Question about Health & Beauty
Super glue stuck on fingers - Health & Beauty
  • Anonymous Mar 31, 2014
    Fingers stuck together with super glue
  • 8,197 Answers
To remove the supper glue from you skin you need to Immerse bonded areas in warm, soapy water. Peel or roll skin apart; a spatula or teaspoon handle or even a pencil will help. Remove cured adhesive with warm, soapy water (may take several applications). Fingernail polish remover with an acetone base has also been successful for removal of cured adhesive from skin.
Good Luck
Posted on Aug 22, 2010
How can i remove super glue from skin
Hi there David
It will come off on its own after about three weeks as the other layers of skin die off (a natural process). If you want to remove it quicker you can try a number of abrasive tricks.
1. whilst in the bath or shower, use on of those pumice stones ladies use to remove hard skin from heels.
2. Use a ladies nail 'emery board'. This is a sand abrasive on a small stiff card. Use it dry.
3. Go to an auto or paint store and buy some 180 grit waterproof abrasive sheets. Go easy with it, you can use it wet or dry.
Next time, either put hand cream on your fingers, or use disposable gloves before using Superglue. I find the Superglue Jel is easier to handle and not spill. We have all had Superglue fingers at some time :>)
Sep 10, 2014 | Scotch Super Glue Liquid Plus, .07oz,...
2004 back window heat cord came unglued
Ask a windscreen replacing shop for ideas and failing that very careful use of Loctite 401 may fix the problem It is a super glue made for the purpose of fixing rear vision mirrors to windscreens. Ensure you have acetone or nail polish remover on hand in case you stick your fingers together.
Mar 05, 2014 | Cars & Trucks
How to remove super glue from fingers
try washing your hands with super glue remover or nail polish remover it just might work ps can you help me with my problem or ask others to help me.
Mar 02, 2013 | Shopzeus.com Shopzeus Loctite Easy Squeeze...
Plastic shutter button broke. Can release shutter by pushing in the middle but button is gone includeing screw int piece for shutter release. Is this an easy fix?
The only easy fix is to glue with a super glue with the broken part or parts. If this is lost then you need to fabricate a similar type knob to be glued into the slot making sure that glue does no overflow and get the whole shaft stuck.
other wise the original can be sourced or replaced from a worn out/discarded camera or consult the Pentax service for estimation.. to restore it originally.
Jan 25, 2011 | Pentax ME Super 35mm SLR Camera
A toothpick is stuck in the ignition switch. how do I remove it?
This can be tricky, but do it carefully and you can be driving in just a few minutes. If the toothpick isn't wedged super tightly in there, you can take another toothpick, break it in half, and put some wood glue or super glue on the broken end. Hold it against the stuck one until it's bonded, and gently pull it out. Super glue will work best, but you'll have to be really careful not to glue it to the ignition itself. If this doesn't work, you'll have to remove the ignition switch to get it out. Good luck.
Dec 06, 2009 | 1995 Toyota Tercel
Drivers side door lock has been superglued shut
A debonder will soften cured CA (super glue). If parts are bonded incorrectly or your fingers are stuck together, a few drops will dissolve the CA in about a minute. Apply on bonded skin and roll apart fingers. Once stuck, use acetone to clean off softened CA, then wash off with soap and water.
Oct 01, 2009 | 2003 Mitsubishi Eclipse Spyder
How do you reattach the rearview mirror on a 2001 tacoma Thanks
get a rearview mirror glue kit and follow the instructions.
Aug 02, 2009 | 2001 Toyota Tacoma
Razer Krait Mouse's Roller too smooth, it slips from my finger
try putting a little super glue on the tip of your finger and spread it around .. wait for the glue to dry and see what happens .... it works for me and glue will come off
Mar 23, 2009 | Razer Krait Mouse
VCR Tape Stuck
Unplug the VCR, take the cover off, find the motor (probably on the right side of the mechanism) and turn its shaft with your fingers until you have run the tape back out. Now plug it back in and try it again with a scarificial tape. If it continues to fail, replace all the rubber belts in the mechanism.
Hope ya fix it!
Jan 05, 2008 | Panasonic AG-1330 VHS VCR
Video tape stuck
Hope ya fix it!
Health & Beauty Logo
1,041 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
