Question about Vacuums
I'm looking for manual for a simplicity easy lock serger 804.
    Problem Solver:
  • 6 Answers
Copy this entire link: http://web.archive.org/web/20060508095821/http://www.simplicitysewing.com/ftp/whitepapers/804.pdf Enjoy!
Posted on Aug 04, 2012
  • Donna Talipsky
    Donna Talipsky Aug 09, 2016
    I already had this manual. Everything I have read says this machine does a Cover Stitch, but nothing in this manual mentions a Cover Stitch.
  • 107 Answers
Recently I found the manual for Easy Lock 804 on eBay...
Posted on Dec 04, 2010
  • 744 Answers
See this link:
Also see this link if you need additional information:
http://www.simplicitysewing.com/manuals/
Posted on Aug 22, 2010
HOW TO CANGE BELT ON SIMPLICITY 9.8 VACUUM
This is pretty easy. Turn vac upside down, remove brush cover, brush with belt on it pops out on each side. You must get the exact replacement belt so take your model number and any other numbers to vacuum repair shop. The belt around brush then around motor spindle, replace brush and cover.
Jun 20, 2014 | Simplicity Vacuums
What is the difference between a sewing machine and a serger?
Well..... A serger (or overlock) sews a different, and usually more complex stitch. Where a sewing machine usually only uses two threads to make the stitch, a serger can use two, three, four or even five threads and will sew around the edges of the work piece, as well as trimming the edge of the work just ahead of the sewing area, or as you feed the work in, the trimming takes place first. Sergers also make a stronger seam, attributable to more thread / stitching in the seam. Sergers are versatile and quick, but one drawback is the fact that sergers make a chain stitch instead of a lock stitch, like a machine with a bobbin, and lock stitches can be pulled out, like the stitching that used to close dog food bags and bags of charcoal. A lock stitch is just what it sounds like, it can't be pulled out. You only get a lock stitch with a machine that uses a bobbin, and sergers don't use bobbins. That fact makes serging desirable for the speed of production. Changing bobbins takes up a lot of time, even if you are using pre-wounds. Hope this helps!
Sep 10, 2011 | Vacuums
Simplicity F3500-- how do I get the bottom off to change the belt?
To change the belt on the Simplicity F3500, unplug the vacuum and turn it upside down. There are two tabs (one on each side) behind the beater bar that hold the cover on the vacuum. Press these tabs inward and lift the bottom plate away from the unit.
Then remove the brushroll and the worn or broken belt from the pulley on the side of the brush roll and the drive shaft. Loop the new belt over the driveshaft and the brushroll. Replace the brushroll in the housing and turn it by hand. Make sure that the belt is seated on the driveshaft and pulley with no twists. Also check that all of the rotating parts will move.
Then put the bottom cover back on by aligning the back hinges and then pressing the plate down until both sides click.
For pictures of the cover removal process, look at page 15 in the manual. The direct link is http://www.simplicityvac.com/about-my-simplicity/manuals/FreedomManual_Update0803.pdf . Most Simplicity vacuum manuals are available at their support site: http://www.simplicityvac.com/about-my-simplicity/manuals/ .
I hope this helps.
Aug 11, 2011 | Simplicity 7250 Deluxe Vacuum
I can't understand how to thread lower looper (red) The instructions on the cover are very unclear
Sounds like you are trying to thread a serger or overlock. I would be helpful if you offered up the model number. However, a few things I've learned.
Sergers MUST be threaded in ORDER. Failure to do so will break your looper (had it happen)
In other words if you break one of the 4 or 5 threads... you have to un-thread all the other points and begin with Thread 1, then do thread 2, etc., etc.,
If you would give me the Make and model number of your serger... I will be happy to see if I can find your manual and threading guide for you.
Mar 11, 2011 | Vacuums
Pro 5 dc elna lock serger manual
I need instruction how to do roll hem on my pro 5 thread Elna serger 9000.
Feb 20, 2011 | Vacuums
Do you have a repair manual for a babylock serger BL3-407?
Do u have a repair manual for a baby lock serger.bl3-407
Feb 10, 2011 | Vacuums
Hi I am looking for ez lock serger model ez100 manual could you help?
http://www.scribd.com/doc/17112301/EZLockEZ100Manual
Feb 04, 2011 | Vacuums
I'm looking for a manual for a Simplicity SL600 serger
Hi vernasgirl,
Did you ever find the manual online? I just bought an sl 600 too and need one. Also the model should have two needles correct?
Sep 27, 2010 | Vacuums
I have a Baby Lock Serger Model BL4-605 Serger and can't find the Instruction Manual. Where can I find one? Also, I need a threading guide now, can you help?
I actually have the same model. I have the manual, but it is not very helpful. It does give instructions on treading, but not much else. You can download this manual online and it will cost at least $10.00.
Sep 13, 2010 | Vacuums
Vacuums Logo
266 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
