that you have selected based on their noise rating, AND to replace all the fans in the machine with fans that you have selected based on their noise rating. I did this for my self-built machine last year and never regretted spending the money on new drives and new fans. It's SO much quieter! ;)
Aug 04, 2007 | E-Machines eMachines Desktop PC
Dell XPS 200 PC Desktop Logo
260 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
