Question about KitchenAid Dishwashers
I have a dishwasher model KUDS02SR, The dishwasher will not start. The clean button keeps blinking. How do I reset it?
  • sckc1999 Aug 22, 2010
    thank you so much for your speedy solution!! Saved me a service call. Best $6 I spent in a long time
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. To resolve this you will have to reset the console, press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 22, 2010
Start light keeps blinking
More information is needed. What is the make and model number of your dishwasher?
On most models with the digital display: Blinking "Start/Reset" light. This indicates that the dishwasher has been reset and is in the process of turning off. This light will continue to blink for a time period between 75 to 90 seconds depending on the model.
Dec 19, 2013 | Dishwashers
I have a KUDS02SR installed at my cottage and, after connecting it for the season, I noticed a bit of water shooting out the housing where the water enters the dishwashed. I removed and cleaned the...
If this is one of those dishwashers where a hose goes from the electric water valve up the side of the dishwasher, then turns down and sprays the water into a plastic "pocket" on the side of the dishwasher, first inspect the hose for cracks, then insert it into the U-shaped channel that's supposed to hold it into the pocket. Make sure it's all the way in. Anchor it in place with good duct tape. I've seen one or two cases where the original tape went bad and let go or even fell off; then the hose would come loose and start splashing some of the water outside of the dishwasher.
Aug 27, 2017 | KitchenAid 24 in. KUDS02SR Built-in...
The clean light keeps blinking and the dishwasher will not turn on. have tried to push cancel which makes the clean light blink faster.
Hello & Welcome to FixYa
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Apr 16, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
The green light for "clean" is blinking green and
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
Kevin
Mar 07, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
Not able to start dishwasher
Here is a quick check list to do and the instructions to reset the control so you can use it again, if you have trouble with the same blinking let me know and we can dig deeper to fix it.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
Apr 25, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
The springs in the door broke, How do you replace them?
Unfortunately you will have to disconnect the water feed line.
pull out dishwasher 6" to access the springs on each side of the unit
Feb 10, 2010 | KitchenAid 24 in. KUDS02SR Built-in...
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Machine won't start and the START light keeps blinking
A flashing start button shows that the filter is dirty. Remove the filter assembly from the machine. The "tube" can be split into 2 sections fairly simply - do so, and wash each piece under the tap to clean it.
Once the assembly is cleaned properly, select the program that you desire, and press and HOLD the start button for 2 seconds. The wash cycle should begin.
Nov 05, 2007 | Zanussi 24 in. IZZI ALU Built-In...
Dishwashers Logo
516 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
