Question about HP OfficeJet 6210 All-In-One InkJet Printer
Paper jam on HP 6210 fax
Can topen door to fax. not sure how much to force, or if it really opens. can print and copy although the jam is still flashing for the fax.
  • susandale May 11, 2008
    shaggy,
    the door to the fax clean out/roller is on the top. the back door is for access to the printer otherwise.
    Genius:
  • 1,224 Answers
Opens from the back of printer be gentle its called a clean out
http://h10032.www1.hp.com/ctg/Manual/c00238458.pdf
click the link goto trouble shoot paper jam
Posted on May 11, 2008
Printer continuously says there is a paper jam, but no paper jam exists. I have run paper through several times and it still says paper jam. How do i clear this? Kirk
Turn off the printer
Remove the Rear Access door
Clean the collers ( upwards ) with lint free cloth.
Close the Door.
Scuffle the papers in tray and place them
Try to make copy or print.
Feb 07, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Cant send nor receive faxes
dear sir,kindly follow the below instructions
Instructions
  1. Ensure that all cables are securely connected. First, make sure that the printer cable connecting your computer to your printer is connected securely. Then, make sure that the power cord is inserted into a wall outlet. Try your print job again after you have ensured that all cables are properly connected.
  2. Clear a paper jam if your printer is not responding or you are receiving a "Paper Jam" error message on your printer. To clear a jam, first open the rear output door by pushing down on the two levers on each side of the door. Opening the rear door simply makes it easier to clear a jam. Open the top cover on the front of the printer by pressing the release button on the right side of the printer. Locate the paper jam and use two hands to gently remove the paper jam. Try your print, scan, fax or copy job again.
  3. Clear stored or saved faxes if you are having trouble sending or receiving faxes. Old faxes may be stuck in the fax queue, which may be causing the printer to not respond. To remove stored faxes, press the "Menu" button on the printer and select "Fax Functions." Then select "Clear Saved Faxes." Wait for the queue to clear and try your fax job again.
  4. Remove paper from the automatic document feeder (ADF) input tray if your scan job is coming out crooked. The ADF input tray can only hold up to 50 sheets at a time. If there are more than 50 sheets in the input tray, the output may appear skewed. Try your scan job again after removing the paper.
  5. Adjust your computer monitor's display settings if your scanned image is not an accurate representation of the original image. This can be done in the "Control Panel" in Windows. Set the settings to the highest possible resolution and try your scan job again.
  6. Perform a power cycle on your printer if the previous steps were unsuccessful. To do this, turn off your printer, then unplug it from the wall. Wait a few minutes and plug the printer back in. Try your print, scan, fax or copy job again.
take care..thank you
Oct 04, 2010 | HP LaserJet 2840 Printer
Paper jam that tells me to 'remove rear access door' and I don't know how to do that
Clear the jam from the back of the All-in-One CAUTION: Do not try to clear a paper jam from the front of the product. Pulling the paper from the front of the product rotates the paper feed roller in the wrong direction and can damage the print mechanism.
  1. Press the Power button (c01476163.gif ) to turn off the product.
  2. Disconnect the power cord from the back of the product.
Press in the tab on the left side of the rear access door to release the door. Remove the door by pulling it away from the product.
Read this document from HP:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00249509&cc=us&lc=en&dlc=en&product=421991
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 17, 2009 | HP OfficeJet 6210 All-In-One InkJet...
My hp officejet 6210 all in one keeps jamming
Look at the rear of the printer....there might be a large access door with a big knob to turn.
Jan 02, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Wont print
I'll have to begin with the obvious...
Have you set the printer preferences correctly for contact sheets?
Check all of your default printer settings in control panel>printers & faxes> your printer>right click>preferences
If these are not correct for what you are printing you need to set up your printer for what you are printing at the time.
(You may know all this already)
I would also do a left click on the printer icon and cancel all documents if there are any in line.
I would then turn off the printer, open the paper jam door and give the paper roller a gentle push upward until it clicks. close the paper Jam door.
Unplug the printer.
Wait about 15 minutes. plug it back in and turn it on and give it a new try ( remember to do the setup for whatever you are printing)
Good luck. Let me know if this works!
Aug 16, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP 6210 All-In-One
Open up the top and look into the cartridge/paper print area. Look in the corners, Sometimes little pieces of paper can still be stuck there. Once you are convinced that the paper and cartridge path is clear then...
Pull out the paper tray. Look inside the opening. If there is paper there then pull it out.
Take all of the paper out of the paper tray.
Turn it over (paper on top is now on the bottom of the tray)
Try it now.
Jun 20, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Jammed fax; cant open door
there should be green or red tab to open this door
May 04, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP 6210 using double paper?
Try cleaning the rollers (especially in the back door). It stopped mine from jamming. Hope it will stop the double paper thing!
Apr 15, 2008 | HP OfficeJet 6210 All-In-One InkJet...
PAPER JAMMED
You have a stuck sensor.
Open the rear door and make sure there is no paper in there.
Remove your toner from the drum and make sure there are no bits of paper stuck under the toner cartridge.
l
Look inside the drum chamber for the little plastic levers that actuate the sensors. Make sure they move back and fourth freely.
Dec 05, 2007 | Brother IntelliFAX 4100 Laser Fax
HP OfficeJet 6210 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
