Question about GE 24 in. GSD6660GSS Built-in Dishwasher
Dishwasher will not drain / drain valve open - GE 24 in. GSD6660GSS Built-in Dishwasher
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on Aug 22, 2010
Doesn't drain
If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
HERE ARE SOME OTHER COMMON CAUSES:
H Drain impeller. The drain impeller is attached to the pump and pushes the water out of the dishwasher through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit. The drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve. The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced.
Clogged or Improperly Installed Garbage Disposer. If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug needs to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve. The check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball. The check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
HOPE THIS HELPS.
HOPES THIS HELPS.HOPE
Dec 17, 2013 | Kenmore 15129 Built-in Dishwasher
Whirlpool gu1200xtls2 wont drain just stopped
Hello
your Whirlpool dishwasher stopped draining mid-cycle, check your circuit breaker or fuses. The cycle won't complete if the power is interrupted. Reset the circuit breaker if tripped, or change out any blown fuses. Fully close the dishwasher door, and restart the cycle if you opened up the door. If you have not used the dishwasher in a while, the motor may be stuck. Open up the main housing, and rotate the motor until it turns freely. You must replace the motor if it's corroded or won't move since it's unlikely that you can fix it.
Pump
The pump is located underneath the lower rack and spray arm. This component is responsible for pumping water out of the dishwasher once the cycle is complete. If the pump isn't working, verify that it is not clogged with debris. Use a toothpick or plastic utensil to remove food particles from it. Check the pump impeller. If a section of it is broken, get a new pump since the impeller is difficult to fix.
Clogs
Clogs in the air gap or drainage hose prevent water from leaving the tub. Clean these components and the water inlet filters, if dirty. Examine the drainage hose, and straighten it if it's kinked. If the hose is badly crushed, you must replace it. Unscrew the drainage hose from the dishwasher to clean it, but reattach it before you restart the cycle. Run the food waste disposer if it's connected to your Whirlpool dishwasher. Remove the knockout plug from the disposer if you have just installed the disposer or dishwasher.
Drain Valve/High Drain Loop
Whirlpool dishwashers have drain valves with an internal solenoid. This valve opens and closes to drain water out of the tub. If the drain valve is stuck, lubricate the lever, and remove any debris clogging the valve. Remove any objects that are preventing the drain valve from freely opening and closing. If the valve is not working properly, you must replace it. Always install a high drain loop to prevent water from the sink entering your dishwasher. Create a loop of the drainage hose that is at least 18 inches high. Attach this hose beneath a section of cabinetry.
Sep 28, 2011 | Whirlpool Dishwashers
Water drains back into dishwasher from sink or disposal
You've got a broken piece of glass or something holding the drain valve open.
Solenoid operates the valve to drain water from dishwasher into drain line.
When power shuts off to solenoid...valve closes.
If valve is blocked by a piece of glass or toothpick or a sliver of bone...it can't close and draining water from disposal or sink can back flow into dishwasher.
I had a piece of glass caught in mine.
Hope this helps...
Jul 23, 2011 | GE Dishwashers
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Mar 20, 2010 | GE Nautilus 24" Built-in Dishwasher
MY SON'S DISHWASHER WON't drain
Hello there:
Please try these things below my post and click on the links that are available for you ok
I hope that tthis is very helpful for you
best regards michael
Water will not drain from my dishwasher. Investigate these six areas if water will not drain from your dishwasher :
dishwasher_drain-hose.jpg Drain Hose
It is quite common for a dishwasher to not drain because either the drain hose or the air gap (if the unit has one) is clogged up. Drain hose clogs commonly occur where the hose is attached to the main household drain line, or where the hose connects with the garbage disposer. Try removing the drain hose to unclog any debris. Don't forget to reattach the hose before you start your dishwasher again.
dishwasher_pump-repair-kit.jpg Pump Assembly
The pump assembly is comprised of a pump, wash impeller, and drain impeller. The pump ejects the water from the unit, the wash impeller pushes water through the spray arm, and the drain impeller directs the water towards the drain port. Examine your dishwasher's pump assembly. Clean out any debris that may be blocking it. Replace the pump assembly if any of its parts appear to be worn or defective.
dishwasher_belt.jpg Belt
It isn't very common, but sometimes a dishwasher's pump assembly is driven by a belt. If that belt becomes worn and defective, then it cannot properly run the pump that drains your dishwasher's tub. If your dishwasher uses a drive belt, examine it now. If it shows signs of wear, replace it.
dishwasher_timer.jpg Timer
A defective timer could interfere with a dishwasher's ability to drain properly. Test your dishwasher's timer mechanism. If it is faulty, replace it. Keep in mind that you can replace either the entire timer assembly or just the timer's motor.
dishwasher_motor.jpg Motor
The motor plays a key role in a dishwasher's ability to drain water. If your dishwasher's motor is not functioning properly, it will negatively affect the draining capability of your machine. Test your dishwasher's motor for continuity. If it fails the test, replace the motor.
dishwasher_drain-solenoid.jpg Drain Valve and/or Solenoid
In some models, a valve has to open in order for the water to drain out of the dishwasher. This valve is controlled by a solenoid, but it is the timer that decides when the valve should open. If your timer is working fine, check the drain valve and its solenoid. If need be, replace them.
Nov 14, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
DIshwasher doesn't drain. 3-4 inches of water sits in the bottom
Sep 25, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
The dishwasher will not drain after its' cycle.
Your dishwasher uses one of two ways to drain. It either opens a valve on the main pump while it's running to let it pump the water out, or it turns off the main pump and uses a smaller pump with a separate motor to drain the water. You'll know which method it uses by the sound it makes when it drains, provided it's working properly. If it sound like it's running normally when it drains, but maybe quieter, it uses the main pump motor and opens a valve to drain. If it sounds completely different than it does and sounds like a different motor running when it's draining, it's using a separate pump to drain.
If your dishwasher uses the main motor to drain, you'll need to check the drain valve to see if it can open. Pull out the dishwasher, with the power turned off, being careful not to damage the sometimes fragile water line, and find the drain valve. It'll probably be located in between the big motor the drain hose. The valve's electromagnetic operator will be on the outside of the tube where the valve is. Make sure it's connected to the wires and make sure the valve isn't blocked with gunk.
If the dishwasher uses a separate pump motor drain, pull out the dishwasher with the power off, being careful not to hurt the sometimes fragile water line, and locate the drain pump. It'll be connected between the big motor and the drain hose. You may need to disconnect one of the hoses and make sure the impeller can turn freely. It may be blocked with gunk. Make sure the wires to the pump's motor are connected properly.
You may also need to check that the wires are plugged into the dishwasher's controller properly.
If the problem is still happening and you checked either the drain valve or drain pump, it'd help to get an electrical meter, disconnect the the wires from the drain valve or pump, and check to see if you can read a voltage on those wires when the dishwasher is trying to drain. If you can read a voltage, the drain valve or pump probably needs to be replaced or repaired. If the voltage doesn't show up, the problem is in the wires or the dishwasher's controller.
If it uses a mechanical knob that rotates and controls the cycle, you need to make sure the drain wire is connected properly. You could take apart the knob timer box to and replace the switch behind the control wheel that turns the drain function on and off.
If the dishwasher uses a digital controller, with buttons and lights and stuff, Follow the drain wires to the control board in the door and make sure they're plugged in. If you see a small black, blue, gray, or white box cube on the circuit board close to where the wires connect, tap it firmly with a screwdriver. That is a switch controlled by the microprocessor that turns the drain function on and off.
Sep 20, 2009 | Hotpoint Dishwashers
Dishwasher will not drain (water just trickes out) fill is good
Drain valve not opening or pump impeller loose on shaft - is it washing ok?
My guess would be drain valve not opening. It is a 110v solenoid and they get stuck or burn up. New solenoid costs ~$20.00
Mar 26, 2009 | GE 25 in. Nautilus GSC3400J Free-standing...
Dishwasher won't drain
Hi! You have not mention about mfg and model No.
Jan 15, 2009 | Whirlpool 24 in. ADP5966 Free-standing...
GE 24 in. GSD6660GSS Built-in Dishwasher Logo
59 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
