Question about Dryers
Diagrams how to change fuse in kenmore 80 series dryer
  • 744 Answers
If you're talking about the thermal fuse (the only one it has), you will need to remove the back of the machine. The fuse has two wires attached to it and is usually white in color. Make sure the power is off before attempting to service the thermal fuse. You will also have to disconnect the vent at the machine.
Posted on Aug 22, 2010
Knemore Series 80 Dryer - Blows Thermal Fuses, Humming Noise
The heating element is shorted to ground. You will need to replace the heating element and the thermal fuse, both available at the link below.
Heating Element $40.77
Thermal Fuse $6.99
Mar 02, 2012 | Kenmore Dryers
110.64872400 kenmore dryer 80 series. dryer makes humming noise when start button is pushed, can turn drum manually. please help
The humming noise is most likely coming from the timer motor and not from the drive motor. This characterizes a problem with a blown thermal fuse which is wired in series with the drive motor and located on the blower housing. Power to the motor is cut when the thermal fuse blows open and consequently the drive motor cannot run. No dryer function works when the drive motor cannot run.
Unplug the dryer or disconnect power then pry the lower access panel off with a flat-head screwdriver as shown.
Remove the screw from the lint duct bracket and remove the bracket. Remove the two hex-head screws from the lint duct and remove the duct to access the thermal fuse and the cycling thermostat.
Click on the links below for the detailed troubleshooting of this problem and the parts diagram. The cycling thermostat(part number
3387134) must also be replaced once the thermal fuse(part number 3392519) is found open.
Whirlpool and Kenmore Electric Dryers Not Starting
Kenmore Electric Dryer Model Number 110.64872400 Parts Diagram
Aug 14, 2011 | Kenmore 73952 Gas Dryer
I have a kenmore dryer 80 series it only makes a lite sound when I push the start button. I won't come on. The power is good.
The Kenmore 80 Series of dryers are consumer grade dryers for home use. As with most home appliances, the Kenmore 80 series dryers will occasionally not work as intended. If a problem occurs with your dryer, however, you do not necessarily need it serviced by a technician. You can attempt to troubleshoot and fix any problems with your dryer before contacting a technician.
  1. Kenmore 80 Series dryers may not run for several reasons. First, make sure that the power cord is plugged into a working power outlet. You may need to plug a different device into the outlet to check that it is receiving power. If the second device does not run on the power outlet, you may have blown a fuse or tripped a circuit breaker. Check your fuse box or circuit breaker box and make the change as needed.
    Next, make sure that the dryer door is fully shut. The dryer will not run with the door ajar.
    Finally, check that the "Start" button was fully pressed and that a cycle was chosen on the machine. If you do not choose a cycle for the dryer, it will not run.
  2. If your Kenmore 80 Series dryer does not heat up during use, check that a heat cycle has been chosen for the load. There are several different dryer cycles you can choose, some of which do not use heat. Make sure that you have chosen a heated cycle.
    As above, check that you have not blown a fuse or tripped a circuit breaker. The dryer may use more than one fuse or breaker: one is used to power the drum, and the other for the heating element. Make sure that both fuses or breakers are in working order.
  3. There may be times when Kenmore Series 80 dryers do not fully dry your clothes. When this occurs, check the lint screen and clear out any lint. The air may not flow as well if the lint screen is clogged.
    Next, check to see if the exhaust vent is clogged. Lint and other particles may clog the exhaust vent over time, restricting air flow and making it more difficult to dry your clothes. To check the vent, run the dryer and hold your hand under the vent. If you do not feel any air flow, clean or replace the vent.
    If you used cold water to rinse the clothes it may take longer than normal to dry. The same is true if the load of laundry is very wet or is filled with items that are very absorbent.
    Finally, check the load size. The more clothes in the load the longer it will take to dry. If you want to reduce drying time, separate the clothes into piles of light and heavy items and dry them separately.
  4. please comment on these solution by saying how helpful.
Dec 22, 2010 | Kenmore Dryers
Kenmore series 80 dryer, ryns with no heat. i
that is ur glow bar or igniotror that is common,, check ur ignitor, thermal fuse, or secondary gas coils, those are what are usually wrong with no heat on gas dryers
Feb 03, 2010 | Kenmore 62802 Electric Dryer
I have a Kenmore 110 60812990 80 series dryer
bad heater box fuse,get the model number from inside the dryer door,and go to your local appliance parts store and give them the number and they will get you a thermal fuse kit,remove the back of dryer and you will see the heater box on the right side
Feb 02, 2010 | Kenmore 64742 Electric Dryer
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
Kenmore 400 series dryer will not heat?
LP dryer flame goes on for a few seconds and them goes off
Oct 27, 2009 | Kenmore 73952 Gas Dryer
Location of the thermal fuse on the kenmore gas dryer 80
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 03, 2009 | Dryers
Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Mar 18, 2008 | Dryers
Dryers Logo
165 people viewed this question
Top Dryers Experts
