Question about Kenmore Washing Machines
My washer will not drain. I bought a new pump, still nothing
  • Kenmore Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Posted on Aug 22, 2010
Hotpoint washer won't spin or agitate
Jump the lid switch and see if it works, then you'll know it's the lid switch
May 16, 2017 | Washing Machines
New pump installed, still not working and nd code
look at ( have a technician look if you want to save money) at the program board for a problem there
Apr 25, 2017 | Samsung WF328AA Front Load Washer
GWL11 washer diplay won't light up or power on. drain pump leaked, replaced both, still nothing
your main board is out very come with a bad drain pump the new pumps and boards come with a fuse to stop this problem. water hit the pump and shorts out the board
Aug 13, 2012 | Fisher and Paykel GWL11 Top Load Washer
Washer will not drain
I have the same problem. I changed the pump and the control switch, but it still does not drain the water out. I am about to give up. It sounds like we may have the same problem. I am still waiting to see if anyone knows whats wrong.
Jan 26, 2010 | Frigidaire FLEB8200DS Top Load Stacked...
WASHER WILL NOT DRAIN WATER KENMORE WASHER APPROX 9 YRS OLD
Does the tub spin without draining?
This JUST happened to me last night. Opened washer after a load and still full of water. Fifteen spins later, still about an inch of water in tub...
RepairClinic.com suggests checking the hoses from the washer tub to the drain pump for anything clogged in it. (WARNING!!! As soon as you remove one end of the hose ANY water remaining in the tub will come RUSHING out if not clogged. I was prepared for water, but not a rush of water.)
If there is no clog in that hose, remove the drain pump and check for something in it.
(My pump was burning up because some how a plastic stick got into it. I am waiting on the new pump now.)
If there is nothing in the first hose or the pump, see if anything is in the hose leading to the drain.
If not, they suggested something either purchasing a new pump as it may have quit working or something may have gotten stuck in between the tubs. This requires tearing apart and sometimes special tools.
Jul 15, 2009 | Kenmore Washing Machines
Whirlpool Duet Washer won't spin
Sounds like the whirling noise is the pump, pumping. Does it drain at all? Check the drive belt and make sure that it is not broken. This system uses a drive belt with a clutch system to agitate back and forth. The clutch system could be bad as well.
This might not be a cheap fix, these are the main components of the system
Mar 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't final spin
After charging me $275 to change the water pump, the repairman said I needed a new computer board for another $160. I went & bought a new washer - this time a regular top loader mechanical washer with no computer. The repairman said computerized washers & front loaders in particular have lots of problems. He said top loader Whirlpools have the least problems.
Nov 13, 2008 | Frigidaire ATF6000ES Front Load Washer
LG dish washer not draining
Normal 0 Thanks to other info gathered from this site and a few quality hours with the washer, I solved this problem for myself.
I experienced the same problem. Did the same things. OE error Drain pump would not drain. Sounded like it was grinding a bit. Just not draining. Checked the strainer. Nothing. I found this link to the service repair manual which has easy to follow instructions on how to disassemble the washer and get to the pump. Removing the door and the pumps is really not that hard.
http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf
Don't be scared. I'm a novice and it was easy. Wear gloves. Lots of sharp edges. All you really need is a screwdriver and pliers to remove hose clamps.
Anyway, I got the the top cover off, removed the front door panel section and could easily access the drain pump. I first pulled off all the hoses. All clear. Disconnected the pumps (easy once I figured out the clip the pump unit slides into). Note there are 2 pumps - a circulation pump and drain pump (larger one). All clear. Reassembled. Still nothing.
Ran a few loads of wash manually draining after each cycle (to keep the wife happy with clean laundry). Yes, you can do laundry while waiting on the part to be delivered. Just get a bucket and drain the washer after each cycle - easier if you pull off the main drain hose and drain it that way versus the little emergency drain slow (slow!).
Became convinced it must be the drain pump so I ordered a new one for $50 here. repairclinic.com
Installed new pump and reassembled machine in about 20 minutes. Worked great. NOW HERE IS SOME ADVICE THAT MIGHT SAVE YOU THE $50 for a PUMP:
After replacing the pump, I was banging on the old one to see why the heck it stopped working. During the process, I figured out how to actually pull the pump apart. There is a rubber washer around the housing below the blade - pull on it hard enough and the pump slides apart. When it did - holy cow! It was filled with grimy sandy muck. I cleaned it all out, but did not feel like testing it to see if worked. So I likely have a spare should the new one ever go out.
Hope this helps.
Good luck.
Nov 02, 2008 | LG Dishwashers
I have a LG TROMM 4.0 WM2277HW
I experienced exactly the same problem. Did the same things. OE error Drain pump would not drain. Sounded like it was grinding a bit. Just not draining. Checked the strainer. Nothing. I found this link to the service repair manual which has easy to follow instructions on how to disassemble the washer and get to the pump. Removing the door and the pumps is really not that hard.
Hope this helps.
Good luck.
Apr 17, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
Sal DeAngelo
fordexpert
Mike Carew
