Question about Hotpoint Kitchen Ranges
Gas water heater with sealed front pilot lights turn to on lazy flame briefly goes out then pilot will not relite for awhile
  • Hotpoint Master
  • 43,501 Answers
If you have a propane or LP heater check the gas, you have run out... if you have a natural gas unit then check the regulator it has gone bad...
heatman101
Posted on Aug 22, 2010
RELAINCE 606 GAS WATER HEATER. WE RECENTLY HAD THE BASEMENT FLOOD DUE TO ALL THE RAIN. WE NOW HAVE NO HOT WATER, I AM SURE DUE TO THE FLOODING, BUT CANT GET THE PILOT LIGHT RELIT! HELP
If keeping the thermocouple bypass pressed keeps the gas flowing to the pilot but the flame goes out when it is released in spite of keeping the flame going the customary amount of time, then either the flame isn't powerful enough to reach and heat the thermocouple bulb, the pilot flame or the bulb is out of alignment or the thermocouple is faulty.
If the flame is weak it indicates a blockage in the jet or the supply pipe.
Sep 08, 2017 | The Kitchen Appliances - Others
When you push in the gas the red button the flame will not stay on
CTRL Z TV ' Volume 1: Introduction to the problem and ...
? 4:49
https://www.youtube.com/watch?v=k1qM-ZbYdWo
Dec 16, 2013 - Uploaded by CTRL Z TV
Which will take you from troubleshooting the problem, getting familiar ... Ctrl z TV, Pilot light won't stay lit up, Gas water heaterproblems, Gas water ... If your water heater has a thermal resetbutton, press & hold it for up to 4 ...
Pilot Light Easiest Way to Light it When it Goes Out - YouTube
? 3:06
https://www.youtube.com/watch?v=9bdLuGKaCXI
Sep 24, 2011 - Uploaded by Mixed Martial Animations
Here's a simple solution to a common water heater problem. ... the instructions says turn off the gas valve when lighting the pilot... i... 4 Steps, Set too pilot, hold down red button, push ignitor till pilots lit, ... if the flame will not stay on no matter how long youhold the button down, your thermocouple is bad..
Nov 29, 2015 | Heating & Cooling
Why doesn't the pilot stay lit?
Why Does My Gas Furnace Pilot Light Keep Going Out?
santafeair.com/blog/.../why-does-my-gas-furnace-pilot-light-keep-going-...
Jan 10, 2014 - The thermocouple is the copper rod you see the pilot flame hitting. It's a safety device that controls a small valve to shut off gas going to the pilot ...
Aug 11, 2015 | Kitchen Ranges
I stopped the device. I don't know how to restart it.
Hold in your pilot button, then push the spark button repeatedly to light your pilot. Once its lit, hold that pilot button in for 30 seconds to heat your thermocouple. once its heated, release the button, and slide the slider to burner position. Turn on hot water fixtures to get the unit to light
Dec 31, 2013 | Bosch AquaStar Indoor Natural Gas Tankless...
I have a Mr Heater infra red propane wall heater. My problem is it turns itself off (pilot light) after running for an hour or two. I have no problem getting it turned back on but for some reason it d
Your pilot flame should be blue with a small yellow tip, and it should cover the thermocouple (a small rod in front of the pilot light). If the flame is too small and doesn't cover the thermocouple, it may be adjusted too low, or you have low gas pressure or you have a leak in your gas line coming in to the heater. If the flame looks like a lazy yellow flame, you are probably not getting enough air to the flame. Check that your air openings around the pilot are not clogged up. If the flame looks like a waving blue flame then you probably have excessive draft at the pilot. If the pilot flame looks good and covers the thermocouple, then the thermocouple might be bad. Best of luck. I hope I have helped.
Nov 23, 2013 | Heating & Cooling
Why does my pilot light on my hot water take not stay lite
It depends on many factors, including brand, type of heater, age, gas pressure, maintenance, venting, proper installation of thermocouple, bad thermocouple, air intake cleaning, if the flame is clear blue etc.
Copy following link to read more:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#pilot
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 20, 2012 | Water Heaters
Pilet light goes out after water is heated and has to be relite how to fix
try tapping the pilot assembly when you have it lit to see if the flame gets straight the flame cannot be lazy like dancing around its gotta be dirrect if it still goes out get a new thermocouple
Aug 17, 2010 | Heating & Cooling
Pilot lite went out and will not relite
The thermocouple is not functioning. The t/c is the small (sensor) tube that the flame touches and should have a small copper tube (capillary) extending to the gas valve. (IMPORTANT: The capillary tube should not have any kinks or crimped places...Only gentle bends. A crimped tube will require t/c replacement.) The flame will deposit a coating (minerals) that will insulate the t/c and prevent it from working. Clean the sensor with steel wool, fine sand paper (emery board) or scotch pad. Now try to relight the pilot making sure the t/c sensor is contacted by the flame, if not, shut off gas and adjust. Once aligned and contacted by pilot flame, hold for a minute, allowing the t/c to warm up fully and signal the gas valve to operate when knob is turned from pilot to operate.
Jul 16, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Pilot turns on but when I switch to turn it on,
When you light the pilot, are you holding it down for 30-60 seconds. When you release the pilot button, does the pilot flame stay lit? Or does it only go out when you turn the knob to on position. Make sure the pilot flame is heating the end of the thermocouple and that it's a strong blue flame, not a lazy yellow pilot flame. Make sure the tip of the thermocouple is not burn't off, which usually happens with lazy yellow pilot flames. Replace thermocouple is nothing else works.
May 13, 2010 | Coleman 5040-751 BackHome Open Flame Patio...
Kitchen Ranges Logo
111 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
