Question about Acer AL1916W 19" LCD Monitor
My computer as an acer screen. It was working but the other day the xcreen was off but the light on the right bottom is on
  • 11,361 Answers
Check for bad caps just like all the failed ACER as shown in my albums here:
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Posted on Aug 22, 2010
How to fix inverted screen
~Turn it over...~
Sorry, couldn't resist...
Seriously;
Press the Control, Alt, and Up Arrow buttons at the same time.
good day ... att.. charlie booker
May 24, 2014 | Acer Aspire One D150 Aod150 Kav10 Series...
No signal for acer monitor....black screen all the day....
Right click on desktop -> select screen resolution. Select identify. If external monitor is number 2, select monitor number 1 (laptops monitor) and from dropdown menu select "extend these displays" or "duplicate these displays". Select apply, picture should be shown on both screens.
May 02, 2014 | Acer Computers & Internet
Black screen with flashing horizontal lines
You may have a bad backlight screen power supply board and that is usually mounted in the bottom part of the screen right behind the front bezel. This supply's high voltage to the backlight tube that lights the screen. This is kind of like a small florescent tube that uses high voltage to fire the backlight and is a common failure point in laptop screens. Easy to fix, just pop the front bezel off and the module will be in the center bottom section of the screen. Do a YouTube search on how to disassemble your model's screen and the parts can be found on Ebay. Good luck.
Apr 14, 2017 | Compaq Computers & Internet
Good Morning. I wonder if anyone could help me solve my problem I have a Accer Aspire 5535 and its around 2yrs old on windows Vista. The screen stopped lighting up and then on Random days it would...
This could be one of two things, it is either the inverter (this generates high voltage to run the back light) or it could be the back light itself.
As you have suggested, it could just be a loose wire or cable.
Replacing the inverter is relatively straightforward as it is located at the bottom edge of the LCD screen behind the plastic case. The backlight is usually part of the LCD screen and you would usually be better replacing the screen entirely.
To get at either of these components to check cables/wires etc, you will need to disassemble the screen case of the laptop, this is fairly simple if you are comfortable with disassmbling laptops.
A brief overview of the screen replacement process is below, instructions 1-4 show how to remove the case to access the inverter and cables:
1. Power off your laptop. Turn the laptop upside down so that you can see the bottom side of the laptop's case.
2. Depress the battery release latch and lift the battery and laptop ac adapter out of the laptop. Flip the computer back over and open up the LCD screen to a 90 degree angle.
3. Pull off each of the rubber buttons located along the edges of the Acer Aspire 5535 Screen. Remove each of the screws underneath the buttons with the Phillips-head screwdriver, remove keyboard.
4. Insert your fingers underneath the cover of the Acer Aspire 5535 Screen. Work your fingers around the edges of the cover to unlock it from the screen. Pull the cover off the screen and set it aside.
5. Locate the inverter board at the bottom edge of the Acer laptop screen . Disconnect the cables at the right and left end of the board that connect to the Acer Aspire 5535 Screen. Remove the screw holding the inverter board in place and then lift the board off the LCD screen.
6. Tilt the screen slightly towards you until you can see the strip of tape holding the video cable. Pull off the tape and then disconnect the video cable from the laptop case.
7. Remove the Acer Aspire 5535 LCD screen from the case. Set the new screen onto the case and reattach the video cable and tape strip. Position the replacement inverter board at the bottom of the screen and attach the screw.
8. Reconnect the inverter board's cables. Pop the plastic cover onto the Acer Aspire 5535 LCD screen and reconnect the screws. Set the rubber buttons over the screws. Reconnect the battery.
9. Turn on the laptop. Wait for the manufacturer's logo to appear on the screen to ensure the display was replaced properly.
Apr 13, 2011 | Computers & Internet
Don't know how to turn it on
Check power lead,press the button on the right at the bottom of the screen if a light comes on then it is on. Start PC, light should go green and monitor should give a display. If there is no life at all then the monitor is dead, change it :( If the light is on but starting PC doesn't give a display then check lead from PC, try another monitor with PC and if it works change resolution to something basic like 1026 x 768 @ 60Hz then try the acer again. If another monitor doesn't work your PC has a graphics problem; Check the lead thoroughly, check in bios settings the display is set right, try a new graphics card
Aug 02, 2009 | Acer AL1916W 19" LCD Monitor
My monitor is new .. the screen stays black and the power button flashes green ... how do i fix this ????
Hi!
I have acer al1716 LCD and whan the computer is turn on, the lcd led turn green but the lcd is showing black, what i can do?
thank you!
Apr 16, 2009 | Acer AL1716 17" LCD Monitor
Acer aspire 5043wlmi laptop starts but know function of lcd but works on desktop monitor
The computer's power management system automatically dims the screen when using battery power, which is one of the power-saving features.
To adjust the brightness:
  • Hold down the Fn Key located at bottom left of your keyboard next to the Ctrl key, and adjust the screen brightness using the left/right arrow keys located at the bottom right of the keyboard.
If that's not it then
A dim or dark screen does not necessarily mean a bad inverter! It could be a faulty lcd backlight bulb, inverter cable, inverter, or in some cases a motherboard failure. If your still under warranty then I would get Acer support on the phone and see what they can do.
An Inverter converts direct current (DC) to alternating current (AC).
Jul 01, 2008 | Acer Computers & Internet
No sound
If it is a desktop then you need to purchase speakers & if a laptop then 90% there would beinbuilt speakers.
Before anything check if the sound is working on the system
Double Click on the speaker icon on the right bottom of the screen>>make sure in none of the mute boxes should be checked>>Now try to play any audio >> this can be tested by playing a song on the system
click the pearl sign on the left bottom>>click programmes>>Click windows media player>>put a cd and try playing it>>Play a file>>
May 25, 2008 | Acer 90.00012.30B Computer Speakers
(strange) volume control icon stuck in the middle of my LCD monitor and the buttons on the front of the monitor are frozen and will not work?????
Restart the computer. Right click on the task manager > Task manager > End all the programs in Applications folder.
All the best.
Santo
Dec 17, 2007 | Acer AL1715 17" LCD Monitor
Acer AL1916W 19" LCD Monitor Logo
26 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
