Question about KitchenAid Architect KBFA25ERSS Stainless Steel French Door Refrigerator
Food is Freezing in the refrigerator
We've had this model about 1 year and recently we've noticed that many items stored on the middle shelves are freezing. We've turned up the temperature to 42 as well as to 5 in the freezer with little change. It doesn't seem that how we arrange the food should make a substantial difference. Thoughts?
Also, I should not on this model that the water dispenser froze. The technician came out and said they've had problems with the design and removed the plastic resevoir tank and installed only looping hoses. So far, so good.
  • 70 Answers
I had removed the bulb in the fridge they seem to heat the temp probe and cause refri. to stay running hope suggestion help toward solution
Posted on Jan 02, 2009
My Samsung RL39WBMS fridge on m fridge freezer keeps freezing food. Why is this happening all the time and how can I prevent it?
maybe the fridge is set on a colder setting and if that's not it then stick it on the lower shelves and that might help from not freezing because are fridge is the same way when it is stuck by the coolant fan
Nov 02, 2014 | Refrigerators
Water condensating in refrigerator side
Check for any air leaks within the unit's door and seal area. See if you notice any blockages in the damper door or switch that is between the two doors. Then contact a professional.
Dec 27, 2012 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Our Whirlpool GI5FSAXVY refrigerator is freezing items. The temp control has been set to 38 degrees forever. It appears that things on the lower shelves are freezing more than things on the upper...
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 12, 2011 | Whirlpool GI5FSAXVY Stainless Steel ...
GE profile side by side is freezing fresh food and not cooling items on top 2 shelves
ge profile side by side is freezing fresh food and not cooling items on the top 2 shelves
May 02, 2010 | GE Profile PSW26P Stainless Steel Side by...
Whirpool Refrigerator Door Shelves Not Cold Enough
The door bins are the last place you should keep milk. The door shelves are always the warmest part of the fresh food compartment (of any refrigerator). Sorry.
Apr 25, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Food freezing in refrigerator and water dripping
The problem with the water is that the drain tube is plugged. The easiest way to fix this and to save money is to unplugg the refrigerator and leave the doors open all day. This will thaw out the drain tube without a service technician coming out. That will fix that problem. With it freezing the food on the where its not supposed, This may be a bad cold control. But try unplugging the unit for a day with the doors open and this may fix both problems. (i know it will fix the water issue)
Nov 24, 2008 | Whirlpool Refrigerators
Refrigerator runs too much
if set at 1 and still freezing request that they change the thermastat it is out of calabration
May 24, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
The water filter keeps freezing and food in door and on shelves keeps freezing.
clean lint from coils in back. could also be low on refrigerant (freon)
Jul 09, 2007 | Admiral 26 cu. ft. Side-By-Side...
KitchenAid Architect KBFA25ERSS Stainless Steel French Door Refrigerator Logo
156 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
