My Warfdale 19" LCD TV doesn't keep the channels tuned, every time I turn it off it has to do the auto tune before I can watch any channel. The problem also happens if I put the TV into standby, however if I change the source, eg to my HDMI input for my PS3 the channels are still tuned when I switch back to the TV.
  • Charles Aug 23, 2010
    Thanx for the advice, I'll check it out.
  • 5,138 Answers
Problem will be either bad capacitors that are vented or puffed up on Top or you need to replace the main board the one you connect cable to Encompass Parts Distrbution might have it on stock
1-800-638-3328
Posted on Aug 23, 2010
  • ladywinn
    ladywinn Aug 24, 2010
    If it turns out to be Main Biard I have found them on EBay alot cheaper then what companys want for them Part number should be printed on Board and I have seen sometimes resoldering Board will clear out the problem.
I lost a few digital channels on an old LG LCD, tried to auto tune but could not retrieve. Followed a tip online that said to auto tune with the antenna cable which will wipe all saved channels, once...
hi your signal could be to strong, on the aerial cable the thin brad rap 4 strands around the center solid pin then retune in auto, if this does not work you may to manual tune it in, or get someone to check your aerial and you could try a firmware update on your tv hope it helps
regards
shaun
Jun 29, 2014 | Televison & Video
Channel search problem
The mains system memory IC to your TV has damaged. Replace it.
Aug 12, 2012 | Konka K1938U 19" TV
I have a Grundig XENTIA 82 FLAT MFW 82-430/8 TV, everytime i turn it on i get a blue screen & the child lock nb to fill in, so i have to type the nb 7038580 to watch tv... how can i cancel this koz...
If this is happening on all the channels I think you will need a total reset. If so open menu and check the settings for child lock when you manually tune. An option is to reset the channels once again after the lock is opened. Choose a new channel scan to reset the memory. However if the lock seems to be only on specified channels you can open the settings of the channel and unlock on the menu.
Oct 16, 2011 | Grundig GU19WDVDPCX 19 in. LCD TV
How to tune the channels
You can tune the channel by Auto programming button in the setting area and then press Auto Scans all available channel option to tune the channel automatically, try it and still facing the problem read the manual carefully for better understanding or you can also call the online customer care available in the manual.
Kindly rate my help++ Thank you
May 09, 2010 | Philips Magnavox MT1905B 19" TV
19" LED TV INSIGNIA HD
I have one of the same tvs. Start by going under menu,setup,tuning band and set it up for antenna. When you get that far put in auto channel search. To see how to get best reception where you live go to http://www.antennaweb.org
Comment if you need any further help
Mar 17, 2010 | Insignia NS-LCD19 19 in. LCD TV
NO SIGNAL . CANNOT FIND ANY CHANNELS WHEN I
You need to use the setup menu to specify the tuning band (specify whether you have cable or an over the air antenna) before doing an auto channel scan.
Dec 01, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
Vizio 32lcd turns itself off on certain station
Do a full channel scan again. It should solve that problem.
Jun 14, 2009 | Vizio VW32L 32 in. LCD HDTV
Free view
The retuning process is as follows:
  1. Press the [i+] button on the remote control to display the DIGITAL INFO menu.
  2. Press the BLUE button to display the MAIN MENU.
  3. Press the UP or DOWN buttons to highlight AUTO TUNING then press the OK button to display the AUTO TUNING MENU.
  4. Press the RED button to start the auto tuning process for all available digital channels.
  5. Wait for the process to complete.
If you wish to CANCEL the auto tuning process whilst it is processing then press the BLUE button at any time.
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
Sep 19, 2008 | Sony 32 in. LCD TV
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
