Question about Kenmore 20722
Water won't empty - Kenmore 20722
  • Kenmore Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Aug 22, 2010
Nespresso won't reset after emptying capsule basket. Lights flash as if basket is still full or water is empty??
Call company ASAP..
and they may give you a new one..
after my research.. many have a lot of troubles,
some are different than yours.
or call 1-800 555 1212.. for company information
to call company..
Bummer not having Coffee when you want it.
Apr 06, 2013 | Coffee Makers & Espresso Machines
Water won't empty
IF YOU CAN HERE IT RUNING OR A HUMING SOUND MAY BE YOUR WATER POMP SOME THIG STUCK ON IT VERRY COMAND ON FRIGDAIRE.
Feb 21, 2012 | Frigidaire Washing Machines
What is the float switch
I have no real experience with float switches on dishwashers, but have with some in humidifiers. It's a piece of styrofoam on a narrow metal stick that lifts when the appliance fills with water & lowers when the water empties. If this gets stuck on something, like a dishwasher rack, the unit won't fill or empty the water & the cycles won't work properly. Take a look & see if there is such a thing hung up somewhere in the dishwasher. If you can loosen it, your dishwasher should work again.
Feb 21, 2012 | Beko 24 in. D3421F Free-standing...
Zanussi 1400 Front Loader: Machine washs clothes as per normal but does not drain the water and cannot go into the spin cycle. Sits there doing nothing then starts bleeping.
This is almost certainly a simple problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. While it's trying to get the water evacuated, you will probably see the machine doing a slow tumble for up to 8 minutes and you may also hear the empty pump running too.
You need to locate and clean the filter. Depending on the model (You haven
Aug 30, 2011 | Zanussi Washing Machines
Washing machine won't pump out to go into spin cycle is there a strainer that needs cleaning
You need to locate and clean the filter. Depending on the model (not familiar which with the model you mention) there is probably a round filter cap on the front of the machine at the bottom (It may be behind a small door or hidden behind a clip on panel on the bottom) Many models of this design also have a small hose to the right of the filter cap that you can pull out, remove a plug from and drain off any water in the filter before you remove the filter and get your floor wet, so take a look for this before you remove the filter and get soaked.
Aug 15, 2011 | Frigidaire Washing Machines
My dehumidifier full light is on but the unit is empty and the fan motor won't work. Is there a way to reset it? Is that why the fan motor won't work?
This is generally causes by improperly installing the water collection bucket after removing it to empty it. Or the float valve in the top ow the water bucket s stuck in the "UP" position. Some Maytag models have a float control that moves from left to right, depending on how much water you want it to collect, before having to empty it. It may be stuck in the center position and needs to be moved left or right.
When installing the bucket, be sure that it fits into the holder "squarely" from top to bottom and makes contact with the bucket removal safety switch at the back of the bucket holder. When installed properly, the bucket should not tilt down at the bottom.
Hope this helps you and thanks for choosing FixYa.
Aug 06, 2011 | Maytag Dehumidifiers
We put a heavy blanket in the washer and the load stopped suddenly with a washer full of water. It wouldn't spin or empty and made a weak sound but nothing worked. We had to manually empty the water....
Usually that means the drive belt is loose and slipping. You should be able to tighten or replace the belt.
To test the belt you have to remove the washer back.
Jul 29, 2011 | Kenmore Washing Machines
Won't catch and empty water through attached hose.
My humidifier has a knockout inside the hose connection, that you have to remove. simple but check it out.
Jul 02, 2011 | Maytag Dehumidifiers
Fills with water, drains, will not spin. sometimes will not fill
This is almost certainly the filter to the empty pump blocked. When you power up the machine, the first thing it does is make sure there is no water left over in the tub, if it can't evacuate any water it finds there, it won't go any further. Same on a spin, if after a set time the water hasn't emptied the empty cycle will stop but the spine cycle wont start because there is still water in the drum.
Locate and clean your empty pump filter.
Jun 29, 2011 | GE Washing Machines
Washing Machines Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
