Our Neptune Maytag Washer is making a very loud noise during the spin clycle. I think It may be a bearing but its only a little over 4 years old. Have Maytag had a lot of problems with this kind of noise
    Novelist:
  • 172 Answers
Yes Maytag has had seal and bearing issues. Check your original warranty paperwork it still maybe covered?
Call the store where you bought it, they may cover it under warranty.
Did you buy an extended warranty?
Posted on May 04, 2008
Maytag Neptune - MAH5500BWW makes loud, loud noise during spin cycle. What parts are necessary to repair the unit? I assume there are bearings and seals needed. Thank you.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
May 26, 2011 | Maytag Neptune MAH5500B Front Load Washer
My Maytag Neptune washer is extremely loud during the spin cycle and the detergent dispensing door is broke, How much would I be looking at out of pocket to get it fix or would it be cheaper to replace it...
The loud noise during the spin cycle is probally due to a bearing failure. Not sure how much it would cost to fix, but Maytag does not sell you the bearings but would sell you a new wash tub with the bearings installed for over $600! Add the labor costs which would be a lot since the machine needs to be taken apart to install a new tub, and you would be ahead of the game getting a new washer.
Oct 04, 2010 | Maytag Neptune MAH5500B Front Load Washer
Makes loud noise in spin cycle
The problem is that the seals are leaking and allowing water to attack the tub bearings.
You need new tub seals and bearings.....not as difficult as it may seem.
see u tube video on replacing maytag seals and bearings
Cheers Stan
Aug 12, 2010 | Maytag Neptune MAH6500A Front Load Washer
Maytag neptune
There is 2 possible problems. 1. Pump will make noise as soon as the drain and spin starts. 2. Rear bearing this noise usually starts later in cycle as the drum gets up to final speed. The rear bearing of coarse is the most expensive of the two as it is part of the outer tub.
Mar 04, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer makes loud grinding noise during the spin cycle
if it's making a noise then either your drain pump bearing is going out or your thrust bearing is going out (assuming the noise happens in both spin and wash). Tip the washer backwards so that you can get underneath of it. Take the belt off and spin the pump pulley on the right side. This should spin effortlessly.
The middle pulley is the trustbearing pulley. Spin this--- one direction it should have a little bit of resistance--- the other should have more resistance
Aug 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Extremely loud noise during spin cycle of my Neptune dryer--just started happening in the last month. The dryer is probably 7-8 years old, so it's not the newer Neptune model.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
hgd76
Jun 26, 2009 | Maytag Neptune Washer
Very loud noise during spin cycle
Probably a broken strut or support. some call it a shock absorber.
May 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Series MAH5500BW loud noise during spin cycle.
very loud in spin cycle can mean a bad rear bearing, not something a homeowner would want to try to replace, parts would exceed 6-7 hundered dollars. you may have some extended part warr through the manufacture. still probly gonna be a 5 hundred when the labor is added in
Dec 06, 2008 | Maytag Neptune Washer
Washing Machines Logo
80 people viewed this question
Top Washing Machines Experts
Richard Roth
Richard Roth
