Question about Kenmore 80012 Microwave Oven
ASKING FOR TIME OF DAY BUT WHEN I PUT IT IN IT WILL NOT DO ANYTHING WHEN I HIT THE START BUTTON. THIS MODEL DOES NOT HAVE A RESET BUTTON.
  • Kenmore Master
  • 9,047 Answers
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
If it still fails, you likely have a bad keypad.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Jot down your full model number and see here for more help.
Posted on Aug 22, 2010
Setting the setting the clock
Colin,
Most of the time, you hit clock, then on the keypad, punch in the time of day and then either hit clock again or hit the start button. Some models may ask you for AM or PM but it will scroll a message if it is going to ask that & will tell you what button to push. Hope this helps!
Jul 09, 2015 | Microwave Ovens
When you put something in microwave and push for time it will run for about 5 seconds and fan will change tone and it won't heat anything
HELLO.
TO MAKE YOUR MICROWAVE WORK AS REQUIRED BY YOU.TAKE THE RESET STEP
4 Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the GE microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset.
5 Reset the time of day. Press the "Clock" button, and turn the dial to set the hours. Press the dial to enter. Follow the same procedure for the minutes and a.m. or p.m. Press the "Start" button to start the clock.
Thanks.
Sep 07, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
The colon between the numbers on the clock, example 8:00 won't stop blinking even after I set the clock and hit the clock button again.
Sometimes the correct procedure for setting the clock is to press the CLOCK or TIME OF DAY button, then enter the time on the keyboard, then press the START button instead.
Otherwise, as long as you can enter a cooking time and your oven operates normally, then don't worry about it. On some models it is normal for the colon on the clock display to blink all the time.
Good luck.
May 11, 2011 | Microwave Ovens
I have a Hot Point Microwave - Counter Saver Plus I hit or did something and the word "LOC" is in the screen.l I can't do anything. I am assuming I locked it up somehow. Please help. The...
This is likely the CHILD LOCK feature of your microwave whish is engaged.
Try holding down the CLEAR / OFF button or the RESET button for 5 seconds in order to disable it.
Since you did not provide a model number, you will have to check your own User's Manual for the exact detailed instructions if required.
Good luck.
Apr 23, 2011 | Hotpoint Microwave Ovens
Model no.TI1613BS1 i have somehow caused the 'padlock' (which i've never used) on the bottom righthand corner to activate. now i can't start either of the 2 electric hobs. have followed manuel's...
Press the "Off/Clear' button to cancel anything on the display, and reset the microwave. This is a soft reset and will simply get you out of any program you have started. Press it when the cooking complete reminder appears on the display.
Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset.
Reset the time of day. Press the "Clock" button, and turn the dial to set the hours. Press the dial to enter. Follow the same procedure for the minutes and a.m. or p.m. Press the "Start" button to start the clock. This should help fix the problem.
Apr 12, 2011 | Brandt Microwave Ovens
Kitchenaid vented microwave KHHS179LSS-5 surface light is blinking on and off. Started a couple of weeks ago. Thought I was forgetting to turn the light off but realized it was not me. Went to the...
Apr 27, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Our 2006 Samsung Microwave has suddenly ceased to heat anything. The clock works and the turn table goes around, but that's it. We had a couple of power outages just before this happened. Could it be...
Nov 29, 2010 | Samsung Microwave Ovens
Whirlpool AVM 230 Microwave short circuit
If the fuse or breaker blew again, you probably have a shorted high voltage capacitor. If not, then you may have a shorted high voltage rectifier diode.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Sep 11, 2008 | Whirlpool Microwave Ovens
Kenmore 80012 Microwave Oven Logo
50 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
