Question about Home
No bootable device - Home
HP 255 How do I setup bootable disk ? I have tried esc and seled internal cd-dvd room but it doesn't work
On the HP System, you'll need to press the escape key as the system is starting up, and then hit F9 to get to Boot Device Options. Once there, you can set the boot order. After you've set the boot order, you'll also need to make sure that you have bootable files in the device that you've selected as the first boot device.
For example, if you've set the first boot device as CD-ROM drive, and the second is the Hard Disk Drive, then you'll have to make sure that there's a bootable CD/DVD in the drive when you start the system. If no bootable files are found on the first boot device, it'll automatically check the next boot device, which is the Hard disk and start booting from the Hard disk.
GuruAid
May 18, 2014 | Computers & Internet
Bootable devise was not found new
Bootable device not found actually indicates the HDD (hard disk) is no longer recognised and either needs to be re-seated or replaced, if the bootable device error message comes up all the time the it will be a definite HDD replacement.
Oct 09, 2013 | Fujitsu LifeBook AH530 NoteBook
How to go usb boot in poweredge2600
The PE26x0 series was many server-line generations ago, thus booting from USB devices was not available at that time, thus it will not work today either. This includes USB based bootable devices (i.e. bootable USB key, DVD ROM..etc).
Even with the latest BIOS A21 for the PE2650, there is no support for bootable USB devices.
Feb 16, 2012 | Dell PowerEdge 2600 Server
My LaCie hard drive is listed in preferences but it does not boot. Your suggestions?
Have you ensured the Lacie HDD is bootable? IMC, external drives that does not contain boot files or not-formatted in bootable mode cannot boot your device.
Try formatting your Lacie drive into bootable mode. Right click -> Format -> Check "make device bootable" and click start. THis shoudl help.
Mar 05, 2011 | LaCie Computers & Internet
A bootable device has not been detected in Intel 945GNT motherboard
solving of problem of a bootable device has not been detected. Please refer to the product guide at http://support.intel.com/support/motherboards/desktop/
Feb 17, 2011 | Intel D946GZIS Motherboard
The problem is my emachine laptop does not want to start up it is asking me a boot decives wch l dont have, the model for my emachines is E525, where can l get the boot device?
It is asking you for a bootable drive or device.
Your windows OS is your main bootable device, if it is not booting, you must have a error in your windows installation.
Other bootable devices can be your Windows CD, or a USB drive with some bootable media on it.
Try tapping F8 when you turn your PC on, it will give you the option to boot into safe mode, or may also give you repair / restore options.
Try booting into safe mode and do a system restore
Sep 30, 2010 | Computers & Internet
How do i resrore my acer aspire laptop without the dvd drive working?
youe have to have any bootable device either usb bootable drive or any other optical device that can be used as bootable device
Oct 09, 2009 | Acer Aspire 5100 Notebook
A bootable device has not been detected.
Please refer to the product guide.
Jun 15, 2009 | Intel D946GZIS Motherboard
How to create a bootable usb pen drive
please download a software (Eg:- bootflashdos) from softpedia.com.
Using that bootflashdos program you can create a usb pen drive as a bootable device.
best regards,
Krishan
May 09, 2009 | Electronics - Others
Bootable files
When a computer is powered on, the BIOS ("basic input output system") has only a few commands available to it, and the main one is to search for a "boot device" - a storage device which contains "bootable files". The first device it finds with "boot records" is used to load the operating system.
Usually this is the C drive, but could also be a floppy, USB flash memory, or CD.
In order to get the boot records onto a device, a special option must be used when the device is formatted. This boots the boot records in a place where the BIOS knows to look for them.
So, a bootable file (or "bootable device") is a storage device which has been set up with these boot records.
Jul 20, 2008 | Microsoft Windows Server Standard 2003 for...
Home Logo
23 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
