Question about Compaq Presario 2100T Notebook
Green screen shows up and says reboot your system i dont have a recovery disk
SOURCE: please help me
If your computer is running kind of sluggish, you can fix it with an easy clean up of your registry. Here's a link to a free scan that works well:
www.your-free-info.com/RegCure
I've used this one and it sped up my computer by quite a bit. Hopefully this helps.
Posted on May 11, 2008
  • 130 Answers
SOURCE: operating system not found media test failure will not reboot aspire 3680
you need to replace your hard drive, as the other one is toast, I doubt very much its the controller, or a software issue, try a new hard drive and your problem will go away.
Posted on Jun 15, 2008
antiochpc
  • 1314 Answers
SOURCE: reformatting my compaq presario using my recovery disks
To turn on system restore, go into control panel, system. Click on the system restore tab. There you can turn on your system restore again.
Posted on Jun 22, 2008
Pyrhyc
  • 2028 Answers
SOURCE: I can't do a full system recovery
It's very possible that your hard drive has failed, and the recovery is stopping because it's unable to read/write to/from the drive. Try a new hard drive.
Posted on Jul 22, 2008
SOURCE: Averatec 3200 Recovery Failed
what is the link for the drivers?
Posted on Sep 28, 2008
Emachines cannot acces to safe mode stuck on windows/welcome screen and dont have a recovery disk
Remove ALL media, DVD,CD,USB, Unplug, remove battery, plug in , reboot, OR, unplug while it's on and repeat if necessary. Use this procedure to do a System Restore/Recovery: http://answers.yahoo.com/question/index?qid=20060819000752AAUeYvu It would be helpful if you posted the eMachine Model and the OS you are using.
Mar 18, 2013 | Computers & Internet
Non system or system disk error
Bad HDD? Have you tried a system restore/recovery. Reboot, at preboot repeatedly tap the F-11 key try to get to system restore/recovery.If it's an old machine you may need to replace the HDD.
Nov 06, 2012 | Compaq Armada M700 Notebook
Tablets wont boot up just shows arnova on screen and shuts down
I had same problem looping startup just showing Aenova screen, i tried the pin thing ended up doing a factory reset IT WORKED WAHEY!!
How can I do a Factory Reset on my tablet? If your tablet freezes often or if you get error messages during the start up of your tablet, you can use the recovery mode to reset your tablet to its factory settings, removing all installed applications as well as any data or content.
Your tablet must be up to date with the latest firmware - downloadable from the downloads area of this website.
To access Recovery mode on the ARNOVA 10bG3
To access to the recovery mode:
1. Hold down the volume button + and press the ON/OFF button.
2. Once the boot logo ARNOVA is displayed, release the volume button +.
The ANDROID green robot is displayed.
3. Once the ANDROID green robot is displayed, press simultaneously the volume button + and the ON/OFF button.
The Android system recovery screen is displayed.
a. Use the volume buttons to navigate
b. Use the ON/OFF button to select an option
To restore the default parameters of your tablet:
1. In the Android system recovery, select Wipe data/factory reset;
2. Select Yes -delete all user data.
3. Select Reboot system now.
Your tablet reboots. Redefine your parameters through the wizard.
Your tablet is restored to its default settings.
To access Recovery mode on the ARNOVA 9G3
1. Hold down the Home button and press the ON/OFF button.
2. Once the ARNOVA boot logo is displayed, release the Home button.
To access Recovery mode on the ARNOVA 8cG3/8bG3
1. Hold down the volume button - and press the ON/OFF button.
2. Once the boot logo ARNOVA is displayed, release the volume button -.
Sep 16, 2012 | Tablets & eReaders
Factory reset for Aspire one without disk and alt + F10 doesnt work
The disk-to-disk recovery may be disabled preventing the Alt + F10 key sequence running eRecovery. To enable disk-to-disk recovery, you must do the following... (do not have an external monitor attached)
1. activate the BIOS utility by pressing F2 during Power On System Test (while Acer logo displayed)
2. select Main from the categories listed at the top of the screen
3. find D2D Recovery at the bottom of the screen and use F5 and F6 keys to set this value to Enabled
4. exit the BIOS utility and save changes.
The system will reboot.
5. while the Acer logo is showing, press the Alt key and the F10 key at the same time repeatedly
6. wait as Acer eRecovery starts up then follow onscreen instructions to perform system recovery.
Alternatively to the above, if Windows can be accessed, the recovery can be done by launching Acer eRecovery Management by running the program from the Acer Empowering Technology program group in the Start menu.
Mar 22, 2011 | Acer Aspire One PC Notebook
My acer will only boot to the Microsoft Windows loading page then it starts over. How can I reboot my acer without a disc?
Enable disk-to-disk recovery
On boot, press <F2> to enter BIOS. To enable disk-to-disk recovery (hard disk recovery), activate the BIOS utility, then select Main from the categories listed at the top of the screen. Find D2D Recovery at the bottom of the screen and use the <F5> and <F6> keys to set this value to Enabled. Save and reboot. While the Acer logo is showing, press <Alt> + <F10> at the same time to enter the recovery process. Refer to the onscreen instructions to perform system recovery.
Oct 05, 2009 | Acer Aspire 5100 Notebook
Backup for Sony vaio
If you got the recovery disk along with the Vaio laptop, good enough.Insert the disk and reboot, follow instruction displayed on the screen to restore.
If you dont have a disk, can try this :--
Reboot and press F11 to try and enter the system recovery mode, if you can then you're good, simply follow the prompts to perform a system recovery.
Let me know the status please.
Thanks
Mar 30, 2009 | Sony VAIO PCV-RS710GX PC Desktop
I need to know how to avtivate the system restore for the computer for a ACER ASPIRE 4520 sincei dont have the disc??
This recovery process helps you restore the C: drive with the original software
content that is installed when you purchase your notebook. Follow the steps
below to rebuild your C: drive. (Your C: drive will be reformatted and all data
will be erased.) It is important to back up all data files before using this option.
Before performing a restore operation, please check the BIOS settings.
1 Check to see if Acer disk-to-disk recovery is enabled or not.
2 Make sure the D2D Recovery setting in Main is Enabled.
3 Exit the BIOS utility and save changes. The system will reboot.
Note: To activate the BIOS utility, press <F2> during POST.
To start the recovery process:
1 Restart the system.
2 While the Acer logo is showing, press <Alt> + <F10> at the same time to
3 Refer to the onscreen instructions to perform system recovery.
Jan 11, 2009 | Computers & Internet
Toshiba satellite with windows xp will only show black sreen and wont let windows xp repair
Your description of the symptom shows that your operating system installation has been corrupted. Fastest and easiest way to resolve the Issue using the "Recovery and application disk" (it comes with laptop) to perform full system recovery. I would like to remind you full system recovery will erase everything saved on Hard drive. You can check possible option on http://support.toshiba.com
If you dont have recovery and application disk you get one. You can call Toshiba @ 1-800-457-7777
Please post if you need further assitance
Good Luck
Jan 15, 2008 | Toshiba Satellite A100-S8111TD Notebook
System recovery for compaq
when you finished doing the formatting for the first time please remove the disk from the drive or please dont press any key when the computer prompts you to ....boot from CD.
Dec 23, 2007 | Acer Aspire 3680 Laptop
Compaq Presario 2100T Notebook Logo
100 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
