Question about Dryers
Our roper gas dryer will heat uinitially, but will not stay hot. Seems like it is not reigniting. We changed the thermostat. still doing same thing.
  • 744 Answers
Check the flame sensor and main gas valve coil(s). Also check the ignitor. One of the coils may be weak and act up after the machine heats up.
Posted on Aug 22, 2010
Dryer model Roper RED4340SQ1 rmy heater don't stay hot all the time during a drying cycle is it normal or i need to change it
You may want to do a thorough tuneup on your dryer. I worked on a couple and wrote a pictorial on it. ROPER DRYER TUNE-UP
My Home movie of a Roper dryer with a heat problem:
Sep 06, 2012 | Roper Dryers
Roper rgx4635eq3 warm heat, not drying
You most likely have a defective heating element or thermostat.
May 30, 2012 | Roper Dryers
My Roper dryer heats way too much. I have changed the t stats ang cleaned lint and exaust vent.
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 10, 2011 | Roper RGX4634KQ Gas Dryer
MY DRYER WILL NOT GET HOT THE TIMMER WILL NOT WORK
first things first..understanding that this is a gas dryer, is the gas lever handle on the fuel line open?..also, as there is no heat, does the drum turn?..i wish there was more info into your question..assuming that the dryer operates but the only thing missing is the heat, lets start with the most common problem being a broken hot surface ignitor..(2) bad temperature selector switch..(3) faulty limit switch..(4) bad thermostat..(5) faulty timer..(6) bad centrifugal switch..if all of the above pass their tests, you need to make certain that there isn't a build up of dryer lint around the burner. Sometimes, lint will impede the gas flow preventing the unit from igniting
Dec 12, 2010 | Roper RGX4634KQ Gas Dryer
I have changed my theremal fuse twice in the last three days. it seems that the dryer is getting too hot. When i change the fuse it works for one load, then the burner will not light any more. is there...
Yes, the thermostat needs to be replaced at the same time...
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 10, 2010 | Roper RGX4634KQ Gas Dryer
Roper dryer not heating/drying but still rotates drum.
If electric then the thermostat or the heating element has failed.
If gas: First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
See also: http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Nov 04, 2009 | Dryers
Will not get hot. No heat.
first things first..understanding that this is a gas dryer, is the gas lever handle on the fuel line open?..also, as there is no heat, does the drum turn?..i wish there was more info into your question..assuming that the dryer operates but the only thing missing is the heat, lets start with the most common problem being a broken hot surface ignitor..(2) bad temperature selector switch..(3) faulty limit switch..(4) bad thermostat..(5) faulty timer..(6) bad centrifugal switch..if all of the above pass their tests, you need to make certain that there isn't a build up of dryer lint around the burner. Sometimes, lint will impede the gas flow preventing the unit from igniting.
Oct 23, 2009 | Roper RGX4634KQ Gas Dryer
Roper brand electric dryer will not stay hot
Sounds like it may be short cycling on the Hi Limit instead of the operating thermostat. Only way to be sure is to measure the temp inside the drum while operating with a load. Another way is to measure the voltage across the Hi Limit and it should always be zero. Lots of juice (240VAC) back there and safety is paramount.
Eric
Jun 08, 2009 | Roper REX4634KQ Electric Dryer
Roper Gas Dryer
The first thing I would check is the thermal fuse (#6 on the bulkhead parts break down diagram). Replace if it's open.
Also, the manufacturer recommended to replace the cycling thermostat (#8 on the bulkhead parts break down diagram) too if the thermal fuse is open.
- The part number for the thermal fuse AP3132867
- The part number for the cycling thermostat AP3131939
- Here are the break down diagrams for the Roper dryer Model RGX4634KQ2
"Did it solve your problem?"
Jan 28, 2009 | Roper RGX4634KQ Gas Dryer
Whirlpool Gas dryer ignites when I first turn it on and gets hot but won't stay hot or ignite again.
replace the 2 coils on gas valve after warm up they fail to open valve to reignite burner
Nov 03, 2008 | Whirlpool LGQ8611L Gas Dryer
Dryers Logo
44 people viewed this question
Top Dryers Experts
