Question about Frigidaire Affinity ATF7000ES Front Load Washer
The machine showed error code E 20. It just shut off and made a beeping noise during a load we were washing. The lights work but the machine just buzzes when turned on.
Mine was too doing the same thing every now and then it would work depending if i changed the cycles around. I finnally pulled it out to where i could work on it. pulled off the back plate bottom was still partly full of water so tiped it on its side. undid the black hose going from the bottom of the drum. Undid the screw that tightens the clamp this is the fatter part of the black hose , inside this hose is a tube u can slip out it was right full, im gussing it was the filter. Put it back together and works fine now.
Posted on Nov 08, 2010
Keeps stopping during wash cycle
Hi Kathy,just read your posting.When the machine stops during the cycle does the machine beep and show an error code?Could you confirm the model number of your machine.Now if you have an LCD screen on your machine the fault code will appear in it but if you have no screen then the error code will appear as lights .These lights will be a row of 8 lights.Starting from the left to right which lights are on when the machine is beeping.Is it the 2nd and 4th or the 1st and 7th ---etc---?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Sep 18, 2010 | Fisher and Paykel GWL11 Top Load Washer
After washing heavy load mashine spin cycle not working
Hi just read your posting.Does your machine drain the water .When your machine stopped doing the spin cycle did it start to beep and show a series of lights as an error code?Or have you got the model with the LCD display and it showed an error code in letters?If you have the model with lights and your machine beeped the lights that did come on will be in a row of 8.Starting from left to right is it the 2nd and 5th lights on or the 4th and 8th lights---etc---- that are lit? Please reply and I can help you rectify this fault for you.
Jun 26, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel GWL10 begins to spin for about 15 to 20 seconds, just starts to pick up some speed, then machine beeps and shuts down. Seems like the water is draining. Any ideas? It has also been...
Yes it does seem like a control module fault.Bit concerned about the noise coming from the machine even thou it is not running.Please turn it off at the power point when not in use.Now if and when it faults again please reply back with error code as per 1st posting.
Jun 11, 2010 | Fisher and Paykel GWL11 Top Load Washer
Our Fisher Paykel washer shuts off during wash cycle and makes a beeping noise that intermittently comes and goes. There is also a small leak at the right front part of the washer.
Hi just read your posting.I need to know the model number of the machine.Also when it beeps do any lights light up or any error code appears on your display if you have that model.Please reply and I can help you rectify this problem.
Jun 03, 2010 | Fisher and Paykel GWL11 Top Load Washer
F-H code and beeping noise
error code which is serial communication error with motor contrl.
replaced M.Contl.brd but still have error.
Dec 03, 2007 | Kenmore Elite 45986 Front Load Washer
Frigidare front load washer error code
Could be "detergent drawer open". Try opening and closing the door shut. There is a magnet there which shows that the door is closed or open. Use front loading washing powders preferably.
Nov 29, 2007 | Washing Machines
My tricity bendix washing machine flashing and beeping end light
Hi, we had something similar happen just before christmas. Our machine seemed to finish a cycle and started making beeping noise with end light flashing. Then when I switched it back on to do another load it just started beeping with end light flashing no matter what cycle was selected. Engineer has been out and advised that it is a fault with the motherboard so has ordered another one. Hope this is of some help. Machine was tricity bendix aw1400w.
Dec 14, 2006 | Tricity Bendix AW1400W Front Load Washer
Washing Machines Logo
41 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
