Question about Mitsubishi WS-55859 55" Rear Projection Television
THERE WAS APOWER OUTAGE AND WHEN POWERE CAME ON THE TV DID NOT. THE "TIMER LIGHT" ON FRONT PANEL KEEOS BLINKING AND CAN'T SEEN TO RESET AND GET TV ON
  • 10,594 Answers
If it is Mitsubishi WS-55859 tv then it would have leaky/ dried up capacitors in dm module, replace these bad capacitors to fix the issue.
Capacitors replacement requires soldering work with proper tools and get help of local tv repair shop if you have no experience to do so.
Let me know if you have additional question.
Thanks.
Posted on Aug 22, 2010
I have a Mitsubishi WD-52725 DLP TV and green light (timer) is rapidly blinking after a power outage and set will not turn on. The bulb was replaced a month ago and it has worked fine since. Now it will...
Hello
make a System Reset process. To do this;
If the TV will not respond to either the remote control or the front panel controls and/or will not power Off, press the SYSTEM RESET button with a pointed item like the end point of a paperclip. The TV will turn Off and the TIMER light will flash quickly for about one minute. When the TIMER light stops flashing, you may again turn on the TV. The changes you made the last time the TV was on before you used the SYSTEM RESET button may be lost, however, the changes that were previously saved are not lost.
OK.
Apr 23, 2011 | Mitsubishi WD-52725 52". Rear Projection...
I have a Mitsubishi WS-55909 projection TV. There was a power outage and when the power came back on, the TV won.t turn back on again. There is this light (Timer) that keeps on blinking on the front panel...
Unplug,replug the tv back like 24 hrs later.That the whole tv is resetting itself everythings.Tv now should be working again.If still have the same problems,than ur tv DM power supply board is have dying parts,must repair the tv DM power supply board to fix the tv.
Mar 21, 2011 | Mitsubishi Televison & Video
Power outage at the house when power returned tv will come on but no picture. Blinking light on front panel. What should i do?
Unplug the set for 30 minutes to see if the processor will reset,if it works great, now if there is no change you will need a tv technician to troubleshoot the problem with an estimate.
Dec 30, 2010 | Sony KV-35S45 35" TV
We recently experienced a power outage, but once the power came back on, my TV would not turn back on other then a the timer green light was blinking. I pushed the reset button and also unplugged the power...
The blinking green light is the DM unit in the set booting up like a computer.
Several things can happen here--Research by model number with GOOGLE, model number and problems.
It is often called the blinking green light of death.
The most common problem is 4 filter caps in power supply (they run 7/24 and supply voltage to DM unit fail--also some fuses there.
If you look on the net you will find places that sell kit for this repair.
This is also one of a group of several Mitsubishi sets with this kind of problem--It is not the Lamp!
Some of these models develop so many problems Mitsubishi now sells a chassis replacement--includes power and several boards that develop bad caps.
Understand: Mitsubishi has a long history of caps failing in their sets, it goes back almost 30 years. I have seen older ones where over 20 filter caps were bad.
You can talk to Mitsubishi to see if chassis replacement is available for your set--this came about as a result of the threat of hundreds of people entering a class action lawsuit (several).
If this told you something you did not know rate this solution as very helpful as I do this here for free.
If you have questions make a "comment" here and I will assist you.
SD TECH
Aug 24, 2010 | Mitsubishi WD-62725 62" Rear Projection...
Blinking light won't stop. It does not reset. Please help. Thanks
A quick fix that might get that out the way. Reset the lamp timer. Other wise you might be looking at a bad ballast. hard to tell w/ out knowing which indicator light is on.
Apr 21, 2010 | Mitsubishi WS-65869 65" Rear Projection...
Tv will not turn on,just has the flashing green light.after reseting the tv via the reset button the same problem persits
try hitting the sleep button over and over it reset my timer and I have had no more blinking green light problems
Nov 15, 2009 | Mitsubishi WD-62725 62" Rear Projection...
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Will not power on.
my tv keeos shutting off with red blinking light how do i fix it?
Dec 06, 2008 | Toshiba TZ50V51 50" Rear Projection...
Mitsubishi WS-55859 55" Rear Projection Television Logo
48 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
