Question about Legacy Car Audio & Video
I am tryin to install a sony xplode amp and subwoofer in my car to the stock stereo but i dont know what wire to splice into for the rem on my amp
  • 57 Answers
For a remote turn on you can use the acc off of the ing ( test 12volt when car is on befor crank goes to 0 during crank then comes back to 12 voltswhen car is running 12 volts also goes to 0 when ing is turned off and key is in off positon. 12 volts from the battery fused 12 inches from connection and ground. also are you using some sortof high level adapter for an audio signal( this would tap into left and right spks either front or rears and provde you with rcas for your amp
Posted on Aug 22, 2010
Have mex bt2600 sony xplode car cd player ::: also have sony xplode amp model no.xm 754sx problem is i want to hook up a subwoofer and the amp to the head unit (also currently have 2 sony xplode 3ways...
If the Sony front end unit (stereo) has RCA jacks (Left and Right) in the back it's an input to the Xplode amp. If that's right then the Subwoofer putputs should plug or wire into the Xplode amp. I haven't hooked these up for some time but try a search on Youtube with the units you describe I'm more than 90% sure that there are videos there.
Nov 19, 2017 | Sony MEX-BT2600 Car CD/ MP3 Player
I have 2 10' sony xplodes connected to a 2
If your radio is still playing and the subs are giving you music, you most likely have the amp remote wire hooked to a constant power source on the radio. Generally, this is a solid blue wire on both the radio and the wiring harness. It allows the radio to turn the amp on and off when the radio is on or, subsequently, off.
Apr 21, 2010 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
I have a 2002 olds alero and im tryin 2 hook my
Ok to start you need to go to this website and you will have to get the factory adapter for your radio so it can be modified.
.http://www.installer.com/cars/by_car.php?carid=4267 and also check this site this wiring diagram will help.
http://www.modifiedlife.com/2002-oldsmobile-alero-car-radio-stereo-audio-wiring-diagram/
Apr 16, 2010 | Car Audio & Video
Stereo wont stay on and only couple speakers work
on the back of the stereo you should have an rca inputs in the back, it should say either rear, subwoofer, or non-fade. all of these are acceptable, run rca's to the amp from the deck.
also on the deck in the wire harness is a blue wire with a white stripe.
hook a wire up to this and run it to the REM. terminal of your amp. this wire tells the amp to turn on when you turn on your key.
these are the only two wires you hook up the back of the stereo.
hope this helps
Jan 07, 2010 | Sony Car Audio & Video
How do i install a dual xinbp-210 car subwoofer with a pyle amp and stock stereo in a 2005 nissan altima
you can buy an adapter that splices into your back speakers and converts for your amp.
Oct 26, 2009 | Dual XINBP-210 Car Subwoofer
Hooking up amp and subwoofer to stock radio
Are you sure that you want to attempt this?
It's a nightmare if you never have worked on any kind of car stereo. I've installed my share of after market stereos, so I know it's lots of brain work and patience.
The color of the speaker wires are the only wires that you can probably identify right off the bat. It's not too complicated to attempt yourself. If you have put in an after market stereo before. Your Lexus has factory installed rear deck speakers. Look at the bottom side of the rear deck. Pop your head in the trunk and look up.
On the right speaker there are 2 wires and on the left speakers there are 2 wires.
I think that all 1991 Lexus LS models came with factory installed rear deck speakers. The speaker wires are factory installed. You want to keep these original factory wires as is, but want some thicker higher wattage amp wires for your sub woofers, but write down the 2 left and 2 right speaker wire colors with the stripes, for example the red with yellow stripe, blue with red stripe, brown with orange stripe, black with white stripe and so on. There are four wires in all. Keep your wire colors on a piece of paper, because we come back to that later on.
You will need to run the thick red power cable to the car battery. That gets bolted directly down to the battery. You'll have to remove the bottom door jam that holds the carpet down. There might be a couple screws that you'll have to remove to pull up the jam. Tuck the red wire and lead wire in under the carpet and screw the jam back on when done. Do the same for the 4 thick higher amp speaker wires and route them to the back in the trunk.
Make sure to bolt the Black Ground Cable on the Chassis of the car for a good solid ground. The one thing that will cause a short is a loose ground wire or weak ground to the body.
Remove the radio from the dash. Be careful not to break the plastic around the radio. You should probably ask somebody for help, if you can not handle it yourself.
Now we need that piece of paper with the 2 left and 2 right wire colors with stripe laid out, you can do your splicing of wires. Simply splice the left and right speaker wires with the amp normal speaker wires that lead into the amp.
The amp may have stereo RCA jacks for input, I'm not sure which you have.
Make sure to match Left to Left and Right to Right. Now the AMP lead wire gets connected to the stereos power wire. This wire may be red or yellow, but I do not think it's gray. To test the wire splice into the yellow wire with the lead and start the car and turn it off. If the amp stays on with the car turned off, then change it to another wire. The goal is that it won't drain the battery with the car turned off.
There's some troubleshooting involve with factory installed stereos and making modifications. If you get this far you did a great job. You'll have it when the lead wire is connected and the car turns off and the amp turned off and when the car turns on and the amp turns on. Make sure you do not mess with the antenna wire. that turns on and then shuts off after the antenna is up.
Aug 28, 2009 | JBL GTO804 8" 4-ohm Component Subwoofer...
Diagram on what wires go were for 2003 chevy cavalier / gm radio interface to sony xplode cd player
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: Pink
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Apr 29, 2009 | Car Audio & Video
I want to remove the face of sony stereo when i leave my car for security but dont know how it clips off.
what model is your radio. I know you said Sony, but, there are many different kinds (xplode,) if you can provide this information I will most likely be able to help you
Nov 10, 2008 | Car Audio & Video
Car 6-9s soud crappy with new deck
what do you mean? distorted? low? echoey? i know you checked the wiring but try one more time. did you use a wire harness? remember the speaker wires out the radio with the black line on them is the negative side. make sure whatever color wire from the stereo that you plug to the car factory wire to, and know if it was positive or negative when you go plug it on the speaker.
May 25, 2008 | Sony Xplode P5 Turbo Subwoofers Car...
Not even static?!
if the flex wires are atached from the cone then the coil is disconnected.hit me up if you need more info.
Aug 09, 2007 | Dual XINBP-210 Car Subwoofer
Car Audio & Video Logo
54 people viewed this question
Top Legacy Car Audio & Video Experts
Tygh Duval
Tygh Duval
Putter71
Level 1 Expert
Robert Little
Level 1 Expert
Are you a Legacy Car Audio and Video Expert? Answer questions, earn points and help others
