Question about Polaroid i534 Digital Camera
I534 camera protected card. how do i unprotect camera will not take pictures
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Aug 23, 2010
I want to delete protected pictures
If the picture on the camera is protected, unprotect the picture first. In playback mode, scroll to the protected picture, then press the AE-L/AF-L button on the back of the camera.
If the memory card is protected, take the card out of the camera. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 20, 2013 | Nikon D40 Digital Camera with G-II 18-55mm...
How to unlock a photo in camara
The protect function allows a user to protect a picture from accidental deletion. To unprotect a picture on your camera, scroll to the protected picture that you want to delete, then press the Menu button (the button to the right of the Play button.) Scroll down the menu and you should come to an option that allows you to Protect/Unprotect the picture. Since your picture is currently protected, deselect that option. You should then be able to delete the picture normally.
Alternatively, you could also format the memory card, however this deletes ALL photos and data you have on the memory card. If you are trying to completely clear the memory, this is the best way. After turning on your camera, simply press the Menu button, scroll to Setup, then scroll down to Format. Select Format, it will ask you if you want to format the memory card, or the camera's built-in memory. Format whichever one you want to clear, if you are using a memory card then your pictures are stored on the memory card. It will take a few seconds to format.
Hope this helps.
Dec 05, 2012 | Kodak EasyShare M1033 Digital Camera
How to delete protected images
If you want to delete everything on the card, the easiest way is to format the card. This will wipe out all images (and any other data as well) on the card, whether protected or not. The Format command is in the Setup menu. Details on page 32 of the manual.
To delete individual protected pictures, unprotect them first. From the Playback menu select Protect/Unprotect (the key icon). Details on page 84.
Mar 16, 2012 | Canon PowerShot SD600 Digital Camera
Sdcard protect: when I plugg on camera an error message appears on screen " SDcard is protected " I tried to change SDcard and the same message related to sdcard appears . I can not unprotect...
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 25, 2011 | Intova CP8 Digital Camera
I put my memory card into my Kodak EasyShare C143 digital camera. I press the review button, but all that comes up is that the file is 'Unrecognised'. One out of the three pictures is unprotected, but the...
It sounds as if the card was not formatted for the camera before it was put to use. My suggestion is that you attempt to download the images that you do have to the computer, then format the memory card. Always format a new card and after each time you download pictures from the card to the computer.
Dec 28, 2010 | Cameras
The camera says that my Memory card is protected. How do I unprotect my pictures? Also how do I reset switch on memory card? Thanks
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If you had protected any pictures on the card, then while viewing that picture press the Menu button. Use up/down to select Unprotect.
Oct 13, 2010 | Kodak Easyshare C182 12MP Digital Camera
I have a i534 Polaroid digital camera and its locked on protected mode. I'm unable to take pictures and can't find my manual.
Aug 07, 2010 | Cameras
How to unlock protected card on i534
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
May 13, 2010 | Polaroid i534 Digital Camera
How to unprotect the memory card
On most sd cards there is a physical (tiny) sliding switch on the memory card. Here is a picture of a standard SD card. On the left you can see the gray switch in the unlocked position. Hope that helps. -WN
4bfc547.jpg.
Jul 27, 2008 | Nikon Coolpix 4600 Digital Camera
the problem isnt with your camera, its your memory card, and it isnt a problem at all. simple solution- take out your memory card, and on the side there is a tiny switch. all you gotta do is flip the switch. quick and easy. hope that helps anyone.
May 18, 2008 | Microtek Take-it MV320 Digital Camera
Polaroid i534 Digital Camera Logo
65 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
