Question about HP OfficeJet 6210 All-In-One InkJet Printer
Jammed fax; cant open door
Paper jammed while sending fax. says to open fax roller door on top. it seems it wont opne/doesnt open? no tsure how much or how to force it.
read about unplugging and #3, not sure where to to the #3. on HP, on keybd computer??? when to do it. did it on hp; nothing changed.
  • 1 more comment
  • susandale May 08, 2008
    there's no tab.
    i went to circuit city, and the guy there used considerable force to open the door. i just was afraid to try that hard, since it's plastic and all. and it didnt really look as if it would open. it did, and it's fine, thank you so much for responding.
    shaggyrat,
    tx agn. model # is 6210. see no tabs. but a 1 inch horiz line on oen sid ethat implies, pull here. it's tricky, cuz it is easy to push agianst the fax tray to pull the door open. instead, we noted, brace forearm against outsid e edge of door, and pull w/ that hand. that's our best case scenario. s.
  • susandale May 09, 2008
    it is the fax door accessing the fax roller, not access to the print roller that i was going for.
    sorry, i clicked mistakenly on inappropriate, sorry. my mistake. i meant it wasnt answering my query. and thanks for trying.
    cc guy didnt open my actual printer, just one in the store. and i see no other way to access fax roller, nor openning that door. tho have wondered about how to get into the rear door., so thanks for that,
    Problem Solver:
  • 5 Answers
I was told to clean all the rollers on the printer & it stopped jamming!
Posted on May 08, 2008
    Genius:
  • 1,224 Answers
There should be green or red tab to open this door
Posted on May 07, 2008
  • Christophe Thompson
    Christophe Thompson May 08, 2008
    your welcome theres couple tabs on fax so it can be opened properly if you have model number i can get the manual so that i can give you the proper way to open it next time
    Christophe Thompson May 09, 2008
    http://h10032.www1.hp.com/ctg/Manual/c00...
    chapter 14
    page 108 is the start of this link for the manual of cleaning and raising lid
    the circuit city guy might have done damage to your printer manual states
    1 Make sure the HP all-in-one is on
    Warning
    If the HP all-in-one is off when you lift the print-carriage access
    door to access the print cartridges, the HP all-in-one will not release the
    cartridges for changing. You might damage the HP all-in-one if the print
    cartridges are not docked safely on the right side when you try to remove
    them.
    2 Open the print-carriage access door by lifting from the front center of the device,
    until the door locks into place.
    The print carriage moves to the far right side of the HP all-in-one.
    page 113
    Paper has jammed the HP all-in-one
    Solution
    1 Press in the tab on the left side of the rear clean-out door to release the door.
    Remove the door by pulling it away from the HP all-in-one.
    in the back of printer
    Caution
    Trying to clear a paper jam from the front of the HP all-inone
    can damage the print mechanism. Always access and clear
    paper jams through the rear clean-out door.
    2 Gently pull the paper out of the rollers.
    Warning
    If the paper tears when you are removing it from the
    rollers, check the rollers and wheels for torn pieces of paper that
    might be remaining inside the device. If you do not remove all the
    pieces of paper from the HP all-in-one, more paper jams are likely to
    occur.
    3 Replace the rear clean-out door. Gently push the door forward until it snaps
    into place.
    4 Press OK to continue the current job.
    page 145 to 146 in the pdf file manual not by the book manual
I am getting rec.paper jam no paper jammed though
Open back door, clean feed roller very well, and open and close upper cover.
May 28, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
Paper jam
Sir/Mam
The problem mite be dirty rollers that feed the paper, try cleaning with alcohol or worn out replace. Problem is the paper roller is miss feeding not taking up the paper instead of hitting something in the machine paper jam.
Apr 18, 2010 | HP 1010 Plain Paper Inkjet Fax
Says there is a paper jam but we looked everywhere and there is no paper stuck anywhere in the machine
soes it say original jam or just paper jam if the jam is in th document feeder part open the top and check the sensors where the paper goes trhough.you may have to take the toner/drum unit out to reset the jam also if there is a door on the back open and close this to reset the sensors. If there was no paper the first time check the paper tray by pulling out and then look inside where the tray sits as the poaper might be stuck there.. also check the tray in that the paper sits tight in the guides and the rollers that feed are not dirty. If turning on and off doesnt get rid of the jam there is something stuck on one of the sensors..Goood Luck A
Aug 11, 2009 | Office Equipment & Supplies
Sharp fax - drum won't grab paper in order to send fax
Open the top and clean the rubber rollers with alcohol. Wife them well with a lint free cloth. Parae towels will put more junk on them.
Mar 08, 2009 | Sharp UX-B750 Inkjet Fax
Paper does not want to go through (apparently rollers),
There is something blocking a clear paper path. open the top and look for something not obvious, like a staple or a punch dot.
Feb 19, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
Machine reads "document jammed"
its the problem of the rollers which pulls the papers they r worn out.I've seen this before repairing computers and asked about fax machines while I am there. There are rollers that cling on to the paper and move it through the machine. When the rollers are worn down they do not grip the paper. For a short fix you can get something rough like sandpaper, brillo pad, etc, and gently scratch the rollers to give them some traction. This will temporarily solve your problem until you can get the rollers replaced.
Jan 07, 2009 | Panasonic KX-FL541 Plain Paper Laser Fax
Rec paper jam
When you open the rear door you will see roller- clean it with water or alcohol and dry it.
Aug 11, 2008 | Canon CFX-L4000 Plain Paper Laser Fax
Faxes out pages jamming
The transmit cover will have to be opened. If you can't do this call a repair man. He will be looking for damage to the last roller called the paper out roller. It may have become dislodged from it's holder, or the holder itself may be broken. If the machine is within warranty, take it back for repair.
Jul 25, 2008 | Canon FAX-L1000 Plain Paper Laser
Fax Jam
hp tells me to do the following
does this help you ?
Issue While printing, copying, or receiving a fax, a paper jam occurs. If the jammed paper is removed incorrectly, other problems may occur. Clearing paper jams Remove the jammed paper by following the steps below: WARNING: Jammed paper must be removed using the rear access door to avoid mechanical damage. Do not remove jammed paper from the front of the all-in-one.
  1. Turn off the HP product and turn it so the back of the all-in-one faces you.
  2. Disconnect the power cord from the back of the all-in-one. CAUTION: The power cord must be disconnected to allow the paper feed rollers to turn freely and avoid mechanical damage.
  3. Locate and open the rear access door by pressing in on the left side tab to release the catches and then pulling the door toward you. Figure 1: Removing the rear access door c00100775.jpg
  4. Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door. Click How to Buy on this page to order replacement parts.
  5. From the rear access door opening, remove the jammed paper.
  6. Remove the remaining paper from the paper supply tray. Discard any paper that is damaged or crumpled and then re-stack and reload the paper into the paper supply tray.
  7. Reinstall the rear access door.
  8. Reconnect the power cord and turn on the all-in-one.
Preventing paper jams The following information will help prevent paper jams from occurring:
  • Never use paper that is wrinkled or damaged in any way.
  • If you are having problems using paper that has already been printed on once (recycling), replace it with fresh paper.
  • Remove and then reinstall the rear access door. Verify that the access door is fully locked in place. The paper can skew if the rear access door isn't locked.
  • Every six months to one year, clean the paper feed rollers with a rag lightly moistened with clean water. Over time the paper feed rollers accumulate dust and do not function as well as they once did.
  • When printing envelopes, tuck the flap into the envelope and crease the folds before printing.
richard from chicago
Dec 02, 2007 | HP Officejet 5510 All-In-One Thermal...
HP OfficeJet 6210 All-In-One InkJet Printer Logo
113 people viewed this question
Ben Johnson
