Question about Cycling
What is the spark plug setting for a 1982 honda express moped
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,508 Answers
0.8mm
Posted on Aug 24, 2010
1982 Honda cb750c no spark on 3 & 4 cylinder
Hi, Richard and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead acid batteries.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting/leaking, spark plug cable connections loose check for spark leakage in the dark.
6. Faulty ignition coil or electronic control module.
7. Faulty CKP, CMP, or BAS sensor.
8. Faulty ignition switch.
9. Tilt sensor needs a reset.
10. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
cb750k 1977 no spark
How to diagnose no spark situation on motorcycle
Honda CB750F2 Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda CB750 CUSTOM 1982 Owner Manual
Jul 14, 2017 | Honda CB 750 Motorcycles
1982 honda nc50 has no brake, turn signils, horn ect
Hi, William for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Honda, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Wiring Diagrams Myrons Mopeds
http://vfrworld.com/forums/showthread.php/29448-No-Turn-Signals-No-Brake-Lights-amp-No-Horn-then-try-this-gt-gt-gt-gt-gt
No Horn No blinking turn signals in The Repair Shed Electrical Help Forum
http://www.jax184.com/projects/Express/Honda%20Shop%20Manual%20for%20NC50-NA50.pdf
http://www.vintagemopedsforsale.com/pdfs/honda-express-nc50-1978-owners-manual.pdf
Jun 23, 2016 | Honda Motorcycles
I have no spark on my 1969 Honda 90 passport moped any help??
I believe that this moped has a magnito and it is probably not functioning
Jun 09, 2014 | Cars & Trucks
My 1982 honda cr80 has no smark but has compression and its not the spark plug
check thd kill switch ! remove plug cap off the ht and see if you can feel a voltage as you kick over the engine ! it wont kill you but easy way to know if coil is working ! plug caps resister break down !
Mar 20, 2014 | 2005 Honda CRF 250 R
1982 Honda VF 750 S no spark front cylinders
Hi, Cort and the usual suspects are:
2. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead-acid batteries.
7. Faulty pulse coil.
8. Faulty CKP, CMP, or BAS sensor.
9. Faulty ignition switch.
10. Faulty run/off switch
11. Tilt sensor needs a reset.
12. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
no spark at front cylinders
Testing Honda Coils and CDI boxes
Honda 45 SABRE VF750S 1982 Shop Manual
https://www.partsfish.com/page/oem-parts-for-honda
http://mybikemanuals.com/honda/honda-vf-owners-manuals
May 26, 2012 | 1982 Honda VF 750 S
Hi, Daniel and the usual suspects are:
Honda VF750C Owner Manual Page 3
Sep 19, 2011 | 1982 Honda VF 750 S
1982 Honda XR 200 how to set the timing
Hi, Socalqueen07 for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere $15 you can download another one.
Timing Marks on the xr200r Help
Ignition timing for CDI Moped Wiki
DOWNLOAD XR200 XR200R XR 200 86 02 Service Repair Manual Download Manuals... $15
http://www.hondampe.com.au/docs/owning_a_honda/owners_manuals/motorcycles/XR200R-1989.pdf
Nov 21, 2010 | Honda Motorcycles
Looking for plug gap to a 1982 honda CBX Pro Link?
The correct spark plug gap is between .024 in and.028 in.
Sep 18, 2010 | 1982 Honda CBX
Honda vf 400 1982 spark plug gap
leave the plug as is she should be happy and sweet..
Oct 04, 2009 | 1982 Honda VF 400 F
Cycling Logo
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
