Question about Whirlpool LTE5243D Top Load Stacked Washer/Dryer
Not spinning My Thin Twin has stopped spinning....it goes through the cycle and then stops at the spin cycle. Do you think this can be fixed without spending a ton of money, or does the unit need to be replaced? Thanks
    Genius:
  • 1,122 Answers
YOUR LIP SWITCH IS BAD REMOVE FRONT PANEL,TRACE WIRE FROM SWITCH TO JACK,UNPLUG,ON MACHINE SIDE CUT BOTH OUTSIDE WIRS AND WIRE NUT THEM TOGETHER,TAKE SURE UNIT IS UNPLUGGED FIRST,YOUR DONE,THANKS-MIKE
Posted on May 29, 2008
My Thin Twin stackable washer & dryer Model # LTE5243DQ3 is having problems w/the washer spin cycle. I'm thinking I may just need a new timer because it goes through all the cycles except the spin...
Before wasting money on a timer that wont be returnable once it is removed from the packaging please respond to me and tell me does the washer do everything including draining, and the only thing it will do not do is spin
or will it wash but not drain and spin
their are 2 posibilities based on your response and neither is the timer
Thanks,
Gene
so ya know i have beena appliance repair technician for over 30 years
Jul 23, 2011 | Whirlpool LTE5243D Top Load Stacked...
Hi, I own a Whirlpool Thin Twin Model# LT5000XSN1. I bought it used from a CRAPPY dealer (worst mistake EVER), since day one, we have had an issue with the spin cycle. The cycle will agitate then when the...
This sounds like a classic clogged empty pump issue. The empty cycle is timed and then it steps on to the spin cycle. The machine won't spin if there is still water in the bottom of the drum. When you reset it to a spin cycle again, you are making it run through the empty cycle again, finally getting rid of the water that the clogged filter could not evacuate on the first attempt.
You need to clean the empty pump filter. Now... Where is the filter???? Hmmmm... not sure. It MAY be behind a little panel in the front of the machine near the bottom. I can't find a picture of the machine on the net so I'm not sure.
Clean the filter, I'll bet your problem goes away. You have to wonder why the idiot who sold the machine to you hasn't suggested this!
Jun 21, 2011 | Washing Machines
It's heavy duty thin twin model. The cycle stops at spin and water stays in the mashine.
When it gets to the SPIN cycle,wait 45 seconds. If it does not spin,open then close the lid.
If it spins then,replace the timer.
If it does not spin,replace the lid switch.
Jul 27, 2010 | Whirlpool LTE6234D Top Load Stacked...
My washing machine doesnt stop ever!!
We are very sorry to hear this and we apologize for the inconvenience this has caused you. We would be glad to look into this if you could email us at Whirlpool_Digital@Whirlpool.com with your name, address, phone number and the model & serial numbers of the laundry center.
Mar 23, 2017 | Whirlpool Washing Machines
Washer stops in mid cycle
This is probably normal. There is a natural pause between agitating and draining, and again between draining and spinning. Hope this helps!
Feb 04, 2009 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool Thin Twin Stopped Spinning at End of Cycle, H20 Will Not Drain
You have a sock caught in the pump, need to pull off outer case and remove pump and clear it out.
May 23, 2007 | Whirlpool LTE5243D Top Load Stacked...
How can I fix my whirlpool thin twin washer?
It almost sounds like your motor is kicking out on overload. The fact that it starts agitating after the fill can rule out the pressure switch. You have installed a new timer so we should be able to rule that out. It's possible that your pump is binding, which is attached directly to your motor and causing it to overheat. To tell for sure you would have to check the motor to see if it's getting power when it cuts out. Check your terminal block where the power cord comes in to see if all connections are secure. Other possibilities could be the clutch and brake assy. With out being there too see the problem, this is where I would start.
Apr 27, 2006 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool LTE5243D Top Load Stacked Washer/Dryer Logo
145 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
