Question about Ovens
I have a Maytag stove model CRG7500AAE but i dont know how turn on the oven can you help me?
  • 37 Answers
Edgar Romero --
Owners Manual is available online at:
[http://shared.whirlpoolcorp.com/assets/pdfs/literature/CRG7400AAL.pdf]
After you look at the manual, if you still have a problem, write back. -- SWT
Posted on Aug 22, 2010
How do I turn the temp down after oven has been on for a while. 'Loc on' message is showing and will not allow me to turn oven on.
Can you provide some additional details to help me help you? What kind of stove (make/model) and does it have any kind of self clean mode?
Without knowing the above details generally speaking of the oven is already preheated, to change the temperature you would hit the bake/preheat button to then adjust temp up or down with a digital stove. The dial stove from is self explainatory!
That loc on message may be because you have a stove lock lever or feature that prevents the stove from being opened when enabled, or when the stove is self cleaning. This may prohibit the adjust meant of temperature when the lock is on, or the stove is running through the self clean..
Again all just a general thought without knowing the above information... if you can post back or let me know is this was helpful in anyway to you! Thanks!!
Feb 13, 2017 | Ovens
Maytag stove model JJW9530AAW not working
https://removeandreplace.com/2017/03/21/maytag-oven-error-codes-stove-range-fault-codes-causes-and-solutions/
Nov 20, 2017 | Stoves Ovens
On a Maytag stove, model 3468XVA, how do you remove the top that the burners are mounted on? The burners are attached to the gas valves by an alumimum tube and the tubes will bend if I raise the top. I...
Hello, Thank You for using FixYa. I will be helping you today.You have to turn each burner head a half turn and lift them off you dont need to open the top. A oil filter wrench for a car will help if their stuck and wont turn. Thank You and please rate my answer if it was helpful..
Jun 14, 2011 | Maytag Ovens
My gas oven doesn't work but the stove part does. The product is only 2 years old.When I put the Bake or broil button on the oven doesn't heat up. I am sure the pilot light is out but I don't know how to...
To answer the question fully, I'm gonna need the model number. Pull out the bottom drawer, and the model should be located on the side of the frame or on the drawer itself. Might even be behing the oven at the top, should be a metal plate that flips up.
Feb 21, 2011 | Maytag Ovens
We have a maytag electric range/oven model #MER5770AAW .after baking some french fries ,with the oven open it made a beep and F9 message came up on the panel.everything still functions ,have hit the...
F9 Door Lock Warning Check door lock circuit or Replace Clock. If clock working don't do that.
ck here for the code.
https://www.repairclinic.com/RepairHelp/FaultCodes/31/Range-Stove-Oven
parts here....
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/19-4-93082-/new/Maytag-Oven-not-self-cleaning-MER5770AAW
you can call their 800# or use the chat for more info if needed.
first check that the latch is not a 1/4 or so closed.
open and close the latch a few times.
also you can turn off the breaker for a few minutes
and see if it resets the ecm.
Hope this helps a little
Jan 16, 2018 | Maytag MEW5530D Electric Single Oven
Electric stoves
if the model has a digital clock and when the power went of it may have fried the little computor.if you dont have trip switchs in fuse box
Nov 07, 2008 | GE JGRP17 Gas Single Oven
Oven stop working
In many cases, even if the igniter is glowing, the resistance may not be low enough to turn on the gas valve. The igniter has probably gone bad. ($50.00 to $90.00 for igniter)
May 21, 2008 | Maytag Ovens
Oven is locked
press Clean again and add time the quickly open the oven . Before it lockes in clean mode it unlocks soo yea hope this helps.
Feb 22, 2008 | Maytag CWG3600A Gas Single Oven
Problems with the oven of my Maytag stove.
press and hold the cancel button for five seconds.
Nov 04, 2007 | Ovens
Ovens Logo
96 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
