Question about Rowenta Professional DX8800 Iron
My expensive 6 month old "no drip" Rowenta iron has started leaking large amounts of water suddenly. (all over a silk dress). What is causing this and how can I fix it??
  • Rowenta Master
  • 43,501 Answers
Here is a tip about Irons that leak water...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Posted on Aug 22, 2010
We have Rowenta DM 890 steam iron. It dumps water. Also Why not use distilled water?
The following web blog about Rowenta steam irons has some tips on maintaining the iron:
http://www.nasa1.org/iron%20rowenta.htm
The following web blog explains the issue of not using distilled water:
http://ths.gardenweb.com/forums/load/laundry/msg011421358265.html
I guess the bottom line is that it takes a higher temperature for distilled water to boil. It also explains that will cause the unit to spit, drip, and leak.
Try affordable spring water, and you should get better results.
Jan 27, 2011 | Rowenta Irons
Rowenta Iron leaking out of bottom and leaks on clothes
I have one of these and have been battling the leak problem for years. I'm a stubborn mechanical engineer and I'm bound and determined to fix this, when in fact I should just buy another, different, iron.
The problem is then 'handle'. Built into the handle is the water tank. The water tank is made from two pieces which are then glued and screwed together. Think of taking a coke bottle, cutting it in half, and then gluing it back together. Now you see where the problem comes in... the glue they use isn't up to the task, or the heat... or the pressure... is causing the tank to leak somewhere / everywhere.
I have disassembled this several times, meticulously scraped out the old silicone, and tried several different types of silicone to re-seal. So far it always fails. It's good for a while, but maybe a couple months, before it starts leaking again.
Conclusion... BAD DESIGN. Very disappointing, because in every other respect I like this iron better than any I've ever owned.
Jul 14, 2010 | Rowenta Power Duo Iron
Brown water staining clothes when ironing
either the water has sat in the iron too long between uses
or its the iron in the water you use.
you will have to flush out the old water.
try distilled water
Jun 27, 2009 | Rowenta DX6700 Iron
I have a rowenta iron. When I am ironing the
Here is a tip that will help you with that problem...
heatman101
Jun 25, 2009 | Rowenta DX6700 Iron
My rowenta professional iron drips, how can I fix it?
Are you using distilled water to refill your iron? Distilled water can cause drips if used all the time. Refill with tap water and see if the drips stop.
Jun 22, 2009 | Rowenta Steam Generator DG050 Iron
Just a few months old and stopped steaming, steams frowater entry
I have taken one of these completely apart and found it is glued together except for the platinum plate on the bottom. It is held on by circular lock clips and will break w/o proper tool. I see no way to repair these and the cost of sending in will probably be as expensive as a new one. I have seen them at Lowes and TuesdayMorning for about $100.00. Have tried to get a repair manual from Rowenta-good luck!
Nov 15, 2008 | Rowenta DZ9080 Iron with Auto Shut-off
Rowenta Steam Iron Leak
I have purchased two Rowenta irons. Both have the problem with water leakage. The entire iron looses all of it's water....both in the stand up position and the sitting down position. This happened after a couple of months for both items. I contacted Rowenta and they never responded. I will never purchase another item from them. Obviously, the irons must be defective. I'm going to contact consumer affairs.
Jul 14, 2008 | Rowenta Perfect Iron
Shark iron
I bought this Shark iron last July and I even saved the receipt!!But I threw the box away. The water is leaking out of the bottom. I bought the expensive Rowenta before that, and that one leaked all over my ironing. And I cleaned these irons faithfully every month. I need a toll free number for Shark
Nov 13, 2007 | Euro-Pro Shark GI490 Iron
Dial stops at "silk."
if the iron is under warranty send it back to the company.if not take down the iron it has a broken part that is stopping it from moving properly.good luck.
Apr 02, 2007 | Rowenta Perfect Iron
Rowenta Professional DX8800 Iron Logo
2,050 people viewed this question
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
