Question about Kitchen Ranges
Jennaire stove flashing F3 and beeping. I think its a timer issue but knob to set timer not working. I tried to reset by turning off and on didn't work. This is my moms stove 10+ years old can't find manuel. I can't find model # the way stove wedged in kitchen this noise is annoying any suggestions
  • 1 more comment
  • 1bigragu Aug 22, 2010
    there are only two things inside this oven is sensor located on top or in rear of oven a think that looks like a fan? the think on top is like a drop down screwed cap
  • 1bigragu Aug 23, 2010
    thank you bob i know exactly the part now saw it but didnt think that was it the pictures and web sites helped a lot thanks for your help problem will be fixed in the meantime i rolled stove out and unplugged it
    Very helpful when he sent the pictures. It was like ohhhhhhhh that thing. I sent bob a thank you too. Id recommend fix ya in a minute this is my second time using and been great. Both times. Thanks
    Genius:
  • 1,478 Answers
F3 stands for a faulty oven sensor. Unplug the oven, then replace the sensor. Should be back to normal. The sensor is inside the oven. When you pull on the sensor, you will get to a male/female quick connector. When you unplug it, be careful not to lose the other end behind the oven wall or this simple repair won't be so simple anymore.
Take care.
Posted on Aug 22, 2010
  • 3,153 Answers
Depending on the exact model it is either a short on the temp sensor OR a fan on with no oven selected.
If it is the sensor then it will look similar to one of these
http://www.applianceaid.com/pictools/Tempsensors.JPG
To get the EXACT sensor you need a model number and they can be found in two places
One is on the rear of the unit and the other is stamped into an area near a door.
On models that have a lower drawer there is sometimes some extra info there too
Without an exact model it is like throwing mud at the moon "Ya just ain't gonna hit it"
Posted on Aug 23, 2010
The oven beeped, the screen said F3, now the oven is locked. It smells like a hot wire
What does F3 mean on my Frigidaire stove when it sounds ...
www.shopyourway.com > Manage My Life > Questions
My Frigidaire range beeps and flashes F3. ... 790.92413202 and when I turn on bake or broil it just shows an F3 code on the screen what does this mean?
What does fault codes "F2" and "F3" mean on a Kenmore ...
I have a Kenmore wall oven model 911.41059591 that beeps and flashes F2 or F3 and shuts off. ... The "F2" and "F3" fault codes is most likely indicating an open oven ... Next, the control panel will need to be taken off in order to measure the ...
Oven error code "F2" and how to fix it ' AskGene.com
www.askgene.com/.../oven.../what-means-the-error-code-"f2"-on-your-o...
Mar 26, 2007 - The error code "F2" will be displayed along with a beeping sound if the
Jan 27, 2016 | Kitchen Ranges
F3 on stove. Can't turn off
Hi Marie -
Since you didn't mention the brand and model of your stove - I can only offer general help. The first thing I recommend is that you shut off the power to the stove at the circuit breaker panel. It should be a double-wide 40 or 50 amp circuit breaker. Move the handle to the OFF position and leave it there for 30 seconds or so. Then return the handle to the ON position again. Doing this should "erase" the memory of the stove and reset the electronics. If the problem is not longer an issue - the F3 code should be gone. If it returns, we'll have to do more. That will require knowing the name of stove's manufacturer and model number. Let me know how you make out and if you need more help - provide the info requested and I'll see what else I can do. Good luck!
Mar 18, 2014 | managemylife.com
Can not re set time
Are you trying to reset the timer or the Clock? It's a bit different on each stove, but usually if it's the clock, you press the Clock button TWICE, the time will then begin to flash on and off. then press the + or - sign to increase or decrease the time. When you have gotten to the time you desire, PRESS the Clock button ONCE more. The time will be set, & then you should be all set :).
If it's the KITCHEN TIMER, Press the Kitchen Timer button ONCE, the timer will start flashing. It will usually flash all 0000's. Press the + sign to add minutes, then Press the Timer Button ONCE again, it will be set to the amount of time you added and will beep once the time runs out.
Disclaimer: This instruction is primarily for the General Electric Stove. If you state your specific model, I could be more specific.
Nov 12, 2010 | Ovens
Oven beeps and displays F2 or F3?
Hello there:
this error code is telling you that the oven temperature sensor is going haywire and needs to e replaced
Here is the 2 error codes and what they mean and what needs to be checked
F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F3 Open oven temperature sensor circuit Replace oven temperature sensor
Oct 04, 2010 | General Electric Stove/Oven/Range Chrome...
After my oven heats up and ive set the timer it starts beeping and showing F3 and doesnt stop soihave to turn it off
The "F3" error code means the oven sensor is open.
An ohmmeter reading for the open circuit should be "∞".
Resistance should be measured across both wires.
The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter – How to check continuity with Ohmmeter.
- The part number for the oven sensor is AP2023862
Here are the break down diagrams for the GE range Model JB940AB1AA
Mar 22, 2010 | General Electric Stove/Oven/Range Chrome...
My stove has started to beep random--why
WE used the broil button last night and our stove started beeping nonstop.It also say F1 three hrs of beeping we unpluged it for the night.When we turned it back on today same thing happened with the beeping and F1.hOW CAN WE FIX THIS?
Oct 28, 2009 | Frigidaire FEF336BC Electric Kitchen Range
The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
Old Eaton Viking Stove - broil won't turn off.
I have the same stove, and just had the same problem. I looked all over the internet to try to find an answer, and then went back to my stove to check the serial number and where the fuses are was the instructions printed on the stove itself.
SO HERE'S THE SOLUTION
1. The timer start knob (the one with little running guy picture) must NOT be pushed in. If it is, turn it slowly until it snaps out.
2. The timer stop knob (the one with the picture of the stop sign) must be completely pushed in.
I hope that helps everyone out!
Dec 21, 2008 | Viking Stove/Oven/Range Timer Knob -...
Caloric gas stove prestige series
to jenna 12 Does your stove have a stop and start timer? When you set your clock you may have inadvertantly moved the stop or start time on that timer. Check them, if they have knobs for setting the stop and start time, make sure the pointer is pointing to the current time and that the knob is popped out and not stuck in. when you have it right both the stop and the start knob should be out, not pushed in. They will pop out when you turn them to the current time.
These timers allow you to start something cookin at a time delayed several hours. this means they will not allow the oven to come on until it hits that time that you may have set in error.
If your stove has a digital stop and start timer check each one so that both show the current time, then your oven should light.
Oct 13, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
83 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
