Where is the main overflow pipe on my goodman furnace ac model number A24/10
  • 139 Answers
Follow the white pvc drain pipe to it .the over flow is next to the drain pipe.. this should have a cap over it .if your furnance is leaking water the drain is clogg.. use a shop vac to unclogg the drain pipe where it drains at the floor drain
Posted on Aug 23, 2010
Model no. pcbbf112 goodman furnace, blinking lights.
Turn main power off to reset unit then back on. If unit still blinking count the number of blinks and there is a list of codes on the inside of the cover.
Oct 05, 2013 | Goodman GMS90703BXA Heater
Overflow pipe
In most cases, they do not come with a overflow valve, That is a addon that most companies install when they do the install. They can be purchased from most ac suppliers I recommend the SS-2 or SS-1 safety overflow switch, comes with two wires you can tie into your low voltage wiring to your thermostat.
Hope this helps.
Jul 06, 2013 | Goodman Manufacturing Goodman CAPF1824C6...
I have a goodman ckl30-1l AC unit. The control board for the furnace has went out and I'm trying to find the model number for it. Could someone help me out please?
the best way is to contact Goodman and ask them for the model, in base from the detail that you have. If you have some wiring diagram or instruc. manual you can identify it. if you do not have downloa give your model +mark+serial number and proceed:
www.fitness.manualsonline.com + www.retrevo.com
God bless you
Jul 26, 2012 | Heating & Cooling
We have a Goodman GSK9 gas furnace. There is a weep hole on the PVC outside of the house, that in the winter develops a vry large icicle against the house and has damaged our wood siding. When we plugged...
Hello Jmranes,
It sound to me like your getting alot of condensation on your exhuast pipe and a weep hole was drilled to "BAND AID" the issue. These is not how 90% plus furnaces are installed. If you are referring to the outside intake and exhaust PVC piping, then there shouldn't be any weep holes. When the furnace is properly installed, the furnace comes with a condensate kit (refer to owners manual) that is mounted on the side of the furnace and all the condensation that collects overflows and should be piped directly into a floor drain. As for the intake and Exhaust for side discharge application, the Exhaust PVC pipe should come out through the side of house and immediate goose neck up (90 degree) with a straight piece of PVC pipe about 2' to 3' or so in length, then a final 90 degree PVC fitting on that so the exhaust blows out. As for the intake, that also comes out the side of the house about 2" to 3" inches parallel to the Exhaust but should only be a 90 degree PVC fitting facing down. The idea here is making sure the furnace doesn't suck in exhaust air. Also, making sure proper size pipe was used. Both outside pipes should be open to atmosphere. I hope this helps.
Nov 12, 2017 | Goodman Heating & Cooling
I need the venting specifications for CAPF3030B6AA furnace that the city inspector is asking for. Do you now where i may get it?
Adhiinc, the model you posted is for an AC coil made by Goodman. You will need to post the Make and Model number for the air handler/furnace that this is connected too. You can find the model number if you remove the front panel and look on one of the sides for a label. Thanks and good luck!
Apr 07, 2011 | Heating & Cooling
I have a Goodman system and I have water leaking from the the small box next to my furnace. I have what looks like 3 lines running from unit to this box. One is a small copper one, another is a line...
the clear plastic hose is the condensate drain .. indeed they clog frequently .. lthat will allow water to overflow the pan that is desined to capture condensed water from the evaporator.. the plastic hose and the pipe it is attached to need to be cleaned out periodically ... allowing water to overflow can damage other things so its important to get the drain cleared .. however that drain has little to do with cooling efficiency .. your lack of cooling performance could be another problem ... sometimes the evaporator coil gets clogged (large finned unit behind where the overflow hose is attached inside furnace) .. that has to be cleaned once in a while but is tricky to do ... how often depends on how good the furnace air filter is and how often its changed ... as the evaporator becomes clogged with dust the cooling efficiency goes down .. same with the outdoor unit ... you have to wash out leaves and such periodically from the condenser coils .... if every thing is clean but the cooling efficiency is still low then have the unit checked for refrigerrant pressure .. it could be low .. of course make sure the furnace filter is not clogged ... also for cooling make sure all of the registers are open ... closing some can reduce overall efficiency ... make sure the outdoor unit fan is working properly ..
Jul 25, 2010 | Goodman Heating & Cooling
Goodman furnace model # GMNT100-4B On vacation neighbor checked house house filled with gas. He shut off main and furnace. Came home turned on gas to everything except furnace. All good. Furnace will not...
from my experience with goodman units ,it could have been a gas supply problem there are so many protective sensors that i dont think it is the unit by the way is it electronic ignitor or pilot
May 14, 2010 | Goodman GMS90703BXA Heater
Water leaking out the bottom of my Furnace
One of the drain tubes (overflow) is plugged. Unhook each one and clear them of any debris.
Dec 20, 2009 | Goodman GMS90703BXA Heater
Goodman GMP100-5 Rev Furnace Manual
I don't know where you are located, but there is a Goodman distributor in Sacramento, CA. Also in Ontario CA. They are a distributor so they may be able to help you or tell where to find someone who will help. Goodman is also known as GMC or Janitrol.
Jan 07, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
212 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
