Question about LG WM1812C Front Load Washer
My laundry is on 2nd floor in the house, I had the washer for 4 years and it always smelled if I left the clothes in it for too long after the wash, , it seems to smell up the entire house, not all the time. It is lg front loader
  • LG Master
  • 43,501 Answers
Here is a tip about how to clean your washer
How to have a Clean Washer
http://www.fixya.com/support/r4356970-clean_washer
heatman101
Posted on Aug 22, 2010
Clothes are sour after wash
The odor is being transferred from your washing machine. The washer must be cleaned first or the clothing will be reinfected upon washing.
The problem area is always just above the normal waterline where suds and soiled water splash up and don't get rinsed out.
To clean your washer add 1 cap of smelly washer cleaner to a full load of laundry in a hot cycle. The added bulk of the laundry will raise the water level to include the "splash area". Intermittent pausing to soak is a good tip for more extreme problems.
Jul 06, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Tip
Mildew smell, gray streaks, won't drain, puddles on floor, burnt motor smell
I have had various issues with my fisher paykel top loader (GWL10US) and didn't realize they were all due to a plugged drain. I had mildew smell from excess water that never drained, gray streaks on clothes from dirt and residue that remained in tub, water left in tub and wet clothes after spin cycle, puddles on floor, and finally it wouldn't drain at all and the motor smelled hot/burned out.
This was all caused by a sock that got in between the outer/inner tub and went to the lowest part of the drain and finally blocked things so a leak was created and water dripped into the motor and caused a burn out.
To repair, bail water out of washer and unplug the washer. Tip machine back so you can see the motor/white plastic housing unit (pump) on bottom of washer. Where this unit attaches to the bottom of the washer, look for a clip/tab that you can pull with your finger (like a childproof cap) and twist the unit off the machine and unplug the connectors (there are 2). Once this unit is removed, you will see a quarter-sized hole into the bottom of the wash tub. this is where i found the elusive SOCK and pulled it through the hole.
When you order the "pump" it comes as one unit--motor and white plastic--and you twist it back onto the machine and plug in the connectors.
another website I've found helpful is ths.gardenweb.com/forum/laundry
on Oct 21, 2008 | Fisher and Paykel IWL12 Top Load Washer
Our washer smells like mildew or mold whats up?
is it fully draining? old water will start to cause this. wash ur clothes and immediately dry them. dont leave wet clothes in the washer over a days period. hope i helped
Mar 12, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Bath towels smell sour
I started adding 1 cap of bleach with 1 cup of water to all my loads in the bleach dispenser and this stopped the smell problem with my sweaty clothes.Sour towels i fixed with using Win high performance sports detergent plus my usual dose of he detergent along with a 2nd rinse.Keep the lid open when not in use always.
Dec 27, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
I have a strange odor
It is normal for all models of washing machines to have a gallon or two of water left inside the bottom of the washer and in the drain pump. This is not the cause of odor. The smell is being caused by residue left on the inside of the plastic outer tub.
The best way to clean a stinky washer is to use a washer cleaner that is able to be used with clothing in the washer. The added bulk of the laundry will raise the water level to include the splash area 3-5 inches above the normal waterline. This splash area always has the worst buildup.
After the odor is gone you'll need to change washing habits to keep it away.
Oct 19, 2009 | Washing Machines
Sulphur like smell when washing the clothes
something not well with motor, like belt or clutch slipping. or motor overheating. you could use the machine until something fails, but i would not leave the house with the machine running.
Aug 09, 2009 | Zanussi ZJD1219 Front Load Washer / Dryer
Burning smell at end of wash
could be the belts but it could also be the motor depending on the smell
Jun 04, 2009 | Kenmore 22622 Top Load Washer
Musty smell
Run your machine through its cycle with NO clothes and when it is filling up with water put bleach in the water. Put bleach in only at the start of cycle.
Before you do this clean all inside parts the best you can yes with bleach and you can run something like fleecy to make clothes soft and smell nice when you wash your clothes as well. Our machine has a special holder to put softener in.
Do NOT have clothes in when running the heavy bleach through it. This should kill the bacteria .
Aug 12, 2017 | Maytag ATW4475TQ Washer
Bad mold and smell from washwe
i have repaired appliance most my life i tested soaps and softer,at our own family shop,i can tell you that washers do not make mold or bad smells either does cloths its what and how much product that you are pulling in the washer that is molding and smelling and it stays in cloths building up load after load,i have a kenmore he3t front load washer i use 1/3 cup powdered only.armen hammer only. non he only.my washer inside is spotless smells clean and fresh all the time, you will need to clean yours inside out with bleach then use affresh weekly switch to 1/3c powered soap
Nov 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Bad smell
washers and dryers dont make smells themselves its a problem with something u might be putting in it. if u tend to add alot more detergent then usual to your towels then they never completely rinse the water out and will have a mildew smell
Feb 18, 2007 | Whirlpool GEW9250P Electric Dryer
LG WM1812C Front Load Washer Logo
67 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
