Question about Playhut Thomas Tank w caboose
How do you change the batteries on the musical caboose?
Need to buy a replacement REAR wheel for Joovy caboose stroller manufactured in 2006
Sure, just click here: Amazon com stroller rear wheel and go to amazon. There can be find parts for everything. Wish you best of luck. Tim
Jan 09, 2013 | Joovy Caboose Baby Gear
Joovy wheel
Here is a link for parts... http://www.joovy.com
I had the twin engine gg1 2360 repaired and the engines are running in opposite directions
it sounds like whoever did the repair reversed the pickup wires on one of the units.
Dec 20, 2012 | Lionel 18359 Pwc 2360 Gg-1 Engine and...
Memorey full delate some data first
try to delect some massages in your in box, delect some items in your muilt media like pictures you don't really need, music you don't want e.t.c because the memory is full can not save anything again execpt you delect some items you don't need.
Dec 19, 2011 | Northern Tool and Equipment Company...
How do I change the battery in my Realistic musical power horn
hi... if youre talking about the powerhorn that plays the 99 tunes then just slide the back of the hand piece down. it takes 8 x aa batteries. hope this helps.
Oct 20, 2011 | Cars & Trucks
The foot rest is broken
my caboose stroller foot rest it broke where can i replace it
Aug 08, 2010 | Joovy Caboose Blue Standard Stroller
The blade has come loose
Had the same problem myself - another example of a product made to break!
Red Caboose has it spot on. Just a couple of points. The thread on the motor shaft is a 4mm machine screw. the shaft thickens a little bit below the thread (very short) forming a slight collar. I put a washer (slightly larger that the width of the blade) onto this, followed by the blade. You''ll then need a washer to sit into the blade to centre it on the shaft. Follow this with a cup washer (as Red Caboose) suggests or a locknut. Working perfectly now!
Aug 03, 2008 | Bodum 's C-MILL electric blade coffee...
Playhut Thomas Tank w caboose Logo
209 people viewed this question
Top Playhut Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Playhut Craft and Hobby Expert? Answer questions, earn points and help others
