Question about Nintendo Wii Console
I get an error code 51330 when the "search for access point" is selected what does the code mean? can you help me out? Thanks
    Genius:
  • 1,234 Answers
Error Code: 51330 This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
  1. Are you using WEP or WPA security on your router?
    1. Log into the router using the default IP (consult your router's manual for assistance)
    2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
    3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
    4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
    5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
    6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
    7. If you are using WPA, the Wii console is compatible with the following types:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
  2. If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
    1. From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
    2. If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
    3. If the Mac address filter was disabled, then continue troubleshooting.
  3. Check Nintendo's router info for special notes, if available, for your router.
    1. Click here to go to our Wireless Router lookup page.
    2. Use the drop-down box to select, if available, your router manufacturer.
    3. Click on your router's model number, if available.
    4. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
  4. Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
  5. Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response.
Posted on Aug 27, 2010
What does error 51330 mean and hiw do i correct it i cannot connect to netflix
This error code indicates the authentication process between the Wii and wireless router or access point failed. This is often caused by the router refusing a connection because an incorrect security key (also known as a WPA or WEP key) has been entered into the Wii Internet settings. hope this helps.
Jun 25, 2017 | Video Game Consoles & Games
Tip
Nintendo Wii Error Code 51330 usually indicates that the WEP/WPA key you set on...
<span><span style="font-weight: bold;">Nintendo Wii Error Code 51330</span> usually indicates that the <span style="font-weight: bold;">WEP/WPA</span> key you set on your Wii is not the correct one to gain access to your <a href="/../support/t9472672-39_t_connect_wii_netflix_ger_error#"><span>router</span></a>. <br /><br />When you setup a router for wireless internet, you usually set a WEP key or by default one is set. This is basically a <a href="/../support/t9472672-39_t_connect_wii_netflix_ger_error#"><span>security</span></a> key(<span style="font-weight: bold;">password</span>) that you set so any device that wants to use your <a href="/../support/t9472672-39_t_connect_wii_netflix_ger_error#"><span>internet</span></a> has to enter correctly in order to gain access.<br /><br />If you know your router security key, go into your <span style="font-weight: bold;">Wii network settings</span> and make sure it is entered correctly. Click <a href="/../support/r9198848-connect_nintendo_wii_internet">here</a> to read my tech article on how to configure your Wii's network settings. <br /><br />If you do not know the security key of your router, then read my other article by clicking <a href="/../support/r9359087-find_wep_key_router_router_security">here</a>. This article will go over <span style="font-weight: bold;">how to find the router security key</span> or if need be, set one.<br /><br />Be sure to check out my other <span style="font-weight: bold;">Tips</span> by clicking on my profile name and then clicking "<span style="font-weight: bold;">Tips</span>" at the top left. <br /><br />Regards,<br />G33k<br /><br /><br /><br /><br /><br /><br /><span>Keywords</span><br style="font-weight: bold;" /></span><span style="font-weight: bold;">Nintendo Wii Error Code 51330, error </span><span style="font-weight: bold;">51330, Wii </span><span style="font-weight: bold;">51330, Wii error </span><span style="font-weight: bold;">51330, Wii network settings, can't connect Wii to netflix, Wii netflix, Nintendo error code </span><span style="font-weight: bold;">51330, Wii code </span><span style="font-weight: bold;">51330</span>
on Jun 14, 2011 | Nintendo Wii Console
How do i set up a wifi conection from my wii to my modem please
Nintendo's wireless connection will only support WEP security. So before connecting it wirelessly, check your wireless router/wireless access point and make sure that IF it has a wireless security configured on it, it's on WEP. So the wireless security should either be Disabled or at WEP. You can check these options on the router's Web UI. If you have a Linksys router, I could help you with it.
follow these steps:
1. Setup Screen > tap "Nintendo Wi-Fi Settings".
2. Select a "Connection slot".
3. Tap "Search for an Access Point. (This will open a list of wireless networks detected.)
4. Select your network (or any network you want to connect to) and connect to it. It will ask your for the network key or WEP key if you have it setup on the router.
Nov 13, 2011 | Nintendo Wii Console
How do you set up Internet on the wii?
To access the internet with your wii console you'll need either a wireless router/gateway, or a wii wired LAN connector.
1. Power on your Wii console
2. Access the "Wii Setting" menu by selecting the circular wii icon in the bottom left of the screen and then choosing wii settings.
3. Use the arrow on the right of the screen to move to page two, then select "internet".
4. Select "Connection 1 ' None"
5. Choose "Wireless Connection" (assuming you have a wireless router), then select "Search for Access Point".
6. Wait for your wii to scan, then select your wireless network, and if prompted enter your wireless network password/key. Then click "OK".
You should now be able to connect to the internet. If your Wii runs a connection test and it proves unsuccessful it will display an error code. If you get Error Code 51330 or 52130 this means the password you entered does not match the password on the wireless network you are attempting to join. A list of all other error codes and what they mean can be found here: http://www.nintendo.com/consumer/systems/wii/en_na/onlineErrorCodes.jsp
Jul 24, 2011 | Nintendo Wii Console
I am trying to connect Netflix to my Wii and I keep getting error code 51330 and 51331. I don't know what these errors are. I am trying to set up with wireless internet.
From Nintendo:
Error Code 51330, 51331, and 51332
    It appears that the wireless security pass code for your home network may have been changed or is entered incorrectly on the Wii console. Click here for more information about WEP and WPA security, including how to access the settings for your Access Point.
If your wireless network password isn't wrong, reply. Hope this helps somewhat.
Jul 21, 2011 | Nintendo Wii Console
Error code 51330 on netflix
Error Code 51330: This means the security code you entered into the wii is not the same one your router is set to. Look in your router's settings and try again. Here is a link that may help.
http://www.nintendo.com/consumer/systems/wii/en_na/netflix/print.jsp
Thanks for using FixYa
May 13, 2011 | Computers & Internet
I'm tryin to get into my Netflix but error code 51330 keeps poping up and denying me access how do i go about tryin to fix this
This code means a network connection cannot be established. Check you connection settings to make sure you are connected to the internet. If you are connected your router may be having some problems establishing a connection with your wii. You may have to reset your router to factory settings you will need to read your routers manual how to do so. Every router has a different way to reset it to factory settings it can be as simple as pressing a button behind the router or having to go into the software settings and doing it from there. If you reset it try to connect your wii to your router again by doing this: Step 1: Turn on Wii Step 2: Select the Wii button on the left side of main menu.
Step 3: Select "Wii Settings"
Step 4: Scroll until you see "Internet" and select it.
Step 5: Select "Connection Settings"
Step 6: Search for an open connection by "Connection 3:None button"
Step 7: Select "Wireless Connection" and search for access point.
Step 8: Choose the access point desired from the list and save the settings.
Step 9: Test your connection. If successful you are connected to the internet if not go back and check your connection settings.
Let me know if you still have problems. Good Luck!
Feb 26, 2011 | Nintendo Wii Console
How do i set up my new dsi to the internet
Power on your console and press the A Button on the Wii Remote to reach the Wii main menu. Use the Wii Remote to select the "Wii" button. Now, select "Wii Settings" to access the "Wii System Settings" menu. Using the arrow on the right side of the screen, scroll to page two and select "Internet." SELECT CONNECTION ONE NONE (Don't see "None" in Connection 1? Click the Connection 1 button, then choose "Clear Settings.") Click on "Wireless Connection" and then "Search for an Access Point (Are you using a wired Internet connection to your Wii console? If so, click here for specific help.) Select "OK" and the Wii will display all the wireless networks it finds. (If you're not sure which is yours, or you don't see any wireless networks, click here. Select "OK," "Save Settings," and then "Yes." The Wii console will run a connection test with your wireless network when the test is completed. You should see the following screen: As long as you see "The connection test was successful," the "Wii Support Code" does not matter and can be ignored The connection test was successful - Then you're almost done! After your connection test, the Wii console will check if there is a new Wii System Update available. Once you select "Yes" and "I Accept," the Wii will begin to download any available updates. Click here to find out what's next! The connection test was not successful - If the test was not successful, you will receive an error code. Error Code 51330 or 52130: This means the security code you entered into the Wii is not the same one your router is set to. Look in your router's settings and try again. Please refer to step seven (7) above for more information. All other error codes: Try our error code troubleshooting where we have detailed information on many common error codes. (You can ignore any "Wii Support Code" you receive on a connection test.
Jan 30, 2011 | Nintendo Dsi Pink Console
I have problems connectiong to wii
Restart the router and reconnect all over again. If problem persist please see your service provider.
Cheers
Apr 14, 2010 | Linksys Wireless-G WAP54G 802.11g/b...
Nintendo Wii Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
