Question about Cub Cadet Garden
The pto quits working after a few minutes of mowing. After sitting for awhile it will work again, but just for a few minutes again.
  • 7 Answers
Check the drive belt , it is probably worn and polished, it will grip a little when cool but will slip as soon as it gets hot.
Posted on Aug 22, 2010
Troy-Bilt Colt XP. Start engine and begin mowing and everything is fine. After a few swipes on the yard, 2-3 minutes, PTO shuts off. turn off and back on works shortly. PTO clutch getting hot???
electric pto clutches get HOT (not warm) for only a few reasons
(1) worn out friction disks inside
(2) foreign object(s) not allowing clutch to fully engage a good blast of high pressure air knocks out most stuff , if let go to long this leads to 1st reason
Jun 29, 2015 | Garden
While mowing along my blades stopped turning. i shut the pto off and tried again. i noticed the battery light comes on when i turn the pto on. i let the machine cool off and tried again. the pto turns on...
Did it work right after you changed battery? It sounds like your regulator/rectifier isn't recharging your battery. When the battery isn't charging properly the pto wont work for long. If you have a multimeter, hook it up to battery while unit is running and check voltage on battery. When idle is high you should see more charge and vice versa. Please exercise caution when doing this. Hope this helps.
Aug 01, 2013 | Garden
Blades fail to engage (using pto) after tractor has been running for awhile.
bad wiring to the charging system or the alternator is bad
May 03, 2012 | Garden
I have a craftsman z7000 mower. When I engage the PTO the blades start working but after about a minute they stop, like I turned the switch off. I waited a minute and tried again, same thing, it worked...
something is loose, pto switch connectors maybe loose or corroded, wires at the pto, bolts on the pto there should be three of them. hope this helps Tim
Apr 24, 2011 | Garden
I have an old Cub Cadet lawn tractor model 2155, where the PTO clutch stops working after about 15 minutes of mowing. It will re-engage after it stops, but will only mow for a couple hunder feet before it...
I have a Cub Cadet 2155 lawn tractor that mows great, purchase in 1999, however it started heating up about an hour into mowing and then I have to shut it down until cools. I have replaced the air filter & that did not work ?
Help.......Thanks
Aug 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
When I engage the PTO clutch, the amp light comes on my 1641 cub cadet. I have new battery, pto clutch and stator. I can mow for awhile, but when I turn the PTO clutch off, I can't engage it again because...
You need to repair either repair a poor connection from the alternator[stator], or replace the rectifier/regulater.Some systems have a inline fuse check that first.
Nov 07, 2009 | Garden
Pto stops working while mowing
is this by any chance a husqvarna or cub cadet/yardman? ran across this problem in all three. they use a cheaply made clutch that's prone to bearing failures. the clutch [not cheap, just cheaply made] needs to be replaced, the pto switch needs replaced AND the little relay under the dash - if you replace the clutch and switch and not the relay, it'll keep taking out the switch and that can get expensive in a hurry
Aug 24, 2009 | Garden
The electric clutch on my cub cadet lt1045 does not stay running
I had the exact same issue early this mowing season on a LT1045 with 184 hours on it. On a wild hunch I lifted the seat and simply sprayed the PTO shut-off safety switch with electronic contact cleaner/enhancer and have had to problems since.
Jun 29, 2009 | Oregon Scientific Electric PTO Clutch for...
Craftsman 19.5 riding mower starts runs quits no power
When you let it sit did you remove all the fuel or add a additive? If you did not then I would recommend that you remove all the fuel and add brand new fuel to your system. Gasoline only last for about 3 to 4 months before it will start to go bad and this sounds like your problem
May 22, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Garden Logo
160 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
