Question about Microwave Ovens
I have a Emerson Mircrowave model: MW9107B The mircowave is active, but will not heat. Im thinking its a fuse. If I am wrong, what could it be?
  • Microwave Ovens Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Posted on Aug 22, 2010
Microwave Model JVM 1870 stopped heating, all else works (timer)
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
ggk
Nov 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My Emerson MW8115SS microwave works but doesn't heat anything up, what could be wrong? And is it a easy fix?
Hi there.
Obviously it is "not working"
Could be an internal fuse or the activator is just finished.
Iceman.
Nov 10, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
How to change a light bulb in a emerson mircowave model mw8115ss
If this is freestanding m/w:
1. disconnect from outlet
2. take the cover off.
3. light bulb located on right upper corner.
Nov 30, 2008 | Emerson Black Microwave Oven
Emerson Microwave (mw8992rd) not heating up
I have replaced the main fuse on this model. Though blown main fuses are common in this model, it will not even turn on when they blow, so your problem is most likely NOT a blown fuse. I had heard of your problem so, when replacing the main fuse inside one, I looked for additional fuses and saw none. The store was wrong. Even if it were a fuse, the security Torx screws mean that you couldn't replace the fuse anyway.
This microwave seems to have been haphazarly been recommended by Consumer Reports, but it is terribly unreliable. The turntables break when popping popcorn, the main fuse repeatedly blows, and they also stop heating.
Oct 19, 2008 | Emerson MW8985W Microwave Oven
Mircowave oven
CHECK THE PROBLEM ON THE BURN THERMAL FUSE ON YOUR UNIT.
Aug 16, 2008 | Emerson MW8107WA Microwave Oven
If we close the mircowave door the units start to run by itself. - it will not heat, but the light comes on and the turntable rotates it will not stop until we turn the power off - when power is turned...
i think you have a welded controller, either a digital one or a mechanical one. microwave won't run unless you switch it to run. the door switches are safety switches to turn off the microwave once you open the door. if you have a digital controller, you could have a welded relay, if you have a mechanical timer, it could be a welded contact at the timer. another thing is that it should heat what ever you are heating. if it is not heating, check if it has a fuse and if it is busted. some fuse are installed to protect only the magnetron that is why the light and turn table are still running. if there is no fuse to the magnetron, then check the diode from the capacitor to the ground. it could be open. if not then you can have a bad magnetron. i hope i was able to help.
Jun 24, 2008 | LG Microwave Ovens
Emerson Model MW8627W does not heat after changing fuse!
check the magnitron and capacitors one of this is bad
Sep 18, 2007 | Emerson MW8627W Microwave Oven
Microwave Ovens Logo
120 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
